Getting error when to upload a sketch
When i try to upload a sketch it says
avrdude: verification error, first mismatch at byte 0x0000
0x14 != 0x08
avrdude: verification error; content mismatch
this happen after i upload sketch relating to gsm
Can you upload simple example programs such as Blink ?
Nope still getting the same error.. :confused:
rangotz:
0x14 != 0x08
Search google or the troubleshooting forum with your error message:
It looks like a problem that has nothing to do with your program.
Alright thanks..does it something related to the bootloader?
Check the board that you have selected in the IDE. Does it match the board that you are using ?
Help im keep getting this error when try to upload a sketch even the simplest one such as the blink..
0x14 != 0x08
does this error is something related to the bootloader?
Checked em all ..the ports , processor ..still getting the same error
rangotz:
What hardware do you have attached to the Arduino? Nothing, nada, zip, zilch is the ONLY correct answer at this point.
This problem occurs when i attached a rs232 converter to the board...because im trying to connect with a gsm modem..but i failed to get the gsm connected to the arduino though..after i remove the converter the error still persist ..
rangotz:
Do you have another board to check?
(Some people seem to think it is an actual hardware memory problem. Search THIS forum for your error message, someone has posted a memory checker...)
Sadly this is the only board i got...but i will try to meet my friend later he has another one..can i reflash the bootloader? using this method Gammon Forum : Electronics : Microprocessors : Atmega bootloader programmer
rangotz:
Can I reflash the bootloader? using this method Gammon Forum : Electronics : Microprocessors : Atmega bootloader programmer
Sorry, totally beyond my knowledge...
What board?
How are you uploading to it?
I'm using mega 2560..using the usb..now when I try to upload any sketches this error pop up..
Do not cross-post. Threads merged.
