Get Ultra sonic sensor to control MIDI channels (instead of notes)
Hey! I'm trying to control My Korg Volca Sampler with an ultra sonic sensor. The problem is that the code I am using is sending tones. But on the Volca sampler each different sample lays on different MIDI channels. So I would like to control the channels instead. For example: if an object is 3 cm away from the sensor a note on channel 3 should be played and if the object is 5 cm away from the sensor a note on channel 5 should be played. Is this possible?
This is the code I am using:
/ MIDI THEREMIN
// Moritz Simon Geist
// www.sonicrobots.com
// v.1.0 14 March 2014
// This sketch uses an HC-SR04 Ultrasonic Sensor and produces an MIDI out signal, according to the measured distance form a object
// Be sure to include the latest MIDI Library  (here 4.0)
// http://playground.arduino.cc/Main/MIDILibrary#.UyNutYUn2Hs
// Wiring: Ping pin from the HC-SR04 Ultrasonic Sensor --> arduino Pin 13,
// Echo pin from HC-SR04 Ultrasonic Sensor --> Arduino PIN 12
// MIDI-Out --> TX according to this sketch http://arduino.cc/en/uploads/Tutorial/MIDI_schem.png
#include <MIDI.h>
int pingPin = 13;
int inPin = 12;
long duration;
int cm_new = 20;
int cm_old = 20;
int sens = 5; // sensivity range when to launch a new  note
  Serial.begin(31250); // MIDI Begin
  pinMode(pingPin, OUTPUT); // setup the Pins
  pinMode(inPin, INPUT); // setup the Pins
// The PING is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(inPin, HIGH); // the singal from the Sensor is measured. The length of the pulse describes the distance form an object to the sensor.
cm_new = map(constrain(duration, 20, 2500), 50, 2000, 96, 48); // contrain --> set a threshold to cut values of the sensor that are to far away of to short (20 .. 3000) MAP --> Map the sensor range to a note values vom 96 (A high C) to 48 (a low C)
if (cm_new != cm_old) // only if a new sensor value is detected, a new nite will be send. IF the object stays stable infront of the sensor, no note will be send.
 MIDI.sendNoteOff(cm_old,0,1);   // Stop the old note
 MIDI.sendNoteOn(cm_new,127,1);  // Send a new Note (pitch , velocity 127, on channel 1)
cm_old = cm_new;
delay(150); // for
Is this possible?
Yes.
replace with
 MIDI.sendNoteOff(44,0,cm_old);   // Stop the old note
 MIDI.sendNoteOn(44,127,cm_new);  // Send a new Note (pitch , velocity 127, on channel x)
Then make sure you use the map function to convert your input from the sensor into the range of channels you want to use. I used 44 as the note value but you can make that anything you want.
