Getting error message while trying to compile code related to uno gsm shield
While trying to compile the following code, i get the following error message. I don't understand the error. please help.
I use a gsm shield using sim900. the libraries are attached.
#include <GSM_Shield.h>
char number[]="+39123456789";  //Destination number
char text[]="hello world";  //SMS to send
byte type_sms=SMS_UNREAD;      //Type of SMS
byte del_sms=0;                //0: No deleting sms - 1: Deleting SMS
GSM gsm;
char sms_rx[122]; //Received text SMS
//int inByte=0;    //Number of byte received on serial port
char number_incoming[20];
int call;
int error;
  Serial.println("system startup");
  gsm.TurnOn(9600);          //module power on
  gsm.InitParam(PARAM_SET_1);//configure the module
  gsm.Echo(0);               //enable AT echo
  char inSerial[5];
  int i=0;
  delay(2000);
    Check_Call(); //Check if there is an incoming call
    Check_SMS();  //Check if there is SMS
    //Check data serial com
    if (Serial.available() > 0)
       while (Serial.available() > 0) {
         inSerial[i]=(Serial.read()); //read data
         i++;
       inSerial[i]='\0';
      Check_Protocol(inSerial);
void Check_Protocol(String inStr)
       Serial.print("Command: ");
       Serial.println(inStr);
  Serial.println("Check_Protocol");
    switch (inStr[0])
       case 'a' :  //Answer
           if (gsm.CallStatus()==CALL_INCOM_VOICE){
             gsm.PickUp();
             Serial.println("Answer");
             Serial.println("No incoming call");
       case 'c': // C  //Call
         if (inStr.length()<2)  //To call variable 'number'    comand   c
           Serial.print("Calling ");
           Serial.println(number);
           gsm.Call(number);
         if (inStr.length()==2)  //To call number in phone book position   comand   cx where x is the SIM position
             error=gsm.GetPhoneNumber(inStr[1],number);
             if (error!=0)
               gsm.Call(number);
               Serial.print("No number in pos ");
               Serial.println(inStr[1]);
       case 'h': //H //HangUp if there is an incoming call
         if (gsm.CallStatus()!=CALL_NONE)
           Serial.println("Hang");
           gsm.HangUp();
       case 's': //S //Send SMS
         Serial.print("Send SMS to ");
         error=gsm.SendSMS(number,text);
         if (error==0)  //Check status
             Serial.println("SMS ERROR \n");
             Serial.println("SMS OK \n");
       case 'p':  //Read-Write Phone Book
         if (inStr.length()==3)
           switch (inStr[1])
             case 'd':  //Delete number in specified position  pd2
               error=gsm.DelPhoneNumber(inStr[2]);
               if (error!=0)
                 Serial.print("Phone number position ");
                 Serial.print(inStr[2]);
                 Serial.println(" deleted");
             case 'g':  //Read from Phone Book position      pg2
               error=gsm.GetPhoneNumber(inStr[2],number);
               if (error!=0)  //Find number in specified position
                 Serial.print("Phone Book position ");
                 Serial.print(": ");
               else  //Not find number in specified position
                 Serial.print("No Phone number in position ");
                 Serial.println(inStr[2]);
             case 'w':  //Write from Phone Book Position    pw2
               error=gsm.WritePhoneNumber(inStr[2],number);
               if (error!=0)
                 Serial.print("Number ");
                 Serial.print(number);
                 Serial.print(" writed in Phone Book position ");
               else Serial.println("Writing error");
    delay(1500);
    return;
 void Check_Call()  //Check status call if this is available
     call=gsm.CallStatus();
     switch (call)
       case CALL_NONE:
         Serial.println("no call");
       case CALL_INCOM_VOICE:
         gsm.CallStatusWithAuth(number_incoming,0,0);
         Serial.print("incoming voice call from ");
         Serial.println(number_incoming);
       case CALL_ACTIVE_VOICE:
         Serial.println("active voice call");
       case CALL_NO_RESPONSE:
         Serial.println("no response");
     return;
 void Check_SMS()  //Check if there is an sms 'type_sms'
     char pos_sms_rx;  //Received SMS position
     pos_sms_rx=gsm.IsSMSPresent(type_sms);
     if (pos_sms_rx!=0)
       //Read text/number/position of sms
       gsm.GetSMS(pos_sms_rx,number_incoming,sms_rx,120);
       Serial.print("Received SMS from ");
       Serial.print(number_incoming);
       Serial.print("(sim position: ");
       Serial.print(word(pos_sms_rx));
       Serial.println(")");
       Serial.println(sms_rx);
       if (del_sms==1)  //If 'del_sms' is 1, i delete sms
         error=gsm.DeleteSMS(pos_sms_rx);
         if (error==1)Serial.println("SMS deleted");
         else Serial.println("SMS not deleted");
     return;
error message
In file included from /usr/share/arduino/libraries/GSM_Shield/GSM_Shield.h:11:0,
                 from GSM_Shield_Test.pde:14:
/usr/share/arduino/libraries/GSM_Shield/NewSoftSerial.h:71:16: error: conflicting return type specified for ‘virtual void NewSoftSerial::write(uint8_t)’
   virtual void write(uint8_t byte);
In file included from /usr/share/arduino/hardware/arduino/cores/arduino/Stream.h:26:0,
                 from /usr/share/arduino/hardware/arduino/cores/arduino/HardwareSerial.h:28,
                 from /usr/share/arduino/hardware/arduino/cores/arduino/Arduino.h:193,
                 from /usr/share/arduino/libraries/GSM_Shield/GSM_Shield.h:10,
/usr/share/arduino/hardware/arduino/cores/arduino/Print.h:48:20: error:   overriding ‘virtual size_t Print::write(uint8_t)’
     virtual size_t write(uint8_t) = 0;
GSM_Shield.h (8.12 KB)
NewSoftSerial.h (3.32 KB)
point to the library you use.
Try disable the softwareserial lib - may be conflicting.
Tried disabling SoftwareSerial. Got the same error message. Is there a problem in the syntax of NewSoftSerial?
I have IDE 1.0.6
Its got GSM lib and SoftwareSerial (which i belive IS the 'newSoftwareSerial')
seems odd that additional lib is neede..
Can you point to that lib u're using ?
The GSM library that comes with IDE is meant for using with shield consisting of "Quectel_M10 " IC. Since I use sim900, I searched on the forum and found this GSM_Shield library. NewSoftSerial came with it.
Which version of the IDE are you using?
Any solution for this problem?
tjarduino:
Yes. Fire up a text editor, and change NewSoftSerial to SoftwareSerial.
