Getting 'Guru Meditation Error: Core 0 panic'ed (LoadProhibited)' error on BLE_client side
Greetings!
I'm getting this error and I don't know why. I have added some debugging statements but didn't work.
Can someone look into this.
Device found. Connecting!
  • Connected to server
  • Found our characteristics
    We are now connected to the BLE Server.
    Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x40090eb6 PS : 0x00060930 A0 : 0x800d7eeb A1 : 0x3ffcfa60
A2 : 0x3ffe0800 A3 : 0x00000000 A4 : 0x00000001 A5 : 0x0000000c
A6 : 0xb33fffff A7 : 0xb33fffff A8 : 0x00000000 A9 : 0x00000000
A10 : 0x00000001 A11 : 0x00001800 A12 : 0x00000000 A13 : 0x3ffb657c
A14 : 0x00001004 A15 : 0x00000001 SAR : 0x00000014 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x40090f10 LEND : 0x40090f1b LCOUNT : 0x00000000
Backtrace: 0x40090eb3:0x3ffcfa60 0x400d7ee8:0x3ffcfa80 0x400d800a:0x3ffcfaa0 0x400d4b51:0x3ffcfac0 0x400d5363:0x3ffcfb10 0x400d3ab5:0x3ffcfb30 0x400d4325:0x3ffcfbc0 0x400ea0b6:0x3ffcfc10 0x400ea76a:0x3ffcfc30 0x40115dd9:0x3ffcfc80 0x40118b79:0x3ffcfca0 0x40095d76:0x3ffcfcd0
ELF file SHA256: 266b32c50dffd1b9
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1448
load:0x40078000,len:14844
ho 0 tail 12 room 4
load:0x40080400,len:4
load:0x40080404,len:3356
entry 0x4008059c
Client Device started working.
Here is the code:
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEScan.h>
#include <BLEAdvertisedDevice.h>
#include <BLEClient.h>
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
#define bleServerName "ESP32_BLE_JSON_Server"
// Flags stating if should begin connecting and if the connection is up
static bool doConnect = false;
static bool connected = false;
BLEAddress *pServerAddress = nullptr; // Declare pServerAddress
BLEClient* pClient;
BLERemoteCharacteristic* pRemoteCharacteristic;
class MyClientCallback : public BLEClientCallbacks {
  void onConnect(BLEClient* pclient) override {
    Serial.println("Client connected");
  void onDisconnect(BLEClient* pclient) override {
    connected = false;
    Serial.println("Client disconnected");
class MyAdvertisedDeviceCallbacks : public BLEAdvertisedDeviceCallbacks {
  void onResult(BLEAdvertisedDevice advertisedDevice) override {
    Serial.print("Advertised Device found: ");
    Serial.println(advertisedDevice.toString().c_str());
    if (advertisedDevice.getName() == bleServerName) { // Check if the name of the advertiser matches
      advertisedDevice.getScan()->stop(); // Scan can be stopped, we found what we are looking for
      pServerAddress = new BLEAddress(advertisedDevice.getAddress()); // Address of advertiser is the one we need
      doConnect = true; // Set indicator, stating that we are ready to connect
      Serial.println("Device found. Connecting!");
// Connect to the BLE Server that has the name, Service, and Characteristics
bool connectToServer(BLEAddress pAddress) {
  Serial.println("Attempting to connect to server...");
  BLEClient* pClient = BLEDevice::createClient();
  pClient->setClientCallbacks(new MyClientCallback());
  // Connect to the remote BLE Server.
  pClient->connect(pAddress);
  Serial.println(" - Connected to server");
  // Obtain a reference to the service we are after in the remote BLE server.
  BLERemoteService* pRemoteService = pClient->getService(SERVICE_UUID);
  if (pRemoteService == nullptr) {
    Serial.print("Failed to find our service UUID: ");
    Serial.println(SERVICE_UUID); // Print directly
    pClient->disconnect();
    return false;
  // Obtain a reference to the characteristic in the service of the remote BLE server.
  pRemoteCharacteristic = pRemoteService->getCharacteristic(CHARACTERISTIC_UUID);
  if (pRemoteCharacteristic == nullptr) {
    Serial.print("Failed to find our characteristic UUID");
    return false;
  Serial.println(" - Found our characteristics");
  connected = true;
  return true;
  BLEDevice::init("ESP32_BLE_JSON_Client");
  Serial.println("Client Device started working.");
  BLEScan* pBLEScan = BLEDevice::getScan();
  pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
  pBLEScan->setActiveScan(true);
  pBLEScan->start(30);
  if (doConnect) {
    if (connectToServer(*pServerAddress)) {
      Serial.println("We are now connected to the BLE Server.");
      Serial.println("We have failed to connect to the server; there is nothing more we will do.");
    doConnect = false;
  if (connected) {
    if (pRemoteCharacteristic != nullptr && pRemoteCharacteristic->canRead()) {
      std::string value = pRemoteCharacteristic->readValue(); // Use std::string
      Serial.print("Received value: ");
      Serial.println(value.c_str()); // Convert std::string to C string for printing
      Serial.println("Characteristic is not readable or is null.");
    delay(1000); // Add a delay to avoid flooding the Serial Monitor
You tried to use a bad address. Run the ESP Exception Decoder to get the path to the error.
Alright, after decoding it, I got this. Can you guide further?
PC: 0x40090eb6: memmove at /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/string/memmove.c line 75
Decoding stack results
0x40090eb3: memmove at /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/string/memmove.c line 66
0x400d8250: String::move(String&) at C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32\WString.cpp line 242
0x400d8372: String::operator=(String&&) at C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\cores\esp32\WString.cpp line 284
0x400d4c11: BLERemoteCharacteristic::gattClientEventHandler(esp_gattc_cb_event_t, unsigned char, esp_ble_gattc_cb_param_t*) at C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\BLE\src\BLERemoteCharacteristic.cpp line 182
0x400d5423: BLERemoteService::gattClientEventHandler(esp_gattc_cb_event_t, unsigned char, esp_ble_gattc_cb_param_t*) at C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\BLE\src\BLERemoteService.cpp line 107
0x400d3b75: BLEClient::gattClientEventHandler(esp_gattc_cb_event_t, unsigned char, esp_ble_gattc_cb_param_t*) at C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\BLE\src\BLEClient.cpp line 359
0x400d43e5: BLEDevice::gattClientEventHandler(esp_gattc_cb_event_t, unsigned char, esp_ble_gattc_cb_param_t*) at C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.2\libraries\BLE\src\BLEDevice.cpp line 158
0x40095d76: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c line 162
The top entry on the stack is where the exception occurred. The following entries show the call path to get there. Typically toward the bottom of the stack will be some user code where the problem started. Your case is unusual in that the stack seems to all be system code. That may be because it is a core 0 dump which is where system code typically runs. Is there an additional dump for core 1?
The problem may be in this area
since that is doing a String copy in this code
