Getting gibberish from the GPS modules (BN-280 and Neo-6M)
I have Arduino UNO and two GPS modules BN-280 and Neo-6M
this is my code
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
  Serial.begin(57600);
  Serial.println("Hello");
  mySerial.begin(4800);
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
I connected the modules one by one at following way:
VCC <–> 5v
GND <–> GND
TX <–> 2
and at serial monitor I see the following:
for BN-280
09:50:09.073 -> Hello
09:50:09.530 -> "⸮bj⸮jjjj*⸮a⸮S⸮⸮jjjj⸮⸮⸮"⸮cjjj⸮⸮⸮L⸮⸮⸮⸮)퍄⸮⸮M⸮⸮⸮⸮⸮⸮M⸮KM⸮KM⸮Kn⸮⸮⸮D⸮⸮⸮⸮⸮⸮⸮⸮⸮KL⸮KL⸮KL⸮퍃"MMm⸮H퍅"MMm⸮퍄⸮⸮⸮⸮⸮⸮⸮⸮
for NEO-6M
10:02:46.551 -> Hello
10:02:46.723 -> ).-⸮⸮⸮⸮⸮⸮i⸮J⸮
⸮⸮⸮⸮⸮⸮i9>
⸮⸮⸮ʊ⸮⸮⸮⸮⸮ɈJ⸮
-⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮i)..⸮⸮⸮⸮⸮i).M⸮⸮⸮⸮⸮i).-⸮⸮⸮⸮⸮⸮i⸮J⸮
⸮⸮⸮⸮⸮⸮i).
⸮⸮⸮ʊ⸮⸮⸮⸮⸮ɈJ⸮
⸮⸮⸮⸮⸮⸮i).
⸮⸮⸮ʊ⸮⸮⸮⸮⸮ɈJ⸮
-⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮i)..⸮⸮⸮ʪɩ⸮⸮i).M⸮⸮⸮⸮⸮i).-⸮⸮⸮⸮⸮⸮i⸮J⸮
⸮⸮⸮⸮⸮⸮i)>
⸮⸮⸮ʊ⸮⸮⸮⸮⸮ɈJ(
-⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮i)..⸮⸮⸮⸮⸮i9.M⸮⸮⸮⸮⸮i).-⸮⸮⸮⸮⸮⸮i⸮Z⸮
⸮⸮⸮⸮⸮⸮i9.
⸮⸮⸮ʊ⸮⸮⸮⸮⸮ɈJ⸮
⸮⸮⸮⸮⸮⸮i).
⸮⸮⸮ʊ⸮⸮⸮⸮⸮ɈJ⸮
-⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮i)..⸮⸮⸮⸮⸮i).M⸮⸮⸮⸮⸮i).-⸮⸮⸮⸮⸮⸮i⸮J(
⸮⸮⸮⸮⸮⸮i).⸮⸮⸮ʊ⸮⸮⸮⸮⸮ɈJ⸮
-⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮i)..⸮⸮⸮ʪɩ⸮+i).M⸮⸮⸮⸮⸮i
what I am doing wrong?
Looks like mismatching baud rates. Did you try 9600 in mySerial?
Dmitry,
I duplicated your arrangement with a UNO and a Neo-6M.
Using "mySerial.begin(9600);" it puts correct NMEA sentences to the monitor.
If you ever suspect a problem with the sketch, try this:
. TX of the GPS to pin 1 of the UNO
. open monitor at 9600 baud
. press and hold the UNO's reset button
The NMEA sentences should appear on the monitor (no sketch required).
Also, observe the UNO's onboard leds labelled TX & RX. This helps understand what's happening.
Good luck.
John.
Hi Jpom,
your suggestion to use baud 9600 was very helpful, and indeed resolved the issue with Neo-6M :slight_smile:
But not for BN-280 - there I still getting gibberish
[⸮m⸮坧S⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮c⸮⸮w⸮⸮qcSWq⸮⸮⸮⸮⸮⸮⸮⸮⸮c⸮⸮u⸮⸮qcqq}⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮qcqY}⸮}⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮u⸮⸮qcqY}⸮}⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮u⸮⸮q_qYS⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮qgqYS⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮qcqgg⸮⸮⸮⸮⸮⸮S⸮c⸮⸮}⸮⸮
any ideas?
DmitrySotnikov:
any ideas?
Try a different baud rate perhaps ?
Dmitry,
Looks like a baud rate mismatch. Until you see the NMEA sentences there's no point worrying about sat fix.
U-blox's software "u-center" is an essential tool. Gives you far more information and diagnostic help than an Arduino can.
Download it from u-blox (no cost). I've only used it on a Neo-6M but I expect it will work with any manufacturer's unit that generates standard NMEA sentences.
John.
