Get value from protected member of class
Hi, i'm really new to Arduino.
I have Arduino Mega, a USB host shield and a barcode scanner. I'm using this library >> link and modified it example so barcode scanner worked (Got it from here) to read what barcode scanner scanned and it worked just fine.
#include <usbhid.h>
#include <usbhub.h>
#include <hiduniversal.h>
#include <hidboot.h>
#include <SPI.h>
class MyParser : public HIDReportParser {
  public:
    MyParser();
    void Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf);
  protected:
    uint8_t KeyToAscii(bool upper, uint8_t mod, uint8_t key);
    virtual void OnKeyScanned(bool upper, uint8_t mod, uint8_t key);
    virtual void OnScanFinished();
MyParser::MyParser() {}
void MyParser::Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf) {
  // If error or empty, return
  if (buf[2] == 1 || buf[2] == 0) return;
  for (uint8_t i = 7; i >= 2; i--) {
    // If empty, skip
    if (buf[i] == 0) continue;
    // If enter signal emitted, scan finished
    if (buf[i] == UHS_HID_BOOT_KEY_ENTER) {
      OnScanFinished();
    // If not, continue normally
    else {
      // If bit position not in 2, it's uppercase words
      OnKeyScanned(i > 2, buf, buf[i]);
    return;
uint8_t MyParser::KeyToAscii(bool upper, uint8_t mod, uint8_t key) {
  // Letters
  if (VALUE_WITHIN(key, 0x04, 0x1d)) {
    if (upper) return (key - 4 + 'A');
    else return (key - 4 + 'a');
  // Numbers
  else if (VALUE_WITHIN(key, 0x1e, 0x27)) {
    return ((key == UHS_HID_BOOT_KEY_ZERO) ? '0' : key - 0x1e + '1');
  return 0;
void MyParser::OnKeyScanned(bool upper, uint8_t mod, uint8_t key) {
  uint8_t ascii = KeyToAscii(upper, mod, key);
  Serial.print((char)ascii);
void MyParser::OnScanFinished() {
  Serial.println(" - Finished");
USB          Usb;
USBHub       Hub(&Usb);
HIDUniversal Hid(&Usb);
MyParser     Parser;
  Serial.begin( 115200 );
  Serial.println("Start");
  if (Usb.Init() == -1) {
    Serial.println("OSC did not start.");
  delay( 200 );
  Hid.SetReportParser(0, &Parser);
  Usb.Task();
So, I want to get the value from (char)ascii, store to char on loop and run it.
I've trying to get the value with itoa, store it to char array and still no luck. I've been stuck for days.
Any help would be appreciated.
Thank you.
Add a public function that returns the value
Hi @UKHeliBob, i tried it but still no luck. I tried this:
uint8_t MyParser::getValue() {
  uint8_t getAscii;
  bool upper; uint8_t mod; uint8_t key;
  getAscii = KeyToAscii(upper, mod, key);
  return getAscii;
and called it in loop:
  Usb.Task();
  uint8_t abcd = Parser.getValue();
  char c = (char)abcd;
  Serial.print(c);
Is there something wrong with my code? Thank you.
That is for you to tell us. Are there errors? Post the entire text of the error. The code does not do what you want? Explain what the code actually does and how that differs from what you want.
  private:
    bool keyReady;
    uint8_t scannedKey;
  public:
    MyParser();
    bool GetKey(uint8_t&);
  protected:
  scannedKey= KeyToAscii(upper, mod, key);
  keyReady = true;
//Return status indicating if there's a key available
//If not, the paremeterized value is undefined
bool MyParser::GetKey(uint8_t &key)
  if (keyReady) {
    key = scannedKey;
    keyReady = false;
    return true;
  return false;
Basically, you want to create two members variables, one to keep track if there's a key has been scanned; the other one is the key itself.
The GetKey() will return true if there's a key; and the key is copied to the argument.
   uint8_t key;
   if (Parser.GetKey(key)) {
      //use "key" here
Or you can also doing this via callback interface.
    using m_cb = void (*)(uint8_t);
  private:
    m_cb action;
  public:
    MyParser(m_cb  act);
  protected:
MyParser::MyParser(m_cb  act) : action(act)
  action(ascii); //invoke callback
.ino
void OnKeyScanned(uint8_t key)
   Serial.println(key);
MyParser     Parser(OnKeyScanned);
Hi @groundFungus thanks for replied. There are no errors but does not appear on loop.
Wow Thanks @arduino_new it worked like a charm. Thank you!
Noted!
arduino_new:
