Dear Forum users,
I'm working on a monitoring system(for my beehives) based on one Arduino Uno (with an ethernet shield) that takes data from his ADCs and over software serial from a Teensy2++ and then sends the data to Exosite.
Until this point everything worked and so I tried to add the time(synchronised over internet with NTP) in order to be able to reset some variables overnight, the problem is that now I get the time but I can't send data to Exosite.
Does someone know where the problem is?
Here is the code, I always only get to the point were the arduino has the data from the Teensy and then it usually resets:
//librerie
#include <SPI.h>
#include <SoftwareSerial.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Exosite.h>
#include <avr-libc.h>
#include <Time.h>
// function that calculates the temperature
enum {
T_KELVIN=0,
T_CELSIUS,
T_FAHRENHEIT
#define EPISCO_K164_10k 4300.0f,298.15f,10000.0f // B,T0,R0
#define SEN00250_10k 3977.0f,298.15f,10000.0f // B,T0,R0
#define RESISTOR 9950.0f
float Temperature(int AnalogInputNumber,int OutputUnit,float B,float T0,float R0,float R_Balance)
float R,T;
R=1024.0f*R_Balance/float(AnalogInputNumber)-R_Balance;
T=1.0f/(1.0f/T0+(1.0f/B)*log(R/R0));
switch(OutputUnit) {
case T_CELSIUS :
T-=273.15f;
case T_FAHRENHEIT :
T=9.0f*(T-273.15f)/3.28f+32.0f;
default:
return T;
// Indirizzo MAC della scheda Ethernet
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x11, 0x22 };
//Username di exosite
String cikData = "a0287bfc60666d2f90a5b87fe28b0db11952b969"; // <-- Fill in your CIK here! (https://portals.exosite.com -> Add Device)
unsigned int localPort = 8888; // local port to listen for UDP packets
IPAddress timeServer(199,167,198,163); // pool.ntp.org NTP server
//IPAddress timeServer = "hera.limescope.net";
const int NTP_PACKET_SIZE= 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
int timeZoneHour = +2; // Enter Your Actual Time Zone EDT (-4)
long timeZoneOffset = (timeZoneHour * -1) * 60 * 60 ;
int NTP_Update_Interval = 60; // Number of secs before resync - should be longer just testing really
//array che prendono i dati
unsigned int bilancia[50];
unsigned int compensazione[50];
//totali bilancia
unsigned int bilanciat1;
unsigned int bilanciat2;
unsigned int bilanciat;
//totali compensazione
unsigned int compensazionet2;
unsigned int compensazionet1;
unsigned int compensazionet;
int cleaned;
int i;
//costanti per il conteggio
unsigned int ins;
unsigned int insHigh;
unsigned int insLow;
unsigned int outs;
unsigned int outsHigh;
unsigned int outsLow;
int AnalogInputNumber;
// global
Exosite exosite(&Ethernet, mac, cikData);
//pin della comunicazione con il beecounter
SoftwareSerial myserial(6, 7); // RX, TX
myserial.begin(9600);
exosite.init();
// Serial.println("Starting");
// start Ethernet and UDP
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
Udp.begin(localPort);
Serial.print("Got IP:");
Serial.println(Ethernet.localIP());
setSyncProvider(getNTPTime);
Serial.println("Looking for a time");
Serial.println("Got a Time");
//while(timeStatus()== timeNotSet)
setSyncInterval(NTP_Update_Interval);
time_t t = now();
printDigits(hour(t));
Serial.print(":");
printDigits(minute(t));
String retVal;
//get the data from the ADCs
for(i=0; i<50; i++){
bilancia[i]= analogRead(A0);
compensazione[i]= analogRead(A1);
bilanciat1= bilanciat1 + bilancia[i];
compensazionet1= compensazionet1 + compensazione[i];
delay(30);
bilancia[i]= 0;
compensazione[i]= 0;
bilanciat2= bilanciat2 + bilancia[i];
compensazionet2 = compensazionet2 + compensazione[i];
delay(30);
bilancia[i]= 0;
Serial.println("Got the scale data");
//medie parziali e medie totali
bilanciat1 = bilanciat1/50;
bilanciat2 = bilanciat2/50;
compensazionet1 = compensazionet1/50;
compensazionet2 = compensazionet2/50;
bilanciat= (bilanciat1 + bilanciat2)/2;
compensazionet = (compensazionet1 + compensazionet2)/2;
//calculate temperature
AnalogInputNumber = compensazionet;
float Temperatura = 100*Temperature(compensazionet,T_CELSIUS,SEN00250_10k,RESISTOR);
Serial.println("Calculated the temperature");
//read data from the teensy over software serial
ins = 0;
outs = 0;
while(ins == 0){
myserial.listen();
if (myserial.available() > 4){
if (myserial.read() == 'I'){
insHigh = myserial.read();
insLow = myserial.read();
outsHigh = myserial.read();
outsLow = myserial.read();
outs = outsLow + (outsHigh*256);
ins = insLow + (insHigh*256);
Serial.println("Getting beecounter data");
Serial.println("Got beecounter data");
//The software interrupts here and it resets
//Send analog input value to Exosite, use the alias (resource name) "1"
exosite.sendToCloud("Bilancia", bilanciat);
exosite.sendToCloud("Compensazione", compensazionet);
exosite.sendToCloud("Temperatura", Temperatura);
exosite.sendToCloud("Ins", ins);
exosite.sendToCloud("Outs", outs);
//exosite.sendToCloud("Cleaned", cleaned);
Serial.println("DATA SENT");
//send signal to the teensy to reset variable at midnight
if(hour() == 00){
myserial.print('S');
ins=0;
//azzerare costanti bilancia
bilanciat1=0,
bilanciat2=0;
bilanciat=0;
compensazionet2=0;
compensazionet1=0;
compensazionet=0;
i = 0;
//funzioni
void printDigits(int digits){
if(digits < 10)
Serial.print('0');
Serial.print(digits);
unsigned long getNTPTime()
Serial.println("In getNTPTime");
sendNTPpacket(timeServer);
if ( Udp.parsePacket() ) {
Serial.println("Got Time Packet");
Udp.read(packetBuffer,NTP_PACKET_SIZE);
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
unsigned long secsSince1900 = highWord << 16 | lowWord;
const unsigned long seventyYears = 2208988800UL + timeZoneOffset;
unsigned long epoch = secsSince1900 - seventyYears;
return epoch;
Serial.println("No Time Packet Found");
return 0;
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address)
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); //NTP requests are to port 123
Udp.write(packetBuffer,NTP_PACKET_SIZE);
Udp.endPacket();
Thank you
Ciaociao
