Get value after increment
How can i get the initial value after increment or dircrement. :confused:
Not sure exactly what you mean, but sounds like you should save the value into another variable called say oldValue before you change it?
#include <Wire.h>
#include <LCD.h>
#include <Servo.h>
#define I2C_ADDR    0x3F
LiquidCrystal_I2C  lcd(I2C_ADDR,2, 1, 0, 4, 5, 6, 7);
unsigned long prevMillis;
int count = 10;
int minute = 11;
int counter = 0; // initial amount of presses
// ONE TIME RUN
  lcd.begin (16,4);    // Inicializar el display con 16 caraceres 2 lineas
  lcd.setBacklightPin(3,POSITIVE);
  lcd.setBacklight(HIGH);
  // Print a message to the LCD.
  lcd.setCursor(2,2);
  lcd.print(":");
  prevMillis = millis();  // get the time at the start
// REPEATED RUN
     countdown();
void countdown() {
    delay(150);
    unsigned long curMillis = millis();
  if(curMillis - prevMillis >= 1000){
    count -= 1;
    lcd.setCursor(3,2);
    lcd.print(count);
    prevMillis += 1000;
   if (count<10){
    lcd.setCursor(3,2);
    lcd.print("0");
    lcd.setCursor(4,2);
    lcd.print(count);
    if(minute<10){
    lcd.setCursor(1,2);
    lcd.print(minute);
    lcd.setCursor(0,2);
    lcd.print("0");
    if(minute>9){
    lcd.setCursor(0,2);
    lcd.print(minute);
      if(count == 0){
        minute -= 1;
        count = 10;
what i want is after variable “minute” reaches cero its initial value to be 11 again.
    if(minute == 0){
        minute =[i] initial value[/i];
Can't you just say....
if(minute == 0)
    minute =11;
Yes, but the thing is that "minute" will be any number. I can adjust the number with a push button increasing or decreasing. But thank you for you answer i found out that i can create two variables with the same value. By the way, can you rate my english? xD
