Getting errors while compiling the GSM test codes
Hi everyone,
My OBJECTIVE: perfoming basic tests on “GSM/GPRS Modem” not shield.
i have gsm/gprs modem with me and i am trying to do some basics tests for this i choose the following code and this code is from the site
and the code is
 This example test if your modem is working correctly.
 Circuit:
 * GSM shield attached (using digital pins 2, 3, and 7)
 Created 12 Jun 2012
 by David del Peral
 modified 21 Nov 2012
 by Tom Igoe
// libraries
#include <GSM.h>
// modem verification object
GSMModem modem;
// IMEI variable
String IMEI = "";
  // initialize serial communications
  // start modem test (reset and check response)
  Serial.print("Starting modem test...");
  if(modem.begin())
    Serial.println("modem.begin() succeeded");
    Serial.println("ERROR, no modem answer.");
  // get modem IMEI
  Serial.print("Checking IMEI...");
  IMEI = modem.getIMEI();
  // check IMEI response
  if(IMEI != NULL)
    // show IMEI in serial monitor
    Serial.println("Modem's IMEI: " + IMEI);
    // reset modem to check booting:
    Serial.print("Reseting modem...");
    modem.begin();
    // get and check IMEI one more time
    if(modem.getIMEI() != NULL)
      Serial.println("Modem is functoning properly");
      Serial.println("Error: getIMEI() failed after modem.begin()");
    Serial.println("Error: Could not get IMEI");
  // do nothing:
  while(true);
to compile this code i have to include the GSM.h file, i have downloaded this from the following link
https://code.google.com/p/gsm-shield-arduino/source/browse/branches/GSMSHIELD/GSM.h?r=102
here i am not adding this file because the header file contains too many lines…
when i am compiling the code i am getting the following errors
GSM_IMEI_testing.cpp:9:1: error: ‘GSMModem’ does not name a type
GSM_IMEI_testing.cpp: In function ‘void setup()’:
GSM_IMEI_testing.cpp:19:4: error: ‘modem’ was not declared in this scope
GSM_IMEI_testing.cpp: In function ‘void loop()’:
GSM_IMEI_testing.cpp:28:8: error: ‘modem’ was not declared in this scope
anyone reading this post please help me out how to overcome this error. and any mistakes i’ve done please correct me…
where can i get the GSM.h,SMS.h and GPRS related libraries can anyone post a link…
thanks in advance…
Which modem? The code on the page you linked to is ONLY for the GSM shield that the Arduino store sells.
They come with the IDE. No need to download them.
why it is showing this error????
Perhaps it doesn't like your poor spelling.
is there any other way to check the Modem is properly working or not???
If the modem wasn't working (to some degree, at least), you wouldn't have gotten to the point where you got the error you couldn't be bothered researching.
hi,
I'm having same problem as.... ysrinivas described above. im getting error -
error: 'GSMModem' does not name a type
In function 'void IMEI_number()':
error: 'modem' was not declared in this scope
Plz tell me how to come out from this errors.
ysrinivas was asked for more details. None were supplied. It seems rather pointless to say that you are having the same problem, without supplying any more details, and still expect to get help.
