Getting constant ADC value based on user input from serial monitor
I am trying to get a constant ADC value from the ADC based on the user input. For example: the user hits 1, the output ADC value is 100, if it is 2 the output would be 200. This will continue till the user enters a new number. The issue I am having with my code is when I enter a number, the output of the ADC goes to that value for about a second and then goes back to 0. Can you please let me know what I am missing?
I am using Arduino MKR NB 1500 board
// Sketch: Blinking two LEDs by user
int test_pin=2; // declare pin10 as ledpin
int ADCvalue; // variable to store the number of blinks
  Serial.println("What is the new speed?"); //Prompt User for Input
 while (Serial.available() == 0) {
    // Wait for User to Input Data
  ADCvalue = Serial.parseInt(); //Read the data the user has input
  if (ADCvalue==0)
    analogWrite(test_pin,0);
    else if (ADCvalue==1)
      analogWrite(test_pin,100);
      else if (ADCvalue==2)
      analogWrite(test_pin,200);
      else if (ADCvalue==3)
      analogWrite(test_pin,300);
      else if (ADCvalue==4)
      analogWrite(test_pin,400);
      else if (ADCvalue==5)
      analogWrite(test_pin,500);
      else if (ADCvalue==6)
      analogWrite(test_pin,600);
      else if (ADCvalue==7)
      analogWrite(test_pin,700);
      else if (ADCvalue==8)
      analogWrite(test_pin,800);
      else if (ADCvalue==9)
      analogWrite(test_pin,900);
      analogWrite(test_pin,1023);
  Serial.print("The user has choosen the number:");
  Serial.println(ADCvalue);
  Serial.println(" ");
Serial monitor line ending to "none"
An alternative that allows for line ending characters is to flush the input buffer before prompting for input:
  while (Serial.available()) Serial.read();  // <<< Add this line
