Hi, I can see that many people are asking about something like that, I also have a challenge with it, but I'm taking it step by step. My project is to look at a website that provides the current hourly price for electricity in my area. I want to take that value and use it to activate various devices in the house, but my first question is, is it possible to retrieve that value. The link is here. :
The picture shows what kind of value I need.
Can this value be retrieved or is the page structured in such a way that you cannot get hold of the value in question.
That is common. I built a weather site reader. Instead of trying to read the site, I found the XML source that it accesses. 1000 times easier to utilize.
the file you have shown how did you get it.. where is the link. It's something like that, I think I can use.
I just couldn't seem to find the information in the source code of the website
Hi thanks. I got the link in a previous answer, I have tried to use a base client in the arduino library. but I get an error.. it is as that I can't be allowed to download the data to my arduino. ( www.ewii.dk/api/pris-el-time-for-time ) but it is also possible that it is me who is using GET incorrectly....
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "www.ewii.dk"; // name address for Google (using DNS)
//www.ewii.dk/api/pris-el-time-for-time
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 1, 177);
IPAddress myDns(192, 168, 1, 1);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// Variables to measure the speed
unsigned long beginMicros, endMicros;
unsigned long byteCount = 0;
bool printWebData = true; // set to false for better speed measurement
// You can use Ethernet.init(pin) to configure the CS pin
//Ethernet.init(10); // Most Arduino shields
//Ethernet.init(5); // MKR ETH shield
//Ethernet.init(0); // Teensy 2.0
//Ethernet.init(20); // Teensy++ 2.0
//Ethernet.init(15); // ESP8266 with Adafruit Featherwing Ethernet
//Ethernet.init(33); // ESP32 with Adafruit Featherwing Ethernet
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection:
Serial.println("Initialize Ethernet with DHCP:");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip, myDns);
Serial.print(" DHCP assigned IP ");
Serial.println(Ethernet.localIP());
// give the Ethernet shield a second to initialize:
Serial.print("connecting to ");
Serial.print(server);
Serial.println("...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.print("connected to ");
Serial.println(client.remoteIP());
// Make a HTTP request:
client.println("GET /api/pris-el-time-for-time");
client.println("Host: www.ewii.dk");
client.println("Connection: close");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
beginMicros = micros();
// if there are incoming bytes available
// from the server, read them and print them:
int len = client.available();
if (len > 0) {
byte buffer[80];
if (len > 80) len = 80;
client.read(buffer, len);
if (printWebData) {
Serial.write(buffer, len); // show in the serial monitor (slows some boards)
byteCount = byteCount + len;
// if the server's disconnected, stop the client:
if (!client.connected()) {
endMicros = micros();
Serial.println("disconnecting.");
client.stop();
Serial.print("Received ");
Serial.print(byteCount);
Serial.print(" bytes in ");
float seconds = (float)(endMicros - beginMicros) / 1000000.0;
Serial.print(seconds, 4);
float rate = (float)byteCount / seconds / 1000.0;
Serial.print(", rate = ");
Serial.print(rate);
Serial.print(" kbytes/second");
// do nothing forevermore:
while (true) {
delay(1);
the error i get comes here:
it's like there's something with the "flear server" that's the problem.. ????
