name=custom board
version=1.0.0
compiler.pt32.extra_include=-I{C:\Users\komal.int70\AppData\Local\Arduino15\packages\custom\hardware\arm\1.0.0\core\my_core}/my_core -I{C:\Users\komal.int70\AppData\Local\Arduino15\packages\custom\hardware\arm\1.0.0\core\my_core}/my_core
compiler.warning_flags=-w
compiler.warning_flags.none=-w
compiler.optimization_flags=-Og -g
compiler.path={runtime.tools.arm-none-eabi-gcc.path}/bin/
compiler.S.cmd=arm-none-eabi-gcc
compiler.c.cmd=arm-none-eabi-gcc
compiler.cpp.cmd=arm-none-eabi-g++
compiler.ar.cmd=arm-none-eabi-gcc-ar
compiler.c.elf.cmd=arm-none-eabi-gcc
compiler.objcopy.cmd=arm-none-eabi-objcopy
compiler.elf2hex.cmd=arm-none-eabi-objcopy
compiler.cpp.std=gnu17
compiler.S.flags={compiler.extra_flags} -c -x assembler-with-cpp {compiler.stm.extra_include}
compiler.c.flags={compiler.extra_flags} -c {compiler.optimization_flags} {compiler.warning_flags} -std={compiler.c.std} -ffunction-sections -fdata-sections --param max-inline-insns-single=500 -MMD {compiler.stm.extra_include}
compiler.cpp.flags={compiler.extra_flags} -c {compiler.optimization_flags} {compiler.warning_flags} -std={compiler.cpp.std} -ffunction-sections -fdata-sections -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -fno-use-cxa-atexit -MMD {compiler.stm.extra_include}
These can be overridden in boards.txt
build.st_extra_flags=
build.extra_flags=
build.bootloader_flags=
build.ldscript=ldscript.ld
build.variant_h=variant_generic.h
compiler.c.st_extra_flags={build.peripheral_pins}
compiler.c.std=gnu17
compiler.cpp.std=gnu++11
compiler.S.st_extra_flags={build.startup_file}
compiler.arm.cmsis.c.flags="-IC:\Users\komal.int70\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0\CMSIS\Include" "-I{C:\Users\komal.int70\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.0.0\CMSIS\Device\ATMEL}"
Specify defaults for vid/pid
build.vid=0
build.pid=-1
Build information's
build.info.flags=-D{build.series} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} -DBOARD_NAME="{build.board}" -DVARIANT_H="{build.variant_h}"
Defaults config
build.xSerial=-DHAL_UART_MODULE_ENABLED
build.flags.optimize=-Os
build.flags.debug=-DNDEBUG
build.flags.ldspecs=--specs=nano.specs
Compile patterns
Compile c files
recipe.c.o.pattern="{compiler.path}{compiler.c.cmd}" {compiler.c.flags} {build.info.flags} {compiler.c.st_extra_flags} {compiler.c.extra_flags} {build.st_extra_flags} {build.extra_flags} {compiler.arm.cmsis.c.flags} {includes} "{source_file}" -o "{object_file}"
Compile c++ files
recipe.cpp.o.pattern="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} {build.info.flags} {compiler.cpp.extra_flags} {build.st_extra_flags} {build.extra_flags} {compiler.arm.cmsis.c.flags} {includes} "{source_file}" -o "{object_file}"
this my platform.txt file and i'm getting error which i have mention below is the error i'm facing
:0:1: error: macro names must be identifiers
C:\Users\komal.int70\AppData\Local\Temp\arduino\sketches\3FBF1BA18EF95D3BB2E0F72EB1CE272F\sketch\sketch_mar29a.ino.cpp:1:10: fatal error: Arduino.h: No such file or directory
#include <Arduino.h>
compilation terminated.
exit status 1
Compilation error: exit status 1
