Hi Guys
I have a Nano and a SI4703 Radio Module. It works so far: I get a clear Signal, can listen to Radio and get (sometimes) RDS Infos like Station, etc..
Actually I need only the Time to set the RTC. But I can't get a correct Time - either I get Garbage, a completely wrong Time or nothing.
I tried different Libraries and Examples, now I use this:
Under construction... See si570x_02_TFT_display
Test and validation of SI4703 RDS feature.
Arduino Pro Mini and SI4703 wire up
| Device Si470X | Arduino Pin |
| RESET | 14/A0 |
| SDIO | A4 |
| SCLK | A5 |
ATTENTION:
Please, avoid using the computer connected to the mains during testing. Used just the battery of your computer.
This sketch was tested on ATmega328 based board. If you are not using a ATmega328, please check the pins of your board.
By Ricardo Lima Caratti, 2020.
#include <SI470X.h>
#define RESET_PIN 14 // On Arduino Atmega328 based board, this pin is labeled as A0 (14 means digital pin instead analog)
#define MAX_DELAY_RDS 40 // 40ms - polling method
#define MAX_DELAY_STATUS 2000
long rds_elapsed = millis();
long status_elapsed = millis();
SI470X rx;
while (!Serial)
Serial.println("\nPU2CLR SI470X Arduino Library.");
rx.setup(RESET_PIN, A4 /* SDA pin for Arduino ATmega328 */);
rx.setRDS(true); // Turns RDS on
rx.setVolume(6);
// Select a station with RDS service in your place
Serial.print("\nTuning 9470 MHz");
rx.setFrequency(9470); // It is the frequency you want to select in MHz multiplied by 100.
// Enables SDR
rx.setRds(true);
rx.setRdsMode(1);
rx.setMono(false);
showHelp();
void showHelp() {
Serial.println("Type U to increase and D to decrease the frequency");
Serial.println("Type S or s to seek station Up or Down");
Serial.println("Type + or - to volume Up or Down");
Serial.println("Type 0 to show current status");
Serial.println("Type ? to this help.");
Serial.println("==================================================");
delay(5000);
// Show current frequency
void showStatus() {
char aux[80];
sprintf(aux, "\nYou are tuned on %u MHz | RSSI: %3.3u dbUv | Vol: %2.2u | Stereo: %s\n", rx.getFrequency(), rx.getRssi(), rx.getVolume(), (rx.isStereo()) ? "Yes" : "No");
Serial.print(aux);
RDS
char *programInfo;
char *stationName;
char *rdsTime;
void showRdsData() {
if (programInfo) {
Serial.print("\nProgram Info...: ");
Serial.println(programInfo);
if (stationName) {
Serial.print("\nStation Name...: ");
Serial.println(stationName);
if (rdsTime) {
Serial.print("\nUTC / Time....: ");
Serial.println(rdsTime);
void checkRDS() {
if (rx.getRdsReady()) {
programInfo = rx.getRdsProgramInformation();
stationName = rx.getRdsStationName();
rdsTime = rx.getRdsTime();
showRdsData();
if ((millis() - rds_elapsed) > MAX_DELAY_RDS) {
checkRDS();
if ((millis() - status_elapsed) > MAX_DELAY_STATUS) {
showStatus();
if (Serial.available() > 0) {
char key = Serial.read();
switch (key) {
case '+':
rx.setVolumeUp();
case '-':
rx.setVolumeDown();
case 'U':
case 'u':
rx.setFrequencyUp();
case 'D':
case 'd':
rx.setFrequencyDown();
case 'S':
rx.seek(SI470X_SEEK_WRAP, SI470X_SEEK_UP);
case 's':
rx.seek(SI470X_SEEK_WRAP, SI470X_SEEK_DOWN);
case '?':
showHelp();
default:
showStatus();
delay(5);
I tried to figure out how RDS works but this is far over my Understanding. Can someone please help me ?
