Getting a SIm7600CE-T/Uno to make a call
Hi, I am attempting to make a phone call via a Sim7600CE-T/Uno with a Tmobile Sim Card which according to their IMEI check is compatible. Unfortunately the board doesn't seem to connect and the ATD command just gives me NO CARRIER. I am running the code at [SIM7600CE-T](SIM7600CE-T_4G(LTE)_Shield_V1.0_SKU_TEL0124-DFRobot).
Here is some output from the Serial Monitor. Can you clue me in on what should be my next step?
RDY
[CPIN: READY
SMS DONE
PB DONE
AT
OK
AT+CREG
OK
AT+CREG?
+CREG: 0,2
OK
AT+COPS=?
+COPS: (3\"Verizon","⸮erizon","311480",7),,(0\1,2,3,4,5)\(0,1,2)
AT+COPS=?
+C⸮PS: (3,"Verizon","Veriyon","311480B,7),,(0,1,2,3,4,5),(0,1,2)
AT+CPIN?
+C⸮IN: READY
OK
That’s a nice story.
Let’s see your code in , hopefully we can see something on there.
The typos in the responses tell me there’s something wrong in your comms with the modem.
This is the code
#include <SoftwareSerial.h>
SoftwareSerial myserial(7, 8); //Define virtual serial port name as myseria,Rx is port 7, Tx is port 8
  myserial.begin(115200); //Initialize virtual serial port
  Serial.begin(115200); //Initialize Arduino default serial port
  while(1){
  while (myserial.available()) {
    Serial.write(myserial.read());//if Serial received data, output it via mySerial.
  while(Serial.available()) {
    myserial.write(Serial.read());//if myserial received data, output it via Serial.
It is from the page in the link on the original post. The product info is also there. The Serial monitor is set to the same baudrate as the code.
Easy answer… SoftwareSerial will never be reliable above 9600 bps
Best to move up to a MEGA or similar with extra hardware serial UARTs.
Good luck.
