So this should be simple. I have a tea maker. It's not Alexa enabled. Fine I thought. I'll grab a NodeMCU, use the Sinric service and hey presto I can simulate a touch event.
Found some nice videos of people using the same setup to trigger the calculator on/off on an iPhone.
So I rigged it up.
D0 pin on the nodemcu goes to a short wire with a crocodile clip. Thats connected to a 9mm square battery connector so it has a good contact area.
the code is as follows
digitalWrite(D0,LOW);
pinMode(D0, INPUT);
pinMode(D0, OUTPUT);
}/code]
When I load the sketch and hold the metal against a button on the iPhone calculator the button lights up. So I know ground is working and triggering the capacitive screen. But it never changes. What I need is for the capacitive switch to go on and off. In the present configuration it seems the switch is always on. What am I doing wrong. I can seem to figure it
