getSerial not declared in this scope - discrepancies, or overlook?
Hello all,
In the code below I am getting an error, when compiling, telling me that getSerial was not declared in this scope void loop().
#include <Servo.h>
unsigned long serialdata;
int inbyte;
int digitalState;
int pinNumber;
int analogRate;
int servoPin;
int pos = 70;
int time = 0;
Servo megaservos;
  getSerial();
  switch(serialdata)
  case 1:
      //Decide to use Vacuum or Positive Pressure
      getSerial();
      switch(serialdata)
      case 1:
          //Turn on Vacuum
          getSerial();
          pinNumber = serialdata;
          getSerial();
          digitalState = serialdata;
          pinMode(pinNumber, OUTPUT);
          if (digitalState == 0)
            digitalWrite(pinNumber, LOW);
          if (digitalState == 1)
            digitalWrite(pinNumber, HIGH);
          pinNumber = 0;
      case 2:
          //Turn on Positive Pressure
          getSerial();
          getSerial();
          pinNumber = 0;
   case 2:
   //Raise or drop arm
   getSerial();
   switch(serialdata)
     case 1:
       //Raise arm
       getSerial();
       servoPin = serialdata;
       megaservos.attach(servoPin);
       if(pos >= 1)
         pos -= 1;
         megaservos.write(pos);
         delay(15);
     case 2:
       //Drop arm
       getSerial();
       if(pos <= 70)
         pos += 1;
         delay(15);
long getSerial()
  serialdata = 0;
  while (inbyte != '/')
    inbyte = Serial.read();
    if (inbyte > 0 && inbyte != '/')
      serialdata = serialdata * 10 + inbyte - '0';
  inbyte = 0;
  return serialdata;
However, when I run this code, which is structured similarly, I do not get the error message.
#include <Servo.h>
int inbyte;
int servoPose;
int servoPoses[80] = {};
int attachedServos[80] = {};
int servoPin;
int pinNumber;
int sensorVal;
int analogRate;
int digitalState;
Servo myservo[] = {};
  getSerial();
  switch(serialdata)
  case 1:
      //analog digital write
      getSerial();
      switch (serialdata)
      case 1:
          //analog write
          getSerial();
          getSerial();
          analogRate = serialdata;
          analogWrite(pinNumber, analogRate);
          pinNumber = 0;
      case 2:
          //digital write
          getSerial();
          getSerial();
          if (digitalState == 2)
          pinNumber = 0;
    case 2:
      getSerial();
      switch (serialdata)
      case 1:
          //analog read
          getSerial();
          pinMode(pinNumber, INPUT);
          sensorVal = analogRead(pinNumber);
          Serial.println(sensorVal);
          sensorVal = 0;
          pinNumber = 0;
      case 2:
          //digital read
          getSerial();
          sensorVal = digitalRead(pinNumber);
          sensorVal = 0;
          pinNumber = 0;
    case 3:
      getSerial();
      switch (serialdata)
        case 1:
           //servo read
           getSerial();
           Serial.println(servoPoses[servoPin]);
        case 2:
           //servo write
           getSerial();
           getSerial();
           servoPose = serialdata;
           if (attachedServos[servoPin] == 1)
             myservo[servoPin].write(servoPose);
           if (attachedServos[servoPin] == 0)
             Servo s1;
             myservo[servoPin] = s1;
             myservo[servoPin].attach(servoPin);
             attachedServos[servoPin] = 1;
           servoPoses[servoPin] = servoPose;
        case 3:
          //detach
          getSerial();
            myservo[servoPin].detach();
            attachedServos[servoPin] = 0;
long getSerial()
  serialdata = 0;
  inbyte = 0;
  return serialdata;
Could anyone provide some insight as to why this is happening and a potential fix? Is this an anomaly or have I overlooked something in the top code? I've looked through and compared them several times and can't seem to find a problem...may just need a new set of eyes to look at it.
Thanks
Look at the last two lines of each case.
Not structured similarly!
You declare getSerial inside the loop.
Yes I just found that on my own! Was about to update the thread.
Overlooking the placement of a } happens sometimes...Oh the intricacies of programming
Thanks for looking through it!
