#include <Wire.h>
#define DS3231_I2C_ADDRESS 0x68
LiquidCrystal_I2C lcd(0x3F,2,1,0,4,5,6,7); // Set the LCD I2C address
////Convert normal decimal numbers to binary coded decimal.
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
////Convert binary coded decimal to normal decimal numbers.
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
////Stops the clock, but it has the side effect of setting seconds to 0.
/*void stopDs1307()
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.write(0);
Wire.writeWire.writeWire.write(0x80);
Wire.endTransmission();
////1) Sets date and time on the clock.
////2) Starts the clock.
////3) Sets hour mode to 24 hours.
void setDS3231time(
byte second, ////0-59
byte minute, ////0-59
byte hour, ////1-23
byte dayOfWeek, ////1-7
byte dayOfMonth, ////1-28/29/30/31
byte month, ////1-12
byte year) ////0-99
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0);
Wire.write(decToBcd(second)); ////0 to bit 7 starts the clock
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour)); ////If you want 12 hours (am/pm) you need to set
////bit 6 (also need to change getDateDs1307)
Wire.write(decToBcd(dayOfWeek));
Wire.write(decToBcd(dayOfMonth));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
////Reads date and time from the clock,
void readDS3231time(
byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
////Reset the register pointer.
Wire.write(0);
Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
////A few of these need masks because certain bits are control bits.
*second = bcdToDec(Wire.read() & 0x7f);
*minute = bcdToDec(Wire.read());
*hour = bcdToDec(Wire.read() & 0x3f); ////Need to change this for 12 hours (am/pm)
*dayOfWeek = bcdToDec(Wire.read());
*dayOfMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
////Define pump pin outs.
int motorPin1 = 8; //Pump 1 – Flourish Excel
int motorPin2 = 9; //Pump 2 – Flourish Iron
int motorPin3 = 10; //Pump 3 – Flourish
int motorPin4 = 11; //Pump 4 – Flourish
int motorPin5 = 12; //Pump 5 – Flourish
int actled = 13; //Status Led
void setup() ////One time run at each execution.
lcd.begin (16,2); // for 16 x 2 LCD module
lcd.setBacklightPin(3,POSITIVE);
lcd.setBacklight(HIGH);
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
pinMode(motorPin5, OUTPUT);
pinMode(actled, OUTPUT);
Wire.begin();
////Set date and time on the clock.
////You only need to run this the first time you setup your RTC.
////Set the correct value below and un comment it to run it.
//DS3231 seconds, minutes, hours, day, date, month, year
//setDS3231time(50,33,12,2,14,5,18);
////Main programm loop.
////Serial Monitor Output.
readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
Serial.print("Date: ");
Serial.print(dayOfMonth, DEC);
Serial.print("/");
Serial.print(month, DEC);
Serial.print("/");
Serial.print(year, DEC);
Serial.println(" ");
Serial.print(" Day of week: ");
switch(dayOfWeek){
case 1:
Serial.println("Sunday");
case 2:
Serial.println("Monday");
case 3:
Serial.println("Tuesday");
case 4:
Serial.println("Wednesday");
case 5:
Serial.println("Thursday");
case 6:
Serial.println("Friday");
case 7:
Serial.println("Saturday");
Serial.print("Time: ");
Serial.print(hour, DEC);
Serial.print(":");
Serial.print(minute, DEC);
Serial.print(":");
Serial.print(second, DEC);
lcd.home ();
if(dayOfMonth<10)
lcd.print('0');
lcd.print(dayOfMonth, DEC);
lcd.print("/");
if(month<10)
lcd.print('0');
lcd.print(month, DEC);
lcd.print("/");
if(year<10)
lcd.print('0');
lcd.print(year, DEC);
lcd.print(" ");
switch(dayOfWeek){
case 1:
lcd.println("Sunday ");
case 2:
lcd.println("Monday ");
case 3:
lcd.println("Tue");
case 4:
lcd.println("Wed");
case 5:
lcd.println("Thur");
case 6:
lcd.println("Fri");
case 7:
lcd.println("Sat");
lcd.setCursor ( 0, 1 ); // go to the next line
lcd.print("Time: ");
if(hour<10)
lcd.print('0');
lcd.print(hour, DEC);
lcd.print(":");
if(minute<10)
lcd.print('0');
lcd.print(minute, DEC);
lcd.print(":");
if(second<10)
lcd.print('0');
lcd.print(second, DEC);
analogWrite(actled, 255);
////Pump Operation
////Everyday: IRON
if((dayOfWeek !=7)&&(hour == 17)&&(minute == 31)&&(second == 10)){
////Start Iron pump 1.5ml
Serial.print("Iron Pump 1.5ml");
Serial.println("");
Serial.println("On");
analogWrite(motorPin1, 255);
delay(1500); // 1000 = aprox 1 ml
analogWrite(motorPin1, 0);
Serial.println("");
Serial.println("Off");
////Monday: kno3, kho2s4, pso4
if(dayOfWeek == 2){
////Start kno3 7.5ml
Serial.print(" Flourish Excel Pump 7.5ml");
Serial.println("");
analogWrite(motorPin2, 255);
delay(7500); // 1000 = aprox 1 ml
analogWrite(motorPin2, 0);
Serial.println("");
////Start kho2s4 1.5ml
Serial.print("kho2s4 Pump 1,5ml");
Serial.println("");
analogWrite(motorPin3, 255);
analogWrite(motorPin3, 0);
Serial.println("");
Serial.println(" Off");
Serial.println("");
analogWrite(motorPin4, 255);
analogWrite(motorPin4, 0);
Serial.println("");
////TUESDAY
if(dayOfWeek == 2){
////Start Micro pump
Serial.print(" Micro Pump 1,5ml");
Serial.println("");
////Wednesday: kno3, kho2s4, pso4
if(dayOfWeek == 3){
Serial.println("");
Serial.println("");
Serial.println("");
Serial.println("");
Serial.println("");
Serial.println("");
////Thursday
if(dayOfWeek == 4){
Serial.println("");
////Friday: kno3, kho2s4, pso4
if(dayOfWeek == 5){
Serial.println("");
Serial.println("");
Serial.println("");
Serial.println("");
Serial.println("");
Serial.println("");
////Saturday
if(dayOfWeek == 6){
Serial.println("");
else{
Serial.println ("Pump Status:Off");
////Backup Close Pump
analogWrite(actled, 0);
// delay(1000);
