hi everyone !
i'm still experimenting with the liquidCrystal library , i tried this code :
#include<LiquidCrystal.h>
void setup(){
LiquidCrystal lcd(12,11,5,4,3,2);
lcd.begin(16,2);
byte custom[8]={B00000,B11111,B00000,B11111,B00000,B11111,B00000,B11111};
lcd.createChar(1,custom);
void loop(){
lcd.write(1);
delay(5000);
but i get the error message " lcd was not declared in this scope " .
i tried re-defining the lcd variable inside the loop bloc and it worked but why do i get this error ? i thought i only had to define variables in the setup bloc only , not twice ( in the setup AND in the loop bloc) :~ i would apreciate your help
oh and i also noticed another issue !!
after i modified the code to this :
void setup(){
lcd.begin(16,2);
byte custom_one[8]={B00000,B11111,B00000,B11111,B00000,B11111,B00000,B11111};
byte custom_two[8]={B
void loop(){
lcd.begin(16,2);
lcd.write(1);
delay(5000);
lcd.clear();
the programm worked fine ( displaying four separate horizontal lines ) , but after the second or third loop , i notice that an unexpected line appears between the two top horizontal lines so i get three horizontal lines with no space between them and two separate lines at the bottom please help
