getting error message while uploading
Board:arduino UNO
Servo:SG90
error:Arduino: 1.8.5 (Windows 10), Board: “Arduino/Genuino Uno”
Sketch uses 5590 bytes (17%) of program storage space. Maximum is 32256 bytes.
Global variables use 278 bytes (13%) of dynamic memory, leaving 1770 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can’t open device “\.\COM1”: The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
“Show verbose output during compilation”
option enabled in File → Preferences.
code:/*NOTE: Four Servos of the Robotic Arm are connected to 4 PWM Pins of Arduino
and these 4 servos are named a, b, c and d.
If you want to control servo a, then type “90a/”,
where “90” is the PWM value (range is 0 - 255),
“a” means servo a and “/” is string parse delimiter.
Some other examples: 100a/ or 120b/ or 40c/ or 25d/
String readString;
int x=90, y=90, z=90, p=90;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;
myservoa.attach(3);
myservob.attach(5);
myservoc.attach(6);
myservod.attach(9);
myservoa.write(x);
myservob.write(y);
myservoc.write(z);
myservod.write(p);
if (Serial.available())
char m = Serial.read();
if (m == ‘/’)
if (readString.length() >1)
Serial.println(readString);
int temp = readString.toInt();
Serial.print("writing Angle: ");
Serial.println(temp);
if(readString.indexOf(‘a’) >=0)
if (temp>x)
for (int i=x; i<temp; i++)
myservoa.write(i);
delay(10);
x=temp;
for (int i=x; i>temp; i–)
myservoa.write(i);
delay(30);
x=temp;
if(readString.indexOf(‘b’) >=0)
if (temp>y)
for (int i=y; i<temp; i++)
{ myservob.write(i);
delay(10);
y=temp;
for (int i=y; i>temp; i–)
myservob.write(i);
delay(10);
y=temp;
if(readString.indexOf(‘c’) >=0) //myservoc.write(n);
if (temp>z)
for (int i=z; i<temp; i++)
{myservoc.write(i);
delay(10);}
z=temp;
for (int i=z; i>temp; i–)
myservoc.write(i);
delay(10);
z=temp;
if(readString.indexOf(‘d’) >=0)
if (temp>p)
for (int i=p; i<temp; i++)
myservod.write(i);
delay(10);
p=temp;
for (int i=p; i>temp; i–)
myservod.write(i);
delay(30);
p=temp;
readString="";
readString += m;
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn’t show the posting toolbar then you can just manually add the code tags:
[code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
Please always do a Tools > Auto Format on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read. If you’re using the Arduino Web Editor you will not have access to this useful tool but it’s still unacceptable to post poorly formatted code. I recommend you to use the standard IDE instead.
Select the port of your Arduino from the Tools > Port menu. If that menu is grayed out or the port of your Arduino board is not shown then one of the following may be the cause:
  • You may need to install the driver for the USB-serial chip on your Arduino. Determine which chip is used on your Arduino and install the driver.
  • You may be using a charge-only or defective USB cable. Test your cable on another device to confirm that it works for data.
