getDate was not declared in scope
Hello! I hate to resort to this, as I'm sure it's an easy fix I'm simply overlooking, but I've scoured for a solution to this for a week now, and from my meager understanding of functions, it seems as though the function has no frame of reference for 'getDate'. I'm setting up a basic controller for a water pump, but wanted to be able to display time, referencing an RTC from the date/time it was compiled(more for aesthetics at this point)
I'm using a DS1307 and using the DS1307RTC.h library.
When I run the example library SetTime.ino -- I receive no errors -- everything compiles just fine. Leading me to believe its not anything with the library.
#include <Wire.h>
#include <TimeLib.h>
#include <DS1307RTC.h>
const char *monthName[12] = {
  "Jan", "Feb", "Mar", "Apr", "May", "Jun",
  "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
tmElements_t tm;
  bool parse=false;
  bool config=false;
  // get the date and time the compiler was run
  if (getDate(__DATE__) && getTime(__TIME__)) {
    parse = true;
    // and configure the RTC with this info
    if (RTC.write(tm)) {
      config = true;
  while (!Serial) ; // wait for Arduino Serial Monitor
  delay(200);
  if (parse && config) {
    Serial.print("DS1307 configured Time=");
    Serial.print(__TIME__);
    Serial.print(", Date=");
    Serial.println(__DATE__);
  } else if (parse) {
    Serial.println("DS1307 Communication Error :-{");
    Serial.println("Please check your circuitry");
    Serial.print("Could not parse info from the compiler, Time=\"");
    Serial.print("\", Date=\"");
    Serial.print(__DATE__);
    Serial.println("\"");
bool getTime(const char *str)
  int Hour, Min, Sec;
  if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) return false;
  tm.Hour = Hour;
  tm.Minute = Min;
  tm.Second = Sec;
  return true;
bool getDate(const char *str)
  char Month[12];
  int Day, Year;
  uint8_t monthIndex;
  if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) return false;
  for (monthIndex = 0; monthIndex < 12; monthIndex++) {
    if (strcmp(Month, monthName[monthIndex]) == 0) break;
  if (monthIndex >= 12) return false;
  tm.Day = Day;
  tm.Month = monthIndex + 1;
  tm.Year = CalendarYrToTm(Year);
  return true;
However when I try and implement this into my own project(Irrigation_controller_7) *yes another one of those), something gets lost in the transition or is being muddied up from what little code I've already placed in here. I keep getting this "'getDate' was not declared in this scope" return
pointing me to this >> if (getDate(DATE) && getTime(TIME)) {
#include <Wire.h>
#include <LCD.h>
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
tmElements_t tm;
int Relay_3 = 11;
int Relay_5 = 8;
int Relay_6 = 9;
int Relay_8 = 13;
  bool parse=false;
  bool config=false;
    parse = true;
      config = true;
  delay(200);
  } else if (parse) {
  lcd.begin(16,2);
  lcd.backlight();
  lcd.setCursor(1,0);
  lcd.print("Welcome to:");
  lcd.setCursor(0, 1);
  lcd.print("Garduino - v1.0");
  delay(3000);
  lcd.clear();
  lcd.print(" BY EDGEWOOD ");
  lcd.setCursor(0,1);
  lcd.print("~~~~~~~~~~~~~~~~");
  delay(2000);
  lcd.clear();
 pinMode(Relay_3, OUTPUT);
 pinMode(Relay_5, OUTPUT);
 pinMode(Relay_6, OUTPUT);
 pinMode(Relay_8, OUTPUT);
 pinMode(Relay_3, LOW);
 pinMode(Relay_5, LOW);
 pinMode(Relay_6, LOW);
 pinMode(Relay_8, LOW);
  pinMode(Relay_3, HIGH);
  pinMode(Relay_8, HIGH);
  int Hour, Min, Sec;
  tm.Hour = Hour;
  tm.Minute = Min;
  tm.Second = Sec;
  return true;
  char Month[12];
  int Day, Year;
  uint8_t monthIndex;
  if (sscanf(str, "%s %d %d", &Month, &Day, &Year) != 3) return false;
  tm.Day = Day;
  return true;
// Is someone pressing the rotary switch?
  if ((!digitalRead(PinSW))) {
    virtualPosition = 10;
    while (!digitalRead(PinSW))
      delay(10);
    Serial.println("Reset");
  // If the current rotary switch position has changed then update everything
  if (virtualPosition != lastCount) {
    // Write out to serial monitor the value and direction
    Serial.print(virtualPosition > lastCount ? "Up  :" : "Down:");
    Serial.println(virtualPosition);
    // Keep track of this new value
    lastCount = virtualPosition ;
Is anybody familiar with this issue? Any help is greatly appreciated
SetTime.ino (1.64 KB)
Irrigation_Controller_7.ino (2.87 KB)
Hmm... this looks funny:
  bool parse=false;
  bool config=false;
}   <-- end of setup
  lcd.begin(16,2);   <-- what's this?
This is one cause of that particular error message:
You can't declare a function inside another function.
If you cant figure out the first error, try the second error. If you can't figure that one out, try the next. If you figure out an error, fix it and compile again (it may have been the cause of other errors). If you get to a point where you can't figure out ANY of the errors, that is the time to come here to ask.
