Getting error in code
I'm getting this error:
/usr/local/bin/arduino-cli compile --fqbn esp32:esp32:esp32doit-devkit1:DebugLevel=none,FlashFreq=80,UploadSpeed=921600 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/116661056/build --build-path /tmp/arduino-build-52743E81FB39DAA24ADD12C8D04500DF --library /mnt/create-efs/webide/13/e8/13e89aac54e7d22b04665ae02741cfff:farhan74/libraries_v2/SimpleTimer --library /mnt/create-efs/webide/13/e8/13e89aac54e7d22b04665ae02741cfff:farhan74/libraries_v2/TimerOne /tmp/116661056/sketch_sep16a
Using library dallastemperature_3_9_0 at version 3.9.0 in folder: /home/builder/opt/libraries/dallastemperature_3_9_0
Using library dht_sensor_library_for_espx_1_18_0 at version 1.18 in folder: /home/builder/opt/libraries/dht_sensor_library_for_espx_1_18_0
/tmp/116661056/sketch_sep16a/sketch_sep16a.ino: In function 'void setup()':
/tmp/116661056/sketch_sep16a/sketch_sep16a.ino:67:4: error: 'ECG' was not declared in this scope
ECG,
/tmp/116661056/sketch_sep16a/sketch_sep16a.ino:73:15: error: 'Spo' was not declared in this scope
xTaskCreate(Spo,"dusra",1000,NULL,1,NULL);
/tmp/116661056/sketch_sep16a/sketch_sep16a.ino:74:15: error: 'tempB' was not declared in this scope
xTaskCreate(tempB,"teesra",1000,NULL,1,NULL);
/tmp/116661056/sketch_sep16a/sketch_sep16a.ino:75:15: error: 'temp' was not declared in this scope
xTaskCreate(temp,"chotha",1000,NULL,1,NULL);
/tmp/116661056/sketch_sep16a/sketch_sep16a.ino:75:15: note: suggested alternative: 'time'
time
/tmp/116661056/sketch_sep16a/sketch_sep16a.ino: In function 'void loop()':
/tmp/116661056/sketch_sep16a/sketch_sep16a.ino:84:28: error: a function-definition is not allowed here before '{' token
void ECG(void*parameters){
/tmp/116661056/sketch_sep16a/sketch_sep16a.ino:100:26: error: a function-definition is not allowed here before '{' token
void Spo(void*parameters){
/tmp/116661056/sketch_sep16a/sketch_sep16a.ino:122:30: error: a function-definition is not allowed here before '{' token
void tempB(void*parameters){
/tmp/116661056/sketch_sep16a/sketch_sep16a.ino:138:29: error: a function-definition is not allowed here before '{' token
void temp(void*parameters){
Error during build: exit status 1
Code
#define BLYNK_TEMPLATE_ID "TMPLi-ilzaW4"
#define BLYNK_DEVICE_NAME "IOT based PMS"
#define BLYNK_AUTH_TOKEN "BfXLIyvrGTD4aHSl46zxH7GA_uZG0EFx"
#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <Wire.h>
#include<Blynk.h>
#include <BlynkSimpleEsp32.h>
#include "MAX30100_PulseOximeter.h"
#include <OneWire.h>
#include <DallasTemperature.h>
#include "DHTesp.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#define DS18B20 5
#define REPORTING_PERIOD_MS     1000
BlynkTimer timer;
int BPM, SpO2;
char auth[] = BLYNK_AUTH_TOKEN;
/*Put your SSID & Password*/
 char ssid[] = "iPhone";  // Enter SSID here
 char pass[] = "12345678";  //Enter Password here
DHTesp dht;
PulseOximeter pox;
uint32_t tsLastReport = 0;
const int oneWireBus = 5;
OneWire oneWire(oneWireBus);
DallasTemperature sensors(&oneWire);
void onBeatDetected()
    Serial.println("Beat!");
 pinMode(2, INPUT); // Setup for leads off detection LO +
  pinMode(4, INPUT); // Setup for leads off detection LO -
   dht.setup(18, DHTesp::DHT11);
  sensors.begin();
//spo2/bpm
   if (!pox.begin())
         Serial.println("FAILED");
         for(;;);
         Serial.println("SUCCESS");
         pox.setOnBeatDetectedCallback(onBeatDetected);
    // The default current for the IR LED is 50mA and it could be changed by uncommenting the following line.
        pox.setIRLedCurrent(MAX30100_LED_CURR_7_6MA);
  xTaskCreate(
   ECG,
  "pehla",
  1000,
  NULL,
  1,
  NULL);
//timer.run();
//Blynk.run();
    for(;;){
 if((digitalRead(2) == 1)||(digitalRead(4) == 1)){
    Serial.println('!');
  else{
    // send the value of analog input 0:
      Serial.println(analogRead(36));
  //Wait for a bit to keep serial data from saturating
  delay(1);
    for(;;){
pox.update();
    BPM = pox.getHeartRate();
    SpO2 = pox.getSpO2();
    if (millis() - tsLastReport > REPORTING_PERIOD_MS)
        Serial.print("Heart rate:");
        Serial.print(BPM);
        Serial.print(" bpm / SpO2:");
        Serial.print(SpO2);
        Serial.println(" %");
           tsLastReport = millis();
    for(;;){
 sensors.requestTemperatures();
  float temperatureC = sensors.getTempCByIndex(0);
  float temperatureF = sensors.getTempFByIndex(0);
  Serial.print(temperatureC);
  Serial.println("ºC");
  Serial.print(temperatureF);
  Serial.println("ºF");
  delay(5000);
    for(;;){
float temperature = dht.getTemperature();
  float humidity = dht.getHumidity();
  Serial.print("Temperature: ");
  Serial.println(temperature);
  Serial.print("Humidity: ");
  Serial.println(humidity);
  delay(2000);
check you indentation
  //timer.run();
  //Blynk.run();
  void ECG(void*parameters) {
the ECG function definition appears within the loop function
Try to move all function definitions before setup()
whilst this is the proper thing to do, the IDE will cover for that. The issue is more how the code is indented, the functions are within the loop... just need to move the closing } of the loop to the right place, probably
  //timer.run();
  //Blynk.run();
} // <==== HERE
perhaps...
But according to the error message, this error is in the setup(), not loop()
yeah, in the setup he refers to the ECG function name and the compiler says it doesn't know about it. The reason for that is that the function is not declared properly because its definition is within the loop, so then compiler has no clue what ECG stands for as the IDE did not create the usual forward declarations
You are right that in correct C++, you need to declare something before using it. But the IDE has your back and generates the forward declaration for you correctly most of the time if you place the function's definition later in the code
thanks guys
