Hi Everyone,
I have put Xbee and another examples in the liberaries under My Document. I tried to verify the code of Xbee "Series1_IoSamples". The error messages show as follows. I have searched about for the solution. I have followed the advice to have Xbee liberary installed under liberaries from The folder of Documents. However, the error is still there. A little bit frustrating. By the way, I use Windows 7 and 64 bit OS. My IDE software is Arduino 1.0.3 version.
Series1_IoSamples:41: error: 'SoftwareSerial' does not name a type
Series1_IoSamples:43: error: 'XBee' does not name a type
Series1_IoSamples:45: error: 'Rx16IoSampleResponse' does not name a type
Series1_IoSamples.pde: In function 'void setup()':
Series1_IoSamples:51: error: 'xbee' was not declared in this scope
Series1_IoSamples:53: error: 'nss' was not declared in this scope
Series1_IoSamples.pde: In function 'void loop()':
Series1_IoSamples:58: error: 'xbee' was not declared in this scope
Series1_IoSamples:63: error: 'RX_16_IO_RESPONSE' was not declared in this scope
Series1_IoSamples:64: error: 'ioSample' was not declared in this scope
Series1_IoSamples:66: error: 'nss' was not declared in this scope
Series1_IoSamples:105: error: 'nss' was not declared in this scope
Series1_IoSamples:110: error: 'nss' was not declared in this scope
#include <XBee.h>
#include <SoftwareSerial.h>
This example is for Series 1 XBee Radios only
Receives I/O samples from a remote radio with 16-bit addressing.
The remote radio must have IR > 0, at least one digital or analog input enabled
and DL set to the 16-bit address of the receiving XBee (the one connected to the Arduino).
This example uses the SoftSerial library to view the XBee communication. I am using a
Modern Device USB BUB board (http://moderndevice.com/connect) and viewing the output
with the Arduino Serial Monitor.
// Define NewSoftSerial TX/RX pins
// Connect Arduino pin 8 to TX of usb-serial device
uint8_t ssRX = 8;
// Connect Arduino pin 9 to RX of usb-serial device
uint8_t ssTX = 9;
// Remember to connect all devices to a common Ground: XBee, Arduino and USB-Serial device
SoftwareSerial nss(ssRX, ssTX);
XBee xbee = XBee();
Rx16IoSampleResponse ioSample = Rx16IoSampleResponse();
// 64-bit response is same except api id equals RX_64_IO_RESPONSE and returns a 64-bit address
//Rx64IoSampleResponse ioSample = Rx64IoSampleResponse();
xbee.setSerial(Serial);
// start soft serial
nss.begin(9600);
//attempt to read a packet
xbee.readPacket();
if (xbee.getResponse().isAvailable()) {
// got something
if (xbee.getResponse().getApiId() == RX_16_IO_RESPONSE) {
xbee.getResponse().getRx16IoSampleResponse(ioSample);
nss.print("Received I/O Sample from: ");
nss.println(ioSample.getRemoteAddress16(), HEX);
nss.print("Sample size is ");
nss.println(ioSample.getSampleSize(), DEC);
if (ioSample.containsAnalog()) {
nss.println("Sample contains analog data");
if (ioSample.containsDigital()) {
nss.println("Sample contains digtal data");
for (int k = 0; k < ioSample.getSampleSize(); k++) {
nss.print("Sample ");
nss.print(k + 1, DEC);
nss.println(":");
for (int i = 0; i <= 5; i++) {
if (ioSample.isAnalogEnabled(i)) {
nss.print("Analog (AI");
nss.print(i, DEC);
nss.print(") is ");
nss.println(ioSample.getAnalog(i, k));
for (int i = 0; i <= 8; i++) {
if (ioSample.isDigitalEnabled(i)) {
nss.print("Digtal (DI");
nss.print(i, DEC);
nss.print(") is ");
nss.println(ioSample.isDigitalOn(i, k));
else {
nss.print("Expected I/O Sample, but got ");
nss.print(xbee.getResponse().getApiId(), HEX);
else if (xbee.getResponse().isError()) {
nss.print("Error reading packet. Error code: ");
nss.println(xbee.getResponse().getErrorCode());
