Hi all, ive been chipping away at this code cleaning up errors and i feel im close to the end, but this error has me stumped, here is the full error log.
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
C:\Users\mattm\Documents\Arduino\6.5RSv2.1\6.5RSv2.1.ino: In function 'void loop()':
6.5RSv2.1:250:9: error: expected '}' at end of input
} //Repeat program (look for start command)
UKHeliBob:
At the very least, you are missing one or more } at the end of the loop() function
Auto Format the code in the IDE and all function definitions, such as this
//Begin function: Turn on accessory and ignition
void begin();
and
void wts();
should be on the left margin
A question for you. Why are you calling the loop() function in your sketch ?
That makes sense, ill give auto format a try. The loop function is supposed to return the program to the begining in the event the start sequence fails at any point during the program. Am I using the wrong function for this purpose?
TheMemberFormerlyKnownAsAWOL:
OK, now I'm at a PC now
The C++ dialect used by Arduino doesn't allow you to define a function inside another function.
Hint: If, after using the auto-format tool, your function definitions don't start on the extreme left margin, you've done something wrong.
Also, unlimited recursive calls are not generally A Good ThingTM
After adding and removing some brackets in places and another few snippets that didnt belong, the code finally compiles! Im not sure if it will work 100% yet, but my issues has been solved for now, thank you for all your help!!!
