Getting a static IP for Arduino Ethernet Shield
I’ve spent a few days trying to figure out how to get basic Ethernet sketches-say the WebServer sketch (attached) to get beyond the LAN. I have no real experience with the inner workings of the net. I’ve learned a bit about port forwarding, and set my cisco linksys to an 8085 port, but I can’t find a thread or tutorial that walks one through the method of getting your server tied to a static address. I know my MAC and the shield’s IP, etc. I can get any of the basic Ethernet sketches to work LAN-wide, but that’s it. In short, assuming that I’ve set the port forwarding up correctly:
  1. How do I go about getting a static IP or some other method that gets to the server from anywhere? (I’e seen some references to where you add the port # to the end of the IP, such as xx.xxx.xx.:port number. At least that’s how I understand it.)
  2. How do I integrate it into the sketch?
Also, I’ve read that the SD reader on these shields are crap. I’ve had no luck with any sketches that involve pulling data up from an SD card, so it appears that’s the case with mine. The serial port acknowledges the card being initialized, but can’t find the file.
Here’s the server sketch:
Program: eth_websrv_page
Description: Arduino web server that serves up a basic web
page. Does not use the SD card.
Hardware: Arduino Uno and official Arduino Ethernet
shield. Should work with other Arduinos and
compatible Ethernet shields.
Software: Developed using Arduino 1.0.3 software
Should be compatible with Arduino 1.0 +
References: - WebServer example by David A. Mellis and
modified by Tom Igoe
Date: 7 January 2013
Author: W.A. Smith, http://startingelectronics.org
#include <SPI.h>
#include <Ethernet.h>
// MAC address from Ethernet shield sticker under board
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 101); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == ‘\n’ && currentLineIsBlank) {
// send a standard http response header
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
client.println(“Connection: close”);
client.println();
// send web page
client.println("");
client.println("");
client.println("");
client.println(“Arduino Web Page”);
client.println("");
client.println("");
client.println(“
Hello from Arduino! Happy Valentine’s Day!!!
client.println(“
A web page from the Arduino server. I’m excited about getting on the journey to understanding how the net works.
client.println("");
client.println("");
// every line of text received from the client ends with \r\n
if (c == ‘\n’) {
// last character on line of received text
// starting new line with next character read
else if (c != ‘\r’) {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
The sd card slot works good.
  1. How do I go about getting a static IP or some other method that gets to the server from anywhere? (I'e seen some references to where you add the port # to the end of the IP, such as xx.xxx.xx.:port number. At least that's how I understand it.)
To get an internet static IP address, contact your ISP. You will probably have to pay extra for that. Most people use a dynamic IP service such as www.noip.com to forward traffic to your current internet IP address. You put your dynamic ip address url in your web page so the browser request get routed properly.
Also, I've read that the SD reader on these shields are crap. I've had no luck with any sketches that involve pulling data up from an SD card, so it appears that's the case with mine. The serial port acknowledges the card being initialized, but can't find the file.
The SD card slot on the w5100 based ethernet cards work well for me. Also #7 below for posting code:
http://forum.arduino.cc/index.php/topic,148850.0.html
Thanks for the reply. Sorry I'm so ignorant of this stuff. I took your suggestion and went to noip.com. I got a xxxxxx.ddns.net host. From there, I don't know what to do. When I enter that, it directs me to my router settings. I assume getting it to where the server sketch pushed to the host involve a correct port orientation. For the port number I assigned in the sketch and in the port forwarding page of the Cisco router settings 8085. Beyond that, I'm lost.
Below is some simple arduino server code that shows how to put a no-ip URL into a web page
//zoomkat 04-10-15
//simple button GET with iframe code
//open serial monitor to see what the arduino receives
//use the ' instead of " in html ilnes
//address will look like http://192.168.1.102:84/ when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //ethernet shield mac address
byte ip[] = {
  192, 168, 1, 102 }; // arduino IP in lan
byte gateway[] = {
  192, 168, 1, 1 }; // internet access via router
byte subnet[] = {
  255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(4, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  //enable serial data print
  Serial.println("server test no-ip 04-10-15"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
            //now output HTML data header
          if(readString.indexOf('?') >=0) { //don't send new page
            client.println("HTTP/1.1 204 Zoomkat\r\n\r\n");
          else {
            client.println("HTTP/1.1 200 OK"); //send new page
            client.println("Content-Type: text/html");
            client.println();
            client.println("<HTML>");
            client.println("<HEAD>");
            client.println("<TITLE>Arduino GET test page</TITLE>");
            client.println("</HEAD>");
            client.println("<BODY>");
            client.println("<H1>Zoomkat's simple Arduino button</H1>");
            client.println("Arduino served LAN: <a href='/?on1' target='inlineframe'>ON</a>");
            client.println("<a href='/?off' target='inlineframe'>OFF</a>
            client.println("Remote served LAN: <a href='http://192.168.1.102:84/?on1' target='inlineframe'>ON</a>");
            client.println("<a href='http://192.168.1.102:84/?off' target='inlineframe'>OFF</a>
            client.println("Remote served no-ip: <a href='http://zoomkat.no-ip.org:84/?on1' target='inlineframe'>ON</a>");
            client.println("<a href='http://zoomkat.no-ip.org:84/?off' target='inlineframe'>OFF</a>");
            client.println("<IFRAME name=inlineframe style='display:none'>");
            client.println("</IFRAME>");
            client.println("</BODY>");
            client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on1") >0)//checks for on
            digitalWrite(4, HIGH);    // set pin 4 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            digitalWrite(4, LOW);    // set pin 4 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
Great! It works!
The only thing that’s now holding me back on the shield is that the SD will initialize by the file can’t be found. It’s a basic server with SD starter program. I’ve looked on forums and followed advice to format the card, make sure it was FAT-32, make sure that the card was set for pin 4, etc, but the serial monitor keeps saying that it initializes but “file not found”.
The test file was a standard hello:
Arduino SD Card Web Page
Hello from the Arduino SD Card!
A web page from the Arduino SD card server.
The sketch is:
Program: eth_websrv_SD
page. The web page is stored on the SD card.
2Gb micro SD card formatted FAT16
SD card contains web page called index.htm
Date: 10 January 2013
#include <SPI.h>
#include <SD.h>
byte mac = { 0x90, 0xA2, 0xDA, 0x0D, 0xA8, 0x6B };
EthernetServer server(8081); // create a server at port 80
File webFile;
Serial.begin(9600); // for debugging
// initialize SD card
Serial.println(“Initializing SD card…”);
if (!SD.begin(4)) {
Serial.println(“ERROR - SD card initialization failed!”);
return; // init failed
Serial.println(“SUCCESS - SD card initialized.”);
// check for index.htm file
if (!SD.exists(“index.htm”)) {
Serial.println(“ERROR - Can’t find index.htm file!”);
return; // can’t find index file
Serial.println(“SUCCESS - Found index.htm file.”);
client.println();
// send web page
webFile = SD.open(“index.htm”); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
if (c == ‘\n’) {
The below post has code and attach files that show how to embed SD files in a web page. I always put files on the SD card using the SD slot in my net pad.
http://forum.arduino.cc/index.php?topic=279849.msg1970392#msg1970392
