Getting Double Text Messages from GSM Shield???
I posted this issue on the vendors forum but haven't received an answer in over a week so I thought I might see if anyone here had any ideas
I am building a remote sensor package, using a Mega, to read river levels and such and send the readings via text message on a periodic basis or as predefined thresholds are exceeded.
I am testing a Geeetech SIM900 GPRS Shield for this. I have the shield up and running and sending the messages but I have run into a problem. Each message shows up twice on the receiving end.
Here's my code for sending the text message. I got the basic code sample from their wiki:
void SEND_SENSOR_READ(String SnsrVal) {
    CellSerial.print("AT+CMGF=1\r");  //Send an SMS in text mode
    delay(100);
    CellSerial.println("AT + CMGS = \"+1nnnnnnnnnn\""); // phone number to send to
    delay(100);
    CellSerial.println(SnsrVal); // Sensor value to send
    delay(100);
    CellSerial.println((char)26); //the ASCII code of the ctrl+z is 26
    delay(100);
    CellSerial.println();
Any thoughts on what would cause this to happen? What might I do to debug this?
Thanks!
Tom G.
I can't see anything wrong with that so I assume your code calls it twice. Post (or attach) the whole thing for better answers :wink:
Thanks for the prompt reply!!!
I looked over my code to see if it might be triggering the message more than one time, but I could not see anything that would cause that.
But, to be sure I loaded the original test code from the vendors wiki and ran that. Same result, two messages received for one send.
In case it makes a difference the carrier is T-Mobile.
Here's the full test code:
/*Note: this code is a demo for how to using gprs shield to send sms message, dial a voice call and
 send a http request to the website, upload data to pachube.com by TCP connection,
 The microcontrollers Digital Pin 7 and hence allow unhindered
 communication with GPRS Shield using SoftSerial Library.
 IDE: Arduino 1.0 or later
 Replace the following items in the code:
 1.Phone number, don't forget add the country code
 2.Replace the Access Point Name
 3. Replace the Pachube API Key with your personal ones assigned
 to your account at cosm.com
#include <SoftwareSerial.h>
#include <String.h>
SoftwareSerial mySerial(7, 8);
 mySerial.begin(19200);               // the GPRS baud rate
 //after start up the program, you can using terminal to connect the serial of gprs shield,
 //if you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message,
 //if input 'd' in the terminal, it will execute DialVoiceCall(), etc.
  if (Serial.available())
   switch(Serial.read())
    case 't':
      SendTextMessage();
    case 'r':
      RecieveTextMessage();//This program code by directive'r'to receive, by receiving the information after the return to call the function
                           //to verify receiving function. But it can not display the received content in SIM.
      DialVoiceCall();
    case 'd':
      DialVoiceCall();
    case 'h':
      SubmitHttpRequest();
    case 's':
      Send2Pachube();
 if (mySerial.available())
   Serial.write(mySerial.read());
///SendTextMessage()
///this function is to send a sms message
 void SendTextMessage()
 mySerial.print("AT+CMGF=1\r");    //Because we want to send the SMS in text mode
 delay(100);
 mySerial.println("AT + CMGS = \"+nnnnnnnnnnn\"");//send sms message, be careful need to add a country code before the cellphone number
 delay(100);
 mySerial.println("A test message!");//the content of the message
 delay(100);
 mySerial.println((char)26);//the ASCII code of the ctrl+z is 26
 delay(100);
 mySerial.println();
 void RecieveTextMessage()
  //mySerial.print("AT+CMGF=1\r"); //Because we want to recieve the SMS in text mode
 //delay(100);
   mySerial.print("AT+CMGR=1\r");//Because we want to recieve the SMS in text mode
   delay(100);
   mySerial.println("AT + CSCA = \"+nnnnnnnnnnn\"");//recieve sms message, be careful need to add a country code before the cellphone number
   delay(100);
   delay(100);
   delay(100);
   mySerial.println();
 //return r;
///DialVoiceCall
///this function is to dial a voice call
void DialVoiceCall()
 mySerial.println("ATD + +nnnnnnnnnnn;");//dial the number
 delay(100);
 mySerial.println();
///SubmitHttpRequest()
///this function is submit a http request
///attention:the time of delay is very important, it must be set enough
void SubmitHttpRequest()
 mySerial.println("AT+CSQ");
 delay(100);
 ShowSerialData();// this code is to show the data from gprs shield, in order to easily see the process of how the gprs shield submit a http request, and the following is for this purpose too.
 mySerial.println("AT+CGATT?");
 delay(100);
 ShowSerialData();
 mySerial.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");//setting the SAPBR, the connection type is using gprs
 ShowSerialData();
 mySerial.println("AT+SAPBR=3,1,\"APN\",\"CMNET\"");//setting the APN, the second need you fill in your local apn server
 delay(4000);
 ShowSerialData();
 mySerial.println("AT+SAPBR=1,1");//setting the SAPBR, for detail you can refer to the AT command mamual
 delay(2000);
 ShowSerialData();
 mySerial.println("AT+HTTPINIT"); //init the HTTP request
 delay(2000);
 ShowSerialData();
 mySerial.println("AT+HTTPPARA=\"URL\",\"www.google.com.hk\"");// setting the httppara, the second parameter is the website you want to access
 ShowSerialData();
 mySerial.println("AT+HTTPACTION=0");//submit the request
 delay(10000);//the delay is very important, the delay time is base on the return from the website, if the return datas are very large, the time required longer.
