Hey there,
I found this code online:
#include <OneWire.h>
OneWire ds(6); // OneWire bus on digital pin 6
Serial.begin (9600);
delay(250);
byte i; // This is for the for loops
boolean present; // device present varj
byte data[8]; // container for the data from device
byte crc_calc; //calculated CRC
byte crc_byte; //actual CRC as sent by DS2401
String test;
//1-Wire bus reset, needed to start operation on the bus,
//returns a 1/TRUE if presence pulse detected
present = ds.reset();
if (present == TRUE)
Serial.println("---------- Device present ----------");
ds.write(0x33); //Send Read data command
data[0] = ds.read();
Serial.print("Family code: 0x");
PrintTwoDigitHex (data[0], 1);
Serial.print("Hex ROM data: ");
for (i = 1; i <= 8; i++)
data[i] = ds.read(); //store each byte in different position in array
test = PrintTwoDigitHex (data[i], 0);
Serial.print(" ");
Serial.println(test);
crc_byte = ds.read(); //read CRC, this is the last byte
crc_calc = OneWire::crc8(data, 7); //calculate CRC of the data
Serial.print("Calculated CRC: 0x");
PrintTwoDigitHex (crc_calc, 1);
Serial.print("Actual CRC: 0x");
PrintTwoDigitHex (crc_byte, 1);
else //Nothing is connected in the bus
Serial.println("xxxxx Nothing connected xxxxx");
delay(8000);
String PrintTwoDigitHex (byte b, boolean newline)
Serial.print(b/16, HEX);
Serial.print(b%16, HEX);
if (newline) Serial.println();
And i want the HEX rom data in a string variable complete. but the way it’s being built up is: it loops 6 times thrue the PrintTwoDigitHex function. And i have no idea how i can have a variable String test for example where the value would be: FF FF FF FF FF FF. Can anyone help me figure this out? Thanks in advance
Regards,
