Getkey () function doesn't work outside the void loop.
Hello everyone! I have a problem with the getkey () function used in a module that you will see in my code, is called "void programaA ()", it does not take any value that I press on the keyboard, in the "void loop" it works, what could be the problem? link to the complete code: Arduino Cloud
Rather than linking, just post or attach your code.
I cant, when i try to post it i get this massage "The message exceeds the maximum allowed length (9000 characters)."
There is an attach option when you use reply.
Getkey is in the loop in the code you posted... post the code that does NOT work...
Print salir and some trace to see if you ever reach that while loop