 //while(!mySerial.available());
 ShowSerialData();
 mySerial.println("AT+HTTPREAD");// read the data from the website you access
 delay(300);
 ShowSerialData();
 mySerial.println("");
 delay(100);
///send2Pachube()///
///this function is to send the sensor data to the pachube, you can see the new value in the pachube after execute this function///
void Send2Pachube()
 delay(100);
 ShowSerialData();
 mySerial.println("AT+CSTT=\"CMNET\"");//start task and setting the APN,
 ShowSerialData();
 mySerial.println("AT+CIICR");//bring up wireless connection
 delay(300);
 ShowSerialData();
 mySerial.println("AT+CIFSR");//get local IP adress
 delay(2000);
 ShowSerialData();
 mySerial.println("AT+CIPSPRT=0");
 delay(3000);
 ShowSerialData();
 mySerial.println("AT+CIPSTART=\"tcp\",\"api.cosm.com\",\"8081\"");//start up the connection
 delay(2000);
 ShowSerialData();
 mySerial.println("AT+CIPSEND");//begin send data to remote server
 delay(4000);
 ShowSerialData();
 String humidity = "1031";//these 4 line code are imitate the real sensor data, because the demo did't add other sensor, so using 4 string variable to replace.
 String moisture = "1242";//you can replace these four variable to the real sensor data in your project
 String temperature = "30";//
 String barometer = "60.56";//
 mySerial.print("{\"method\": \"put\",\"resource\": \"/feeds/42742/\",\"params\"");//here is the feed you apply from pachube
 ShowSerialData();
 mySerial.print(": {},\"headers\": {\"X-PachubeApiKey\":");//in here, you should replace your pachubeapikey
 ShowSerialData();
 mySerial.print(" \"_cXwr5LE8qW4a296O-cDwOUvfddFer5pGmaRigPsiO0");//pachubeapikey
 ShowSerialData();
 mySerial.print("jEB9OjK-W6vej56j9ItaSlIac-hgbQjxExuveD95yc8BttXc");//pachubeapikey
 ShowSerialData();
 mySerial.print("Z7_seZqLVjeCOmNbEXUva45t6FL8AxOcuNSsQS\"},\"body\":");
 ShowSerialData();
 mySerial.print(" {\"version\": \"1.0.0\",\"datastreams\": ");
 ShowSerialData();
 mySerial.println("[{\"id\": \"01\",\"current_value\": \"" + barometer + "\"},");
 ShowSerialData();
 mySerial.println("{\"id\": \"02\",\"current_value\": \"" + humidity + "\"},");
 ShowSerialData();
 mySerial.println("{\"id\": \"03\",\"current_value\": \"" + moisture + "\"},");
 ShowSerialData();
 mySerial.println("{\"id\": \"04\",\"current_value\": \"" + temperature + "\"}]},\"token\": \"lee\"}");
 ShowSerialData();
 mySerial.println((char)26);//sending
 delay(5000);//waitting for reply, important! the time is base on the condition of internet
 mySerial.println();
 ShowSerialData();
 mySerial.println("AT+CIPCLOSE");//close the connection
 delay(100);
 ShowSerialData();
void ShowSerialData()
 while(mySerial.available()!=0)
When I send the "t" to the shield via the Serial Monitor here is the response I get back:
AT+CMGF=1
OK
AT + CMGS = "+nnnnnnnnnnn"
A test message!
+CMGS: 38
OK
PROBLEM SOLVED!!!
Thanks to a couple suggestions I got from Wildbill, I moved the text send portion of the code into the setup loop and deleted all the other code. I also looked at all the line feeds being issued.
Wildbill questioned the need for that last println() and that got me thinking. I removed it from the code but, no change, still 2 text messages. However that caused me to look at the other line feeds. As it turns out, removing the "ln" from the text message content line has solved the problem. Without a line feed between the text content and the cntrl+z I get only one text message.
A BIG THANK YOU TO WILDBILL!!!!!
Tom G.
#include <String.h>
 // Serial.begin(19200);
 delay(100);
 delay(100);
 // mySerial.println("A test message!");//the content of the message
 mySerial.print("A test message!");//the content of the message
 delay(100);
 delay(100);
 // mySerial.println();
void loop(){
  // No loop code
into the setup loop
As opposed to the loop loop?
setup() is a function!
