I downloaded Arduino for mac 10.10 and I get this when i try to upload the blink sketch:
avrdude: stk500_getsync() attempt 10 of 10: not in sync
Tools>board> is on Arduino/Genuino and the serial port only has /dev/cu.Bluetooth-Incoming-Port
Can someone please help me get this to work? It should be on tty for the serial port?
peeela
#2
Same.
System: Mac OS 10.12.6 Sierra
Board:Arduino Uno
Port: /dev/cu.usbserial-A403CUA8
Programmer: arduino
Have tried to problem solve by updating FTDISerialDriver_v2_2_18.dmg (FTDIUSBSerialDriver_10_4_10_5_10_6_10_7).
I get a serial connection to: cu.usbserial-A403CUA8 but nothting more than that.
Complete log/error:
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Uno"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/andrewpeel/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10805 -build-path /var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724 -warnings=all -build-cache /var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_cache_64910 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_modified_sketch_31525/Blink.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/andrewpeel/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10805 -build-path /var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724 -warnings=all -build-cache /var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_cache_64910 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/Applications/Arduino.app/Contents/Java/hardware/tools/avr -verbose /var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_modified_sketch_31525/Blink.ino
Using board 'uno' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Using core 'arduino' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr
Detecting libraries used...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/sketch/Blink.ino.cpp" -o "/dev/null"
Generating function prototypes...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/sketch/Blink.ino.cpp" -o "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/preproc/ctags_target_for_gcc_minus_e.cpp"
"/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/preproc/ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/sketch/Blink.ino.cpp" -o "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/sketch/Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/Blink.ino.elf" "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/sketch/Blink.ino.cpp.o" "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/../arduino_cache_64910/core/core_arduino_avr_uno_51f02b7210b938436b779d1c032618e1.a" "-L/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724" -lm
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/Blink.ino.elf" "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/Blink.ino.eep"
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/Blink.ino.elf" "/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/Blink.ino.hex"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-A403CUA8 -b115200 -D -Uflash:w:/var/folders/hg/dkxv2ztx19l6kqc61nk6mx340000gn/T/arduino_build_776724/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/myusername/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbserial-A403CUA8
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
