getting a skid steer tank working
so we have this robot at work for cleaning ducting, and the chinese thing has the worst control ever!!
i picked up an Leonardo to replace the main control board
ive drummed up a some code to test
const int LMR = 2;
const int LMS = 3;
const int RMR = 4;
const int RMS = 5;
const int Xdeadzone = 25, Ydeadzone = 25;
  pinMode(LMR, OUTPUT);
  pinMode(LMS, OUTPUT);
  pinMode(RMR, OUTPUT);
  pinMode(RMS, OUTPUT);
  int X = analogRead(A0);
  int Y = analogRead(A3);
  int Xspeedf = map(X, 500, 650, 0, 255);
  int Yspeedf = map(Y, 500, 650, 0, 255);
  if (X >= (500 + Xdeadzone))//Forward
    if(Y > (500 + Ydeadzone)) //Left
      analogWrite(LMS, Xspeedf - Yspeedf); analogWrite(RMS, Xspeedf);
      //digitalWrite(LMR, LOW); digitalWrite(RMR, LOW);
    else if (Y < (500 - Ydeadzone)) //Right
      analogWrite(LMS, Xspeedf); analogWrite(RMS, Xspeedf - Yspeedf);
      analogWrite(LMS, Xspeedf); analogWrite(RMS, Xspeedf);
    { // Full stop
      analogWrite(LMS,0);
      analogWrite(RMS,0);
      digitalWrite(LMR,LOW);
      digitalWrite(RMR,LOW);
  Serial.println(X);
  Serial.println(Xspeedf);
  Serial.println(LMS);
  Serial.println(RMS);
  delay(100);
so far on the monitor can read the joystick and the associated PWM (xspeedf), but the motor outputs (LMS RMS) just stay as the pins they’re supposed to be assigned to
where am i going wrong here
I see two statements on the one line. Lines are cheap. Use more of them.
What do you mean "just stay as the pins they're supposed to be assigned to"?
const int LMR = 2;
const int LMS = 3;
const int RMR = 4;
const int RMS = 5;
Of these pins only 3 & 5 are analogue.
MorganS:
when viewing the serial monitor, the values for the joystick input and the PWM adjustment change, but the output pins just say 3 & 5
Yes, you're printing the pin numbers, not what was written to the pin with analogWrite().
You need at least 2 more variables to record the output of your calculation (Xspeedf - Yspeedf) so that this can be used in the analogWrite() and in the Serial.print().
const int LMS = 3;
const int RMS = 5;
Yes, it should print 3 and 5. That's what you told it to print. LMS you set to 3. You even made it const so you know it never changes. Same with RMS except you told the compiler that it would have the value 5.
