Getting error running processing code from example08a
I'm getting an error when I try running the code from the Example 08A: Arduino networked lamp (Processing code). The error I get is "cannot find a class or type named "URL". It stops at this line
    URL url = new URL(feed);  // An object to represent the URL
This is the whole code
// Example 08A: Arduino networked lamp
// parts of the code are inspired
// by a blog post by Tod E. Kurt (todbot.com)
// Copy and paste this example into an empty Processing sketch
import processing.serial.*;
String feed = "http://blog.makezine.com/index.xml";
int interval = 10;  // retrieve feed every 60 seconds;
int lastTime;       // the last time we fetched the content
int love    = 0;
int peace   = 0;
int arduino = 0;
int light = 0;  // light level measured by the lamp
Serial port;
color c;
String cs;
String buffer = ""; // Accumulates characters coming from Arduino
PFont font;
  size(640,480);
  frameRate(10);    // we don't need fast updates
  font = loadFont("HelveticaNeue-Bold-32.vlw");
  fill(255);
  textFont(font, 32);
  // IMPORTANT NOTE:
  // The first serial port retrieved by Serial.list()
  // should be your Arduino. If not, uncomment the next
  // line by deleting the // before it, and re-run the
  // sketch to see a list of serial ports. Then, change
  // the 0 in between [ and ] to the number of the port
  // that your Arduino is connected to.
  //println(Serial.list());
  String arduinoPort = Serial.list()[0];
  port = new Serial(this, arduinoPort, 9600); // connect to Arduino
  lastTime = 0;
  fetchData();
void draw() {
  background( c );
  int n = (interval - ((millis()-lastTime)/1000));
  // Build a colour based on the 3 values
  c = color(peace, love, arduino);
  cs = "#" + hex(c,6); // Prepare a string to be sent to Arduino
  text("Arduino Networked Lamp", 10,40);
  text("Reading feed:", 10, 100);
  text(feed, 10, 140);
  text("Next update in "+ n + " seconds",10,450);
  text("peace" ,10,200);
  text(" " + peace, 130, 200);
  rect(200,172, peace, 28);
  text("love ",10,240);
  text(" " + love, 130, 240);
  rect(200,212, love, 28);
  text("arduino ",10,280);
  text(" " + arduino, 130, 280);
  rect(200,252, arduino, 28);
  // write the colour string to the screen
  text("sending", 10, 340);
  text(cs, 200,340);
  text("light level", 10, 380);
  rect(200, 352,light/10.23,28); // this turns 1023 into 100
  if (n <= 0) {
    fetchData();
    lastTime = millis();
  port.write(cs); // send data to Arduino
  if (port.available() > 0) { // check if there is data waiting
    int inByte = port.read(); // read one byte
    if (inByte != 10) { // if byte is not newline
      buffer = buffer + char(inByte); // just add it to the buffer
    else {
      // newline reached, let's process the data
      if (buffer.length() > 1) { // make sure there is enough data
        // chop off the last character, it's a carriage return
        // (a carriage return is the character at the end of a
        // line of text)
        buffer = buffer.substring(0,buffer.length() -1);
        // turn the buffer from string into an integer number
        light = int(buffer);
        // clean the buffer for the next read cycle
        buffer = "";
        // We're likely falling behind in taking readings
        // from Arduino. So let's clear the backlog of
        // incoming sensor readings so the next reading is
        // up-to-date.
        port.clear();
void fetchData() {
  // we use these strings to parse the feed
  String data;
  String chunk;
  // zero the counters
  love    = 0;
  peace   = 0;
  arduino = 0;
  try {
    // prepare a connection
    URLConnection conn = url.openConnection();
    conn.connect(); // now connect to the Website
    // this is a bit of virtual plumbing as we connect
    // the data coming from the connection to a buffered
    // reader that reads the data one line at a time.
    BufferedReader in = new
      BufferedReader(new InputStreamReader(conn.getInputStream()));
    // read each line from the feed
    while ((data = in.readLine()) != null) {
      StringTokenizer st =
        new StringTokenizer(data,"\"<>,.()[] ");// break it down
      while (st.hasMoreTokens()) {
        // each chunk of data is made lowercase
        chunk= st.nextToken().toLowerCase() ;
        if (chunk.indexOf("love") >= 0 ) // found "love"?
          love++;    // increment love by 1
        if (chunk.indexOf("peace") >= 0)   // found "peace"?
          peace++;   // increment peace by 1
        if (chunk.indexOf("arduino") >= 0) // found "arduino"?
          arduino++; // increment arduino by 1
    // Set 64 to be the maximum number of references we care about.
    if (peace > 64)   peace = 64;
    if (love > 64)    love = 64;
    if (arduino > 64) arduino = 64;
    peace = peace * 4;     // multiply by 4 so that the max is 255,
    love = love * 4;       // which comes in handy when building a
    arduino = arduino * 4; // colour that is made of 4 bytes (ARGB)
  catch (Exception ex) { // If there was an error, stop the sketch
    ex.printStackTrace();
    System.out.println("ERROR: "+ex.getMessage());
-Antikythera
Is that in a book somewhere?
What version of Processing are you using?
Perhaps have a peek at this thread:
I am using the newest version of the program for mac os. I did see that post but I didn't understand what was being said "You use 2.0b7. Which cuts off most default imports, so you must type them explicitly now.
import java.net.URL;
or
import java.net.*;"
I was not too sure what was being said there. Where would I be typing this in the code? I'm new to this but Im trying to learn. Yes, it was in the book getting stated with arduino. There wasn't too much information for trouble shooting.
Thank you for taking a look PaulS.
What part didn't you understand?
You use 2.0b7.
You either are or you aren't.
So, what version is it? When you start Processing, it tells you in the title bar.
This seems pretty straightforward.
You could look at the code. See if you can find an appropriate point. Perhaps with the other import statement(s).
If you get it wrong, the compiler will be happy to laugh at you.
It's version 2.0
I think I found an appropriate place to put the "import java.net.URL" line of code. I'm guessing since I'm still learning that it would come after import processing.serial.*; I could be wrong but I will give this a shot.
I added those lines of code mentioned from another forum and now Im getting a new error just like in that other post       BufferedReader(new InputStreamReader(conn.getInputStream()));
The person said they fixed it when they found out all they needed was the java API. Does this mean I have to insert all the packages from the Java API list?
