Hi everyone,
I'm working with Arduino GPS project and I want to derive NMEA data from NEO M8N GPS module via Arduino NANO. So I used following simple sketch and it is working correctly.
But the problem is when I am using USB communication, GPS can send additional NMEA messages(GxDTM, GxDBS, GxGNS, GxGRS and etc. ) and PUBX messages as well. Those can be enable or disable as user wish via u-center but valuable data can be derive from those massages via u-center software. But when communicating via UART its always sending GGA GLL RMC VTG GSV GSA messages only. Also it cannot able to working with high navigation rates such as 2Hz, 3Hz. But USB connection is giving all information in higher navigation rate also.
How can I getting all NMEA massages from UART as well. Because I want to connect GPS via Arduino and getting some results. USB connection cannot connecting with Arduino NANO. So I need your help to solve this problem.
Thank You.
The NeoGPS library has an example of requesting, receiving and processing PUBX messages
#include <NeoGPS_cfg.h>
#include <ublox/ubxNMEA.h>
// Program: PUBX.ino
// Description: This program parses NMEA proprietary messages from
// ublox devices. It is an extension of NMEA.ino.
// Prerequisites:
// 1) You have a ublox GPS device
// 2) NMEA.ino works with your device
// 3) You have installed ubxNMEA.H and ubxNMEA.CPP
// 4) At least one NMEA standard or proprietary sentence has been enabled.
// 5) Implicit Merging is disabled.
// Serial is for debug output to the Serial Monitor window.
// License:
// Copyright (C) 2014-2017, SlashDevin
// This file is part of NeoGPS
// NeoGPS is free software: you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation, either version 3 of the License, or
// (at your option) any later version.
// NeoGPS is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with NeoGPS. If not, see <http://www.gnu.org/licenses/>.
#include <GPSport.h>
#include <Streamers.h>
// Check that the config files are set up properly
#if !defined( NMEAGPS_PARSE_GGA ) & !defined( NMEAGPS_PARSE_GLL ) & \
!defined( NMEAGPS_PARSE_GSA ) & !defined( NMEAGPS_PARSE_GSV ) & \
!defined( NMEAGPS_PARSE_RMC ) & !defined( NMEAGPS_PARSE_VTG ) & \
!defined( NMEAGPS_PARSE_ZDA ) & !defined( NMEAGPS_PARSE_GST ) & \
!defined( NMEAGPS_PARSE_PUBX_00 ) & !defined( NMEAGPS_PARSE_PUBX_04 )
#error No NMEA sentences enabled: no fix data available.
#endif
#if !defined( NMEAGPS_PARSE_PUBX_00 ) & !defined( NMEAGPS_PARSE_PUBX_04 )
#error No PUBX messages enabled! You must enable one or more in PUBX_cfg.h!
#endif
#ifndef NMEAGPS_DERIVED_TYPES
#error You must "#define NMEAGPS_DERIVED_TYPES" in NMEAGPS_cfg.h!
#endif
#ifndef NMEAGPS_EXPLICIT_MERGING
#error You must define NMEAGPS_EXPLICIT_MERGING in NMEAGPS_cfg.h
#endif
#ifdef NMEAGPS_INTERRUPT_PROCESSING
#error You must *NOT* define NMEAGPS_INTERRUPT_PROCESSING in NMEAGPS_cfg.h!
#endif
static ubloxNMEA gps; // This parses received characters
static gps_fix fix;
static void poll()
#if defined( NMEAGPS_PARSE_PUBX_00 )
gps.send_P( &gpsPort, F("PUBX,00") );
#endif
#if defined( NMEAGPS_PARSE_PUBX_04 )
gps.send_P( &gpsPort, F("PUBX,04") );
#endif
static void doSomeWork()
// Print all the things!
trace_all( DEBUG_PORT, gps, fix );
// Ask for the proprietary messages again
poll();
} // doSomeWork
static void GPSloop()
while (gps.available( gpsPort )) {
fix = gps.read();
#if defined(GPS_FIX_VELNED) && defined(NMEAGPS_PARSE_PUBX_00)
fix.calculateNorthAndEastVelocityFromSpeedAndHeading();
#endif
doSomeWork();
} // GPSloop
DEBUG_PORT.begin(9600);
while (!DEBUG_PORT)
DEBUG_PORT.print( F("PUBX: started\n") );
DEBUG_PORT.print( F("fix object size = ") );
DEBUG_PORT.println( sizeof(gps.fix()) );
DEBUG_PORT.print( F("ubloxNMEA object size = ") );
DEBUG_PORT.println( sizeof(gps) );
DEBUG_PORT.println( F("Looking for GPS device on " GPS_PORT_NAME) );
#ifdef NMEAGPS_PARSE_PUBX_04
if (LAST_SENTENCE_IN_INTERVAL != (NMEAGPS::nmea_msg_t) ubloxNMEA::PUBX_04) {
DEBUG_PORT.println( F("ERROR! LAST_SENTENCE_IN_INTERVAL should be PUBX_04") );
for(;;);
#else
if (LAST_SENTENCE_IN_INTERVAL != (NMEAGPS::nmea_msg_t) ubloxNMEA::PUBX_00) {
DEBUG_PORT.println( F("ERROR! LAST_SENTENCE_IN_INTERVAL should be PUBX_00") );
for(;;);
#endif
trace_header( DEBUG_PORT );
DEBUG_PORT.flush();
gpsPort.begin(9600);
// Ask for the special PUBX sentences
poll();
GPSloop();
It looks like the messages have to be requested rather than being sent by default. Note the poll() function in particular
