Getting error in the code of nRF24L01 transceivers. Need help.
Hello Guys,
I was trying a simple chat example using 2 nRF24L01 and two Arduino Uno boards. My code is as below. I am getting some errors. When I run code I am getting errors as below.
nRF24_Serial_Chat.ino: In function 'void nRF_receive()':
nRF24_Serial_Chat:110: error: void value not ignored as it ought to be
I have shared the code.
Please guys help me to get rid of the error. Its urgent.
nRF Serial Chat
this simple interactive serial chat over nRF that can be used for both sender
and receiver as I swapped the TX & RX addr during read/write operation.
It read input from Serial Monitor and display the output to the other side
Serial Monitor or 16x2 LCD (if available)... like a simple chat program.
Max payload is 32 bytes for radio but the serialEvent will chopped the entire buffer
for next payload to be sent out sequentially.
#include <LiquidCrystal.h>
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
LiquidCrystal lcd(10, 7, 3, 4, 5, 6);
RF24 radio(8,9);
const uint64_t pipes[2] = { 0xDEDEDEDEE7LL, 0xDEDEDEDEE9LL };
boolean stringComplete = false;  // whether the string is complete
static int dataBufferIndex = 0;
boolean stringOverflow = false;
char charOverflow = 0;
char SendPayload[31] = "";
char RecvPayload[31] = "";
char serialBuffer[31] = "";
void setup(void) {
  Serial.begin(57600);
  lcd.begin(16,2);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("RF Chat V0.90");
  printf_begin();
  radio.begin();
  radio.setDataRate(RF24_250KBPS);
  radio.setPALevel(RF24_PA_MAX);
  radio.setChannel(70);
  radio.enableDynamicPayloads();
  radio.setRetries(15,15);
  radio.setCRCLength(RF24_CRC_16);
  radio.openWritingPipe(pipes[0]);
  radio.openReadingPipe(1,pipes[1]);
  radio.startListening();
  radio.printDetails();
  Serial.println("RF Chat V0.90");
  lcd.clear();
void loop(void) {
  nRF_receive();
  serial_receive();
} // end loop()
void serialEvent() {
  while (Serial.available() > 0 ) {
      char incomingByte = Serial.read();
      if (stringOverflow) {
         serialBuffer[dataBufferIndex++] = charOverflow;  // Place saved overflow byte into buffer
         serialBuffer[dataBufferIndex++] = incomingByte;  // saved next byte into next buffer
         stringOverflow = false;                          // turn overflow flag off
      } else if (dataBufferIndex > 31) {
         stringComplete = true;        // Send this buffer out to radio
         stringOverflow = true;        // trigger the overflow flag
         charOverflow = incomingByte;  // Saved the overflow byte for next loop
         dataBufferIndex = 0;          // reset the bufferindex
      else if(incomingByte=='\n'){
          serialBuffer[dataBufferIndex] = 0;
  } // end while()
} // end serialEvent()
void nRF_receive(void) {
  int len = 0;
  if ( radio.available() ) {
      bool done = false;
      while ( !done ) {
        len = radio.getDynamicPayloadSize();
        done = radio.read(&RecvPayload,len);
        delay(5);
    RecvPayload[len] = 0; // null terminate string
    lcd.setCursor(0,0);
    lcd.print("R:");
    Serial.print("R:");
    lcd.setCursor(2,0);
    lcd.print(RecvPayload);
    Serial.print(RecvPayload);
    RecvPayload[0] = 0;  // Clear the buffers
} // end nRF_receive()
void serial_receive(void){
  if (stringComplete) {
        strcat(SendPayload,serialBuffer);
        // swap TX & Rx addr for writing
        radio.openWritingPipe(pipes[1]);
        radio.openReadingPipe(0,pipes[0]);
        radio.stopListening();
        bool ok = radio.write(&SendPayload,strlen(SendPayload));
        lcd.setCursor(0,1);
        lcd.print("S:");
        Serial.print("S:");
        lcd.setCursor(2,1);
        lcd.print(SendPayload);
        Serial.print(SendPayload);
        // restore TX & Rx addr for reading
        SendPayload[0] = 0;
  } // endif
} // end serial_receive()
This compiles using IDE ver 1.04 with no errors after commenting out the #include printf.h and printf.begin(): statements. I guess the printf.h file is not on my system. You don't seem to use printf() anywhere, anyway.
I am using IDE version 1.6.4. And after commenting commenting out the #include printf.h and printf.begin(): statements, I am still getting same errors.
I think it seems like in "{void nRF_receive(void)" function, line "done = radio.read(&RecvPayload,len);" has error. If i comment that line, I don't get any errors. But I need that line.
I tried to add Radio Head library but still getting the same error. Its really urgent.
Thanks.
