hey
i'm writing a line follower code on arduino and motor shield
i'm getting alot of errors tring to verify the code
here is the code :
#include <AFMotor.h>
const int Sensor1 = 2;
const int Sensor2 = 3;
const int Sensor3 = 4;
const int Sensor4 = 5;
const int Sensor5 = 6;
int SensorState1 = 0;
int SensorState2 = 0;
int SensorState3 = 0;
int SensorState4 = 0;
int SensorState5 = 0;
AF_DCMotor MotorR(1, MOTOR12_64KHZ);
AF_DCMotor MotorL(2, MOTOR12_64KHZ);
pinMode(Sensor1, INPUT);
pinMode(Sensor2, INPUT);
pinMode(Sensor3, INPUT);
pinMode(Sensor4, INPUT);
MotorL.setSpeed(255);
MotorR.setSpeed(255);
SensorState1 = digitalRead(Sensor1);
SensorState2 = digitalRead(Sensor2);
SensorState3 = digitalRead(Sensor3);
SensorState4 = digitalRead(Sensor4);
SensorState5 = digitalRead(Sensor5);
if (SensorState1 == HIGH) {Serial.print("black1"); Serial.print(" "); }
if (SensorState1 == LOW){Serial.print("white1");Serial.print(" "); }
if (SensorState2 == HIGH) {Serial.print("black2"); Serial.print(" ");}
if (SensorState2 == LOW) {Serial.print("white2");Serial.print(" "); }
if (SensorState3 == HIGH) {Serial.print("black3"); Serial.print(" "); }
if (SensorState3 == LOW) {Serial.print("white3"); Serial.print(" ");}
if (SensorState4 == HIGH) {Serial.print("black4"); Serial.print(" "); }
if (SensorState4 == LOW) {Serial.print("white4"); Serial.print(" ");}
if (SensorState5 == HIGH) {Serial.println("black5"); }
if (SensorState5 == LOW) {Serial.println("white5"); }
if (SensorState1 == HIGH) && (SensorState5 == HIGH) && (SensorState2 == HIGH) && (SensorState3 == HIGH) && (SensorState4 == HIGH)
MotorR.run(FORWARD);
MotorL.run(FORWARD);
else if (SensorState1 == LOW) && (SensorState5 == LOW) && (SensorState2 == HIGH) && (SensorState3 == HIGH) && (SensorState4 == HIGH)
{ MotorR.run(FORWARD);
MotorL.run(FORWARD);}
else if (SensorState1 == LOW) && (SensorState5 == LOW) && (SensorState2 == LOW) && (SensorState3 == HIGH) && (SensorState4 == LOW)
else if (SensorState1 == HIGH) && (SensorState5 == LOW) && (SensorState2 == HIGH) && (SensorState3 == HIGH) && (SensorState4 == LOW)
{ MotorR.run(RELEASE);
else if (SensorState1 == LOW) && (SensorState5 == HIGH) && (SensorState2 == LOW) && (SensorState3 == HIGH) && (SensorState4 == HIGH)
MotorL.run(RELEASE);}
basically the Errors are:
1-In function 'void loop()':
2- error: expected identifier before '(' token
3- error: expected `;' before '(' token
any help wil be useful
