Getting data from serial monitor
Hello,
Can someone assist me to parse the following data which i am receiving on serial monitor. The data which i am getting on serial monitor is
+CRING: VOICE
+CLIP: "+919404789938",145,"",,"No1",0
+CRING: VOICE
i want to get the number +919404789938 and store it in a array
This is easy. Scan through the string and as soon as you see a ‘+’ start saving characters, stop at the ‘"’.
char source; // contains the string in the OP.
char res[32]; // where to store the phone number
int idx_scan= 0;
int idx_res = 0; index for result.
while (source[idx_scan] != ‘+’) idx_scan++; // so we get the ‘+’
while (source[idx_idxscan] != ‘"’) {
res[idx_res++] = source[idx_scan++];
res[idx_res] = ‘\0’; // terminate
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
You could adapt the 3rd example to use the '+' as the start-marker and the '.' as the end-marker.
Or it might be better to receive the entire message and then parse it. The parse example in the link should get you started.
...R
Thanks for the suggestion's i tried KeithRB method as well as Robin2's method but it didn't work in my case. Robin2 3rd example is quite good and explains it very well.
As i am using two serial inputs one from Serial1 and another from Serial of mega so couldn't get the desired result. i have taken data from gsm modem on serial1 and given it to serial port. i have used the example given in arduino tutorial of MultiSerialMega .
// read from port 1, send to port 0:
  if (Serial1.available()) {
    int inByte = Serial1.read();
    Serial.write(inByte);
  // read from port 0, send to port 1:
  if (Serial.available()) {
    int inByte = Serial.read();
    Serial1.write(inByte);
whenever i make a call to modem i receive the string of data which i have placed in the above section and the data updates every second or so till the call is ended.
JairajDange:
As i am using two serial inputs one from Serial1 and another from Serial of mega so couldn’t get the desired result.
If you want help you need to post the complete program you have tried.
And “but it didn’t work in my case.” tells me nothing useful that I can use to help you.
…R
in the following code i tried to use your example 3 sketch
onst byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
    Serial.println("<Arduino is ready>");
Serial1.begin(9600);
pinMode(13,OUTPUT);
 Serial.println("Serial call");
Serial1.println("ATD>SM1");
// this works fine and calls number which is located in sim
delay(20000);
Serial.println("Call has been made");
instead of calling the functions i used the changes in sketch itself
    static boolean recvInProgress = false;
    static byte ndx = 0;
    char startMarker = '+';
    char endMarker = ',';
    char rc;
    while (newData == false) {
        rc = inByte;
        if (recvInProgress == true) {
            if (rc != endMarker) {
                receivedChars[ndx] = rc;
                ndx++;
                if (ndx >= numChars) {
                    ndx = numChars - 1;
            else {
                receivedChars[ndx] = '\0'; // terminate the string
                ndx = 0;
                newData = true;
        else if (rc == startMarker) {
            recvInProgress = true;
      if (newData == true) {
        Serial.print("This just in ... ");
        Serial.println(receivedChars);
        newData = false;
now whenever i make a call i get following output on serial monitor
RING
RING
RING
RING
NO CARRIER
it doesn’t display a number
JairajDange: in the following code i tried to use your example 3 sketch
You don't seem to have read the first sentence of Reply #4 carefully.
...R
i have posted whole code in reply #5
JairajDange: i have posted whole code in reply #5
I am not going to try to join two parts together. I might make a mistake, or you may have done so.
...R
i posted code separately because i thought it would be easy to understand
here is the full code
const byte numChars = 32;
pinMode(13,OUTPUT);
delay(20000);
    char rc;
        rc = inByte;
                ndx++;
                    ndx = numChars - 1;
            else {
                ndx = 0;
                newData = true;
        newData = false;
You seem to be using my code to read from Serial whereas I thought the whole purpose was to apply it to Serial1 where the numbers come from.
Also it would be much easier (for you and for me) if you just keep my complete function and call it from loop() as in my example rather than trying to incorporate the code into loop(). Putting code into small single purpose functions makes it much easier to develop and to maintain.
And there would be nothing to prevent you having two copies of my function (with different function names) one to receive data from Serial and the other to receive data from Serial1
...R
Initially i used following code to make a call through the Gsm modem through Serial1 port of mega and getting data on Serial port .
delay(20000);
it worked very well
Then i tried to use your code to sort the data which i was getting on serial monitor but it was keeping the modem engaged continuous by sending data to port the code i used was
int inByte;
delay(20000);
recvWithStartEndMarkers();
    showNewData();
    showNewData();
void recvWithStartEndMarkers() {
    char rc;
 // if (Serial.available() > 0) {
    while (Serial.available() > 0 && newData == false) {
        rc = inByte;
                ndx++;
                    ndx = numChars - 1;
            else {
                ndx = 0;
                newData = true;
void showNewData() {
        newData = false;
so i tried to put the section of your code in loop itself so that it directly shall read the data from Serial1 port instead of calling and then sorting the string
JairajDange:
Then i tried to use your code to sort the data which …
You seem to have things all mixed up.
The call to recvWithStartEndMarkers() should not be inside any IF clause. It should be called directly from loop() - like in my demo.
And, as I said earlier, I thought you wanted to use that function to get data from Serial1 - but you are using it to get data from Serial. Which serial port is your GSM device (or whatever it is?) connected to?
…R
i thought of calling the recvWithStartEndMarkers() function when their is serial call takes place, so i used recvWithStartEndMarkers() in if condition so that it will engage only when their is a call from serial . The gsm is connected to Serial1 port of mega.
JairajDange: i thought of calling the recvWithStartEndMarkers() function when their is serial call takes place, so i used recvWithStartEndMarkers() in if condition so that it will engage only when their is a call from serial .
As I said (and showed in my demo) that is not right.
So why is the recvWithStartEndMarkers() function reading from Serial?
I get the feeling a little more careful thinking is what you need to do.
...R
I guess i was wrong trying to read from both serial as well as serial1, i shall stick to serial1 which is connected to gsm modem
JairajDange: I guess i was wrong trying to read from both serial as well as serial1, i shall stick to serial1 which is connected to gsm modem
They are two completely different data streams. Maybe you need to read from both or maybe not. I mentioned how to read from both in Reply #10 - if you need to do that.
...R
