getKey keypad entry not detected when moved out of void loop
Hello all,
A rotary encoder displays a simple Lcd menu with 7 menu items.
For each menu item I need to be able to change the value of the associated variable (DropSize, NumberOf Drops, etc) using the keypad.
The various menu items are displayed in menuDisplay(). Currently the routine 1 works and accepts a keypad entry. However, I need to move this working section ( getKey(), enterNewNumber() and getNumber() from the void loop into the menuDisplay() so that it accepts a keypad entry for each of the different menu items,
When I move the working segment into a menu itme within menuDisplay() keypad entry is no longer detected. Thanks in advance for any advice.
Woking routine 1
void loop(){// open void
  if (fired) // if ISR has triggered calls Rotary Encoder routine
  {// open if
    menuDisplay();// Display menu options on LCD
    fired = false;
  }// close if
  // -------end of encoder
  [color=blue]char key = getKey();// this routine will be used to change all integer variables like
  // DropSize, FlashDelay, Number of drops etc
  [color=green][font=Verdana]if(key != 0) // Do nothing if no key is pressed.
  {// open first if
    switch (key)
    {// open switch key
    case '#':
      enterNewNumber();
      getNumber(0,1,rotaryCount);
    }// close switch
  }// close first if[/font][/color]
}[/color]// close void loop returns with the key pressed, or 0 if no key is pressed
The Serial output for the above working code is shown below. Comments and user input are shown between < >.
Serial output for working routine 1
Drop Control Menu
Turn Knob for
Menu options
Inside menuDisplay()          < knob turned to menu "number of drops">
Number of drops   0
            rotaryCount = 0
Row cleared
enterNewNumber()
Before calling getNumber()
inside getNumber
currentKeyIn = 1          < 5 on keypad pressed>
num = 5
currentKeyIn = 2          < 6 on keypad pressed>
num = 56
currentKeyIn = 0
Row cleared
New number = 56
A = Save to EEPROM
Here is the code where the getKey() and getNumber() are moved from the void loop to the menuDisplay(). The keypad entry is not detected.
void menuDisplay() { // Displays LCD Menu options when rotary encoder is moved
  // Called from within void loop
  Serial.println("Inside menuDisplay() ");// testing
  rotaryCount = constrain(rotaryCount, 0, Number_of_Menu_Items);// if rotary count is > 7 back to 0.
  if (rotaryCount>=Number_of_Menu_Items)
  {// open if
    rotaryCount=0; // loop menu to first item on menu
  }// close if
  initialiseLcd();// clear and set cursor home
 char key = 0;
  switch(rotaryCount)
  {// used for displaying Menu items and variable value.
  case S_number_Of_Drops:
    displayNumber_Of_Drops(); //
      key = getKey();//
  {// open first if
    switch (key)
    {// open switch key
    case '#':
      enterNewNumber();// on lcd print  "enter new number"
      getNumber(0,1);// gets two char entry and convert to an integer
    }// close switch
  }// close first if
  case S_dropSize:  //
    displayDrop_Size();
         key = getKey();//
  {// open first if
    switch (key)
    {// open switch key
    case '#':
    }// close switch
  }// close first if
Here is the Serial output for the above code which is not working. No keypad entry is detected.
Set up started
Drop Control Menu
Turn Knob for
Menu options
Inside menuDisplay()    < rotary encoder knob move to "Number of Drops" menu item.
Number of drops   0
            rotaryCount = 0
Inside getKey()
keypressed        <nothing happens when any key is pressed>
Here is the working getNumber() segment.
int getNumber(byte lcdCol, byte lcdRow)// lcdCol and LcdRow are located in getNumber(10,1)
called from get Key()
getNumber() is used to change the variables like DropSize, NumberOfShots FlashDelay etc.
 From the keypad entry it creates a 1-3 digit number which will be stored in EEPROM.
{// open getNumber
  Serial.println("inside getNumber");
  unsigned int num = 0;
  lcd.setCursor(lcdCol, lcdRow);  //put the cursor to (0,1)
  while(key != '#')// # is the start of keypad entry key
  {// open while
    switch (key)
    {// open switch
    case '0':
    case '1':
    case '2':
    case '3':
    case '4':
    case '5':
    case '6':
    case '7':
    case '8':
    case '9':
      Data[currentKeyIn++]= key;// each digit entry is stored in array
      lcd.print(key);// print key
      num = num * 10 + (key - '0');// converts char key entry to integer
      Serial.print("currentKeyIn = ");
      Serial.println(currentKeyIn);
      Serial.print("num = ");
      Serial.println(num);// test to see if correct integer has been entered
    case 'D'://backspace to beginning of number to change digits over write and then press '*'
      Data[currentKeyIn--]= key;
      cursorPosition = currentKeyIn;
      lcd.setCursor(cursorPosition, lcdRow);
      num = 0;
      lcd.blink();   // blinks over last digit entered.
    case '*':// signals end of input
      while(currentKeyIn !=0)
        Data[currentKeyIn--] = 0; //clear for new data
      Serial.println(currentKeyIn);// working = 0
      lcd.noBlink();
      lcd.setCursor(0,3);
      clearLcdRow();// clears "Enter new number
      strcpy_P(buffer_a, (char*)pgm_read_word(&(Menu_List[9]))); // "A = Save to EEPROM"
      lcd.setCursor(0,3);//
      lcd.print(buffer_a);
      Serial.println(buffer_a);
      return num;// required otherwise rotary encoder does not work.
    }// close switch
    key = getKey();// *****required here otherwise no response to keypad
  }// close while
  Serial.println("end of getNumber()");
}// close getNumber()
Here is the working getChar() segment.
char getKey()
  char key = 0;                                  // 0 indicates no key pressed
  for(int column = 0; column < numCols; column++)
    digitalWrite(colPins[column],LOW);         // Activate the current column.
    for(int row = 0; row < numRows; row++)     // Scan all rows for  a key press.
      if(digitalRead(rowPins[row]) == LOW)     // Is a key pressed?
        delay(debounceTime);                   // debounce
        while(digitalRead(rowPins[row]) == LOW);
        // wait for key to be released
        key = keymap[row][column];             // Remember which key was pressed.
    digitalWrite(colPins[column],HIGH);     // De-activate the current column.
  return key;  // returns the key pressed or 0 if none
  Serial.print("key pressed");
  Serial.println(key);
  {                           // open if
    menuDisplay();      // Display menu options on LCD
    fired = false;
  }                           // close if
Looks like menuDisplay() is only called when the knob is turned. If you put the keyboard checking inside menuDisplay() it will only work when the knob is moved. Having it in loop() was the right thing to do.
Thanks John.
