Hello, I am totally new to Arduino programming, but have searched, and found almost what i wanted, however the programming is not going as well as I would like it to do.
The code is kind of a bodge between bits of code, from different places.
My Problem is that the morsecode transmitter works as it should, however i would like it to show which Character (letter or number) it is transmitting at the moment, and I would like it to do that in the LCD 1602 and the serial
It is at the moment doing that, but it is in the ASCII number for the Character, and not the Character itself. I have used a lot of hours searching for the answer and I can not find any. This is most likely because I am new, and it is not an original code, and i might have messed it up slightly
I ask of you, can you help to figure out what I have done wrong?
Regards
char text[] = "test sos"; // Transmittet text
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11 , 12);
int ledPin = 13;
int relaypin = 12;
int tempo = 500;
void setup () {
pinMode(ledPin, OUTPUT);
pinMode (relaypin, OUTPUT);
lcd.begin(16, 2);
lcd.setCursor(0,0);
lcd.write("Transmitter");
lcd.setCursor(0,1);
lcd.write("Sender Morse:");
Serial.println("Transmitter");
Serial.println("Sender Morsekode:");
void start(){ // rapid blink at startup
for(int i = 0; i < 50; i++){
digitalWrite(ledPin, HIGH);
delay(25);
digitalWrite(ledPin, LOW);
delay(25);
delay(7 * tempo);
void dot() { // we need more dots
digitalWrite(relaypin, LOW);
delay(1 * tempo);
digitalWrite(relaypin, HIGH);
delay(1 * tempo);
void dash() { // a dash and a splash
delay(3 * tempo);
delay(1 * tempo);
void morse(char letter) { // time to transmit
Serial.println(letter, DEC);
lcd.setCursor(13,1);
lcd.print(letter, DEC);
if (letter == 'a' or letter == 'A') {dot(); dash();}
if (letter == 'b' or letter == 'B') {dash(); dot(); dot(); dot();}
if (letter == 'c' or letter == 'C') {dash(); dot(); dash(); dot();}
if (letter == 'd' or letter == 'D') {dash(); dot(); dot();}
if (letter == 'e' or letter == 'E') {dot();}
if (letter == 'f' or letter == 'F') {dot(); dot(); dash(); dot();}
if (letter == 'g' or letter == 'G') {dash(); dash(); dot();}
if (letter == 'h' or letter == 'H') {dot(); dot(); dot(); dot();}
if (letter == 'i' or letter == 'I') {dot(); dot();}
if (letter == 'j' or letter == 'J') {dot(); dash(); dash(); dash();}
if (letter == 'k' or letter == 'K') {dash(); dot(); dash();}
if (letter == 'l' or letter == 'L') {dot(); dash(); dot(); dot();}
if (letter == 'm' or letter == 'M') {dash(); dash();}
if (letter == 'n' or letter == 'N') {dash(); dot();}
if (letter == 'o' or letter == 'O') {dash(); dash(); dash();}
if (letter == 'p' or letter == 'P') {dot(); dash(); dash(); dot();}
if (letter == 'q' or letter == 'Q') {dash(); dash(); dot(); dash();}
if (letter == 'r' or letter == 'R') {dot(); dash(); dot();}
if (letter == 's' or letter == 'S') {dot(); dot(); dot();}
if (letter == 't' or letter == 'T') {dash();}
if (letter == 'u' or letter == 'U') {dot(); dot(); dash();}
if (letter == 'v' or letter == 'V') {dot(); dot(); dot(); dash();}
if (letter == 'w' or letter == 'W') {dot(); dash(); dash();}
if (letter == 'x' or letter == 'X') {dash(); dot(); dot(); dash();}
if (letter == 'y' or letter == 'Y') {dash(); dot(); dash(); dash();}
if (letter == 'z' or letter == 'Z') {dash(); dash(); dot(); dot();}
if (letter == '1') {dot(); dash(); dash(); dash(); dash();}
if (letter == '2') {dot(); dot(); dash(); dash(); dash();}
if (letter == '3') {dot(); dot(); dot(); dash(); dash();}
if (letter == '4') {dot(); dot(); dot(); dot(); dash();}
if (letter == '5') {dot(); dot(); dot(); dot(); dot();}
if (letter == '6') {dash(); dot(); dot(); dot(); dot();}
if (letter == '7') {dash(); dash(); dot(); dot(); dot();}
if (letter == '8') {dash(); dash(); dash(); dot(); dot();}
if (letter == '9') {dash(); dash(); dash(); dash(); dot();}
if (letter == '0') {dash(); dash(); dash(); dash(); dash();}
if (letter == ' ') {delay(5 * tempo);} // This makes 7 * tempo for space
if (letter == 166 or letter == 134) {dot(); dash(); dot(); dash();} // æ/Æ is recognized as 166/134
if (letter == 184 or letter == 152) {dash(); dash();dash();dot();} // ø/Ø is recognized as 184/152
if (letter == 165 or letter == 133) {dot();dash();dash();dot();dash();} // å/Å is recognized as 165/133
delay(2 * tempo); // this makes 3 * tempo for letter end, and 7 * tempo for space
void loop () {
start();
for (int i = 0; i < sizeof(text); i++) {
morse(text[i]);
