Hi all,
I'm working on a project where an arduino is sent a JSON message that contains two fields - the angle the servo should move to, and the time it should take to get there.
I have the JSON Decoding bit working, but for some reason I can't work out the "move over this amount of time" bit.
My code is as follows:
// Receive message as {"angle": "123", "duration": "5"}
// Angle is degrees to point to, duration is time in seconds to get there
void callback(char* topic, byte* payload, unsigned int length) {
StaticJsonDocument<256> doc;
deserializeJson(doc, payload, length);
JsonVariant new_angle_tmp = doc["angle"];
int new_angle = new_angle_tmp.as<int>();
int duration = doc["duration"];
// Is the new angle greater than the current angle?
// If so, increase the current angle until we reach the target position.
if (new_angle > current_angle){
// Work out the delay by multiplying the duration by 1000 to
// turn it into seconds, then divide that by the number of
// degrees that we need to move to get the delay between each step
int step_delay = (duration * 1000) / (new_angle - current_angle);
if (step_delay < 1){
step_delay = 15;
Serial.print(new_angle);
Serial.print(" is greater than ");
Serial.print(current_angle);
Serial.println(" - Increasing current angle");
while( new_angle > current_angle){
current_angle = current_angle + 1;
servo.write(current_angle);
delay(step_delay);
// The new angle is less than the current angle, so
// we do the same as above, but this time we decrease until we
// reach the target position.
else if (new_angle < current_angle){
int step_delay = (duration * 1000) / (current_angle - new_angle);
step_delay = 15;
Serial.println(step_delay);
Serial.print(" is less than ");
Serial.println(" - Decreasing current angle");
current_angle = current_angle - 1;
delay(step_delay);
// If we've got this far, then the angle sent is
// the same as the angle we're currently pointing at,
// so we don't need to do anything
else {
Serial.println("No need to rotate");
I'm sure this is a really simple fix, I've just been banging my head against the wall for a good few hours trying to work out why it always moves at the same speed, and why the "decrease" side of things doesn't move it at all!
