Getting a LCD to work
Probably I'm making a little mistake, but I can't get my parallel LCD to work. I see some blocks, but that's about it. First I thought the wiring was the problem since I didn't solder anything. But also after soldering I still can't get it to work.
I connected my AnagVision AV1610 (16x1), KS0066 driver, as follow:
pin1(Vss) -> ground
pin2(Vdd) -> Arduino 5 volt
pin3(conrast) -> ground
pin4(RS) -> Arduino dig pin 7
pin5(RW) -> ground
pin6(ENAB) -> Arduino dig pin 6
pin7,8,9,10 -> Ground (?? should I do that?)
pin11,12,13,14 -> Arduino dig pin 2,3,4,5 (also tried it reversed)
pin15(Backlight+) -> Arduino 5 Volt
pin16(Backlight-) -> Ground
I used the LCD4bit "fruit" example and changed the LCD4bit.cpp file:
RS = 7
ENAB = 6
RW = 8 // not used
int DB[] = {2,3,4,5};
When I power up, all I see is 8 blocks. However, if I remove the unused datapins 1..4 from the ground I do see some strange characters being written every x seconds...
What could it be? Bad configuration? Wiring wrong? Or maybe my soldering(the first time I did soldering)? The LCD is soldered to a male header and placed in a breadboard. Not superb quality, but at least the soldering does not make multiple pins contact to each other.
Any ideas?
Rick
Try this, its the easiest method I've come across, the same wiring also works with the standard LiquidCrystal library. I'd use the supplied sketch for starters.
http://www.skpang.co.uk/content/view/29/42/
Now that's a clear example, thanks for the link! And it works like a charm now. I was affraid I messed up with my first-time-attempt to solder (with a too large 30W tool). It didn't work because the contrast was connected to the ground. Once I placed a potmeter like the example shows the text became visible. Every tutorial warns about this, but I just thought the blocks wouldn't be visible either if the contrast was 0. Doh!
Thanks
