Hello. I am using Adafruit's TFTLCD library to drive a 2.8in ILI9341 display, however when trying to compile my code several errors show up with things that are not in explicitly in my program(excluding libraries), namely errors from the TFTLCD library.
Below is my code:
#include <Adafruit_GFX.h>
#include <Adafruit_TFTLCD.h>
#include <SPI.h>
#include <Keypad.h>
#include <ctype.h> //for keypad, refer to github
#define USE_ADAFRUIT_SHIELD_PINOUT 0
#define LCD_CS 40 //chip select
#define LCD_CD 41 //data in
#define LCD_WR 42 //write
#define LCD_RD 43 //read
#define LCD_RESET 9 //reset pin
#define BLACK 0x0000 //colour definitions, taken from TFTLCD library
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET); //display declaration
int modeButton = 36; //shift button, hold-enable, release-disable, separate from main matrix
volatile bool state = false; //init pin state
int modeButton2 = 35; //alpha button, hold-enable, release-disable, separate from main matrix
volatile bool state2 = false; //init pin state
const byte ROWS = 4;
const byte COLS = 4;
char standardKeys[ROWS][COLS] = {
{'7','8','9','+'},
{'4','5','6','-'},
{'1','2','3','/'},
{'0','.','=','*'}
char shiftKeys[ROWS][COLS] = {
{'sin','cos','tan','+'},
{'pi','sqrt','pow','-'},
{'x','y','z','/'},
{'x10pow','.','=','*'}
char alphaKeys[ROWS][COLS] = {
{'sin-1','cos-1','tan-1','+'},
{'e','cbsqrt','log','-'}, //'e' for euler's number
{'a','b','c','/'},
boolean shift = false; // disable shifted and alpha keypads on startup
boolean alpha = false;
boolean standard = true;
byte rowPins[ROWS] = {40, 39, 38, 37};
byte colPins[COLS] = {22, 23, 24, 25};
Keypad stdpad( makeKeymap(standardKeys), rowPins, colPins, sizeof(rowPins), sizeof(colPins) ); //defining keypads for standard, shifted and alpha keys
Keypad shfpad( makeKeymap(shiftKeys), rowPins, colPins, sizeof(rowPins), sizeof(colPins) );
Keypad alhpad( makeKeymap(alphaKeys), rowPins, colPins, sizeof(rowPins), sizeof(colPins) );
unsigned long startTime;
float y; // y=mx+c, linear equation
float m;
float x;
float c;
float a; // ax+bx^2+c, quadratic equation(x and c reused)
float b;
float pi = 3.14159;
int xmin;
int xmax = -xmin;
static const uint8_t PROGMEM boot[] =
//new bmp required for new display
void shiftPressed() //shift ISR
if (digitalRead(20) == HIGH)
state = true;
state = false;
void alphaPressed() //alpha ISR
if (digitalRead(21) == HIGH)
state2 = true;
state2 = false;
char key;
pinMode(20, INPUT);
pinMode(21, INPUT);
stdpad.begin( makeKeymap(standardKeys) );
shfpad.begin( makeKeymap(shiftKeys) );
alhpad.begin( makeKeymap(alphaKeys) );
stdpad.addEventListener(KeypadEvent(standardKeys));
stdpad.setHoldTime(500);
shfpad.addEventListener(KeypadEvent(shiftKeys));
shfpad.setHoldTime(500);
alhpad.addEventListener(KeypadEvent(alphaKeys));
alhpad.setHoldTime(500);
pinMode(modeButton, INPUT);
attachInterrupt(digitalPinToInterrupt(36), shiftPressed, RISING);
pinMode(modeButton2, INPUT);
attachInterrupt(digitalPinToInterrupt(35), alphaPressed, RISING);
tft.begin(); //automatically assumes ILI9341 driver IC
tft.fillScreen(BLACK); // clear screen
tft.drawXBitmap(0, 0, boot, 240, 320, WHITE); //boot bitmap
struct formula
String sy;
String sm;
String sc;
String sx;
String sa;//other variables for more complex equations, c already included previously
String sb;
if(state == true); //disable all other keymaps other than activated
standard = false;
alpha = false;
shift = true;
if(state2 == true); //disable all other keymaps other than activated
shift = false;
standard = false;
alpha = true;
if(state && state2 == false); // default, if both shift and alpha keys are disengaged standard mode is enabled
shift = false;
alpha = false;
standard = true;
if( shift ) {
key = shfpad.getKey( );
if( alpha )
key = alhpad.getKey( );
key = stdpad.getKey( );
and here are the errors I am getting when verifying:
In file included from c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp:17:0:
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\pin_magic.h:467:2: error: #error "Board type unsupported / not recognized"
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::write8(uint8_t)':
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp:1102:47: error: 'write8inline' was not declared in this scope
void Adafruit_TFTLCD::write8(uint8_t value) { write8inline(value); }
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp:1102:47: note: suggested alternative: 'writeLine'
writeLine
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp: In member function 'uint8_t Adafruit_TFTLCD::read8fn()':
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp:1108:3: error: 'read8inline' was not declared in this scope
read8inline(result);
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp:1108:3: note: suggested alternative: 'read8fn'
read8fn
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::setWriteDir()':
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp:1114:43: error: 'setWriteDirInline' was not declared in this scope
void Adafruit_TFTLCD::setWriteDir(void) { setWriteDirInline(); }
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp:1114:43: note: suggested alternative: 'setWriteDir'
setWriteDir
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::setReadDir()':
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp:1118:42: error: 'setReadDirInline' was not declared in this scope
void Adafruit_TFTLCD::setReadDir(void) { setReadDirInline(); }
c:\Users\user\OneDrive\Documents\Arduino\libraries\Adafruit_TFTLCD_Library\Adafruit_TFTLCD.cpp:1118:42: note: suggested alternative: 'setReadDir'
setReadDir
exit status 1
Compilation error: exit status 1
How do I fix these errors? For context, I am attempting to make a calculator with a 1284P as its core using said display, hence the need for the Keypad and TFTLCD libraries. Any help would be greatly appreciated.
