Getting 3x4 Keypad to work with Duemilanove
So I'm a total nood and I can't find anything on how to connect the keypad to my arduino, so I can get a servo to run when the right pass code is entered but first i need to figure out how to hook it up. it only has 7 connection points and all the diagrams I can find have 14 of are how to connect it to a diecimila. Can anyone help me please? :-/
Which keypad do you have?
http://www.sparkfun.com/commerce/product_info.php?products_id=8653
From the comments on that item:
Looking at the top of the board, the pinout from left to right is: No connection Column 1 Row 0 Column 0 Row 3 Column 2 Row 2 Row 1 No connection
I'm lost as to what any of that means.... sorry I'm a n00b
I posted a tutorial for this on the playground. http://www.arduino.cc/playground/Main/KeypadTutorial
It tells you how to identify your pins/columns/rows and provides an example sketch.
If you need extra help you'll find my email address at the top of the Keypad.cpp file when you download the keypad library.
-Mark
Sadly that does not help me AT ALL, I only have 9 "holes"/connections not 14 or whatever, I can't get it to work, has anyone done this? Pictures? PLEASE?
Connect a Spark Fun Keypad to an Arduino
Keypad Designator Arduino
Pin # Pin #
1 Col1 12
2 Row0 11
3 Col0 10
4 Row3 9
5 Col2 8
6 Row2 7
7 Row1 6
With that information at hand you should connect keypad pin 1 to Arduino pin 12 and so on down the list. (You can choose different Arduino pins if you prefer.)
If you have the keypad library properly installed then use the HelloKeypad example to test your setup. Follow the menus File->Examples->Keypad->Examples->HelloKeypad to load the sketch. Using the list of Arduino pin numbers from above change rowPins and colPins to match. The pins must be entered in order from Row0 to Row3 and Col0 to Col2.
Example: rowPins[4] = {11, 6, 7, 9};
This means pin 11 = Row0, pin 6 = Row1, pin 7 = Row2 and pin 9 = Row3. The same is true for colPins.
Mark Stanley
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
      {'1','2','3'},
      {'4','5','6'},
      {'7','8','9'},
      {'*','0','#'}
byte rowPins[ROWS] = {11, 6, 7, 9}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {10, 12, 8}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
void loop(){
      char key = keypad.getKey();
      if (key != NO_KEY){
            Serial.println(key);
mstanley:
Beautiful job of explaining things!
