Getting a "expected primary-expression before 'float'"
Hi everyone!
I'm getting a "expected primary-expression before 'float'" message,
What does it mean by "primary expression?" The line in question is calling a function in a header file, which gives me a feeling of uncertainty and cloudy incomprehension.
any ideas?
  metervoltage = analogRead(meterpin);
  doublemetervoltage = 2 * metervoltage;
  digitalcoeff = (5 / 1023);
  flowrate = 0.00488759 * doublemetervoltage; // 0.00488759=digitalcoeff;
dac_voltage = flowrate;
LTC2664_voltage_to_code(dac_voltage, float min_output, float max_output);
LTC2664_write(LTC2664_CS, LTC2664_CMD_WRITE_ALL_UPDATE_ALL, 0, dac_voltage);
Remove the float from
If you need to cast because the function expects floats, put braces around the float
LTC2664_voltage_to_code(dac_voltage, (float)min_output, (float)max_output);
If you get compiler warnings or errors after that, post your complete code. We have no idea what the types of the variables are or what your functions expect as parameters.
I'm trying to call a function in a header file using this line:
and I have no idea what a "primary-expression" is, or what it is reffering to. any ideas?
Thanks,
Justin
If you're trying to cast min_output and max_output as floats, it needs to read as (float) min_output ...
You already had an answer in Getting a "expected primary-expression before 'float'" - Programming Questions - Arduino Forum.
Don't double post !!
Thanks everyone, for the help. Still learning stuff.
This is for a DAC, and it gets complicated very fast.
