hello.
I am getting error while uploading a blink program.
I am getting this error message
/usr/local/bin/arduino-cli compile --fqbn arduino:avr:uno --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/562493824/build --build-path /tmp/arduino-build-D25142F96C7245628F79BF24544EA620 /tmp/562493824/Blink
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
Upload started
Programming with: Serial
Flashing with command:C:/Users/anupa/.arduino-create/arduino/avrdude/6.3.0-arduino17/bin/avrdude.exe -CC:/Users/anupa/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:/Users/anupa/AppData/Local/Temp/arduino-create-agent427468751/Blink.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:/Users/anupa/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2f
avrdude done. Thank you.
Please help
