Getting 3.3v out of Arduino Pro-Mini 5v 16mhz
Hello all,
I have recently purchased a 5v Pro-Mini to create a smaller version of a already designed circuit
which used the UNO.
A problem I just notices is that there is no 3.3v pin on the Mini as there is on the UNO, this only
causes a problem when powering my Nokia 5110 screen and to power the my level shifter that
converts my 5v logic to 3,3v for the inputs of the screen.
So I am turning here for some ideas of how I can get around this problem.
For now I am using the 3,3v that is supplied form the USB program loader that came with the
Mini.
Thank you for the help in advanced.
I will provide additional information if needed.
Add a separate 3.3V regulator.
The promini 5V regulator is only good for 150mA, so I wouldn't use 5V from the Vcc pin to power the 3.3V regulator.
So your saying to use a separate power supply connected to a 3.3v regulator to power my screen?
Use the same supply that powers the Promini, connect them up in parallel.
Yes.
Use a 3.3V regulator from the 5V on the USB connector or better on a Wall Wart or batteries. Depending how your final project will be powered.
OH I see what your saying now.
Any suggestions for a regulator I should use from your experiences?
Also I appreciate it thank you steinie44 and CrossRoads.
Just google the words
3V3 regulator
For lots of options where you live.
Part Number of 3.3V Regulator in UNO
LP2985-33DBVR
http://ca.mouser.com/ProductDetail/Texas-Instruments/LP2985-33DBVR/?qs=sGAEpiMZZMsGz1a6aV8DcCOj5hh%2FNjhX4p6toGEueJ8%3D
