Hi All,
I was trying to port a LED matrix project meant for arduino device made by bennyd93 from github, to an ESP32. After trying to upload the code to the ESP32, I received this error saying that CRGB can't be converted into the data i wanted to read. i was facing the error of 'no matching function for call to 'fs::File::read(uint8_t*, int)' ' at the below part of the code (Full code at the bottom most of the post). I was wondering what is causing CRGB to be unreadable since its a structure of 3 uint8_t values (correct me if i am wrong). Help to assist me with the understanding will be very much appreciated, thank you.
void readNextStep(File *file)
uint8_t numColors;
file->read(&numColors, 2);
bytesRead += 2;
for (int i = 0; i < numColors; i++)
CRGB color;
uint8_t num_leds;
file->read(&color, 3);
bytesRead+= 3;
file->read(&num_leds, 2);
bytesRead += 2;
uint8_t led_idx;
for (int j = 0; j < num_leds; j++)
file->read(&led_idx, 2);
bytesRead += 2;
set_led(led_idx, CRGB(color.r / BRIGHTNESS_DIVIDER, color.g / BRIGHTNESS_DIVIDER, color.b / BRIGHTNESS_DIVIDER));
/* Written guide by bennyd93 (bennyd93 · GitHub): Natural-Nerd/readme.md at master · hansjny/Natural-Nerd · GitHub /
#include <SPI.h>
#include <SD.h>
#include <FastLED.h>
#define DATA_PIN 6
#define BUTTON_PIN 2
/ If LEDS_PER_SECTION is 1, the number of sections is your amount of LEDs /
#define ROWS 24
/ LED PIN /
#define LEDS_PER_ROW 30
#define NUM_LEDS LEDS_PER_ROWROWS
#define BRIGHTNESS_DIVIDER 3
//The CS pin on the SDCARD
#define CHIP_SELECT 53
CRGB leds[NUM_LEDS];
uint8_t stepsInAnimation = 0;
uint8_t currentStep = 1;
uint16_t bytesRead = 0;
File root;
File readFile;
volatile bool change_animation = false;
unsigned long last_interrupt;
char fname[12];
bool selectFile() {
File entry = root.openNextFile();
while(!entry) {
root.rewindDirectory();
entry.close();
bool found = false;
memcpy(&fname, entry.name(), strlen(entry.name()) + 1);
if (fname[strlen(fname) - 1] == 'N' && fname[strlen(fname) - 2] == 'I' && fname[strlen(fname) - 3] == 'B' && fname[strlen(fname) - 4] == '.') {
found = true;
entry.close();
return found;
void find_new_animation() {
int i = 0;
while(!selectFile()) {
if (i++ == 100) {
//This is ugly. It's here so it tries a few times before giving up.
readFile.close();
readFile = SD.open(fname);
bytesRead = 0;
animationInit(readFile);
void button_click()
if (millis() - last_interrupt > 250) {
last_interrupt = millis();
change_animation = true;
uint8_t numColors;
bytesRead += 2;
CRGB color;
uint8_t num_leds;
bytesRead+= 3;
bytesRead += 2;
uint8_t led_idx;
bytesRead += 2;
void animationInit(File dataFile) {
if (dataFile)
if (dataFile.available())
dataFile.read(&stepsInAnimation, 1);
bytesRead++;
readNextStep(&dataFile);
void led_clear()
for (int i = 0; i < NUM_LEDS; i++)
leds[i] = CRGB(0, 0, 0);
void set_led(uint16_t i, CRGB color) {
uint8_t x;
uint8_t y;
y = (ROWS - 1) - (i / LEDS_PER_ROW);
x = i % LEDS_PER_ROW;
if (y % 2 == 0)
leds[y * LEDS_PER_ROW + x] = color;
leds[y * LEDS_PER_ROW + (LEDS_PER_ROW - 1) - x] = color;
FastLED.addLeds<WS2812, DATA_PIN, GRB>(leds, NUM_LEDS);
leds[0] = CRGB(255, 255, 255);
while (!SD.begin(CHIP_SELECT))
root = SD.open("/");
find_new_animation();
pinMode(BUTTON_PIN, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(BUTTON_PIN), button_click, FALLING);
void readNext(File f)
//Start from beginning
if (currentStep >= stepsInAnimation)
f.seek(1);
currentStep = 1;
bytesRead = 1;
currentStep++;
readNextStep(&f);
if (change_animation) {
led_clear();
readNext(readFile);
FastLED.show();
delay(100);
