Ok, this was completly my bad...
The code is pretty extensive, 1100+ lines.
Here is the link of the code: CodePile | Easily Share Piles of Code
the part I show in post#1 is in line 920 to 930
Sorry.
I leave the code in here too, but this doesn't have lines:
const char* ssid = "***"; //your network SSID
const char* password = "***"; //your network password
const char* apssid = "***";
const char* appassword = "***";
// Initialize Telegram BOT
#define BOTtoken "***" // your Bot Token (Get from Botfather)
// Use @myidbot to find out the chat ID of an individual or a group
// Also note that you need to click "start" on a bot before it can
// message you
#define CHAT_ID "***"
#include <WiFi.h>
#include <esp32-hal-ledc.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
#include <ArduinoJson.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "esp_camera.h"
#include "esp_http_server.h"
#include "esp_timer.h"
#include "img_converters.h"
#include "fb_gfx.h"
#include "fd_forward.h"
#include <Wire.h>
#include <Adafruit_MLX90614.h>
String newChatID = "";
String outputPhoto = "";
float tempValues[25] = {};
String Feedback="";
String Command="";
String cmd="";
String P1="";
String P2="";
String P3="";
String P4="";
String P5="";
String P6="";
String P7="";
String P8="";
String P9="";
byte ReceiveState=0;
byte cmdState=1;
byte strState=1;
byte questionstate=0;
byte equalstate=0;
byte semicolonstate=0;
typedef struct {
size_t size;
size_t index;
size_t count;
int sum;
int * values;
} ra_filter_t;
typedef struct {
httpd_req_t *req;
size_t len;
} jpg_chunking_t;
WiFiClientSecure client;
UniversalTelegramBot bot(BOTtoken, client);
// Checks for new messages every 1 second.
int botRequestDelay = 1000;
unsigned long lastTimeBotRan;
// Handle what happens when you receive new messages
void handleNewMessages(int numNewMessages) {
Serial.println("handleNewMessages");
Serial.println(String(numNewMessages));
for (int i=0; i<numNewMessages; i++) {
// Chat id of the requester
String chat_id = String(bot.messages[i].chat_id);
newChatID = chat_id;
if (chat_id != CHAT_ID){
bot.sendMessage(chat_id, "Unauthorized user", "");
continue;
// Print the received message
String text = bot.messages[i].text;
Serial.println(text);
String from_name = bot.messages[i].from_name;
// type this to start the bot.
if (text == "/start") {
String welcome = "Service has started.";
Serial.println(welcome);
// example for photos
String photoURL = "";
if (text == "/photo") {
//doesn't need the if
//only send this command with photo string to telegram.
bot.sendMessage(chat_id, photoURL, "");
// or - needs testing.
bot.sendPhoto(chat_id, photoURL, "person", false);
#define PART_BOUNDARY "123456789000000000000987654321"
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
static ra_filter_t ra_filter;
httpd_handle_t stream_httpd = NULL;
httpd_handle_t camera_httpd = NULL;
static ra_filter_t * ra_filter_init(ra_filter_t * filter, size_t sample_size){
memset(filter, 0, sizeof(ra_filter_t));
filter->values = (int *)malloc(sample_size * sizeof(int));
if(!filter->values){
return NULL;
memset(filter->values, 0, sample_size * sizeof(int));
filter->size = sample_size;
return filter;
static int ra_filter_run(ra_filter_t * filter, int value){
return value;
filter->sum -= filter->values[filter->index];
filter->values[filter->index] = value;
filter->sum += filter->values[filter->index];
filter->index++;
filter->index = filter->index % filter->size;
if (filter->count < filter->size) {
filter->count++;
return filter->sum / filter->count;
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
Serial.setDebugOutput(true);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
#ifdef ESP32
client.setCACert(TELEGRAM_CERTIFICATE_ROOT); // Add root certificate for api.telegram.org
#endif
if(psramFound()){
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10; //0-63 lower number means higher quality
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12; //0-63 lower number means higher quality
config.fb_count = 1;
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
ESP.restart();
sensor_t * s = esp_camera_sensor_get();
s->set_framesize(s, FRAMESIZE_QVGA); //UXGA|SXGA|XGA|SVGA|VGA|CIF|QVGA|HQVGA|QQVGA
ledcAttachPin(4, 4);
ledcSetup(4, 5000, 8);
WiFi.mode(WIFI_AP_STA);
//WiFi.config(IPAddress(192, 168, 201, 100), IPAddress(192, 168, 201, 2), IPAddress(255, 255, 255, 0));
WiFi.begin(ssid, password);
Serial.println("");
Serial.print("Connecting to ");
Serial.println(ssid);
long int StartTime=millis();
if ((StartTime+10000) < millis()) break;
if (WiFi.status() == WL_CONNECTED) {
WiFi.softAP((WiFi.localIP().toString()+"_"+(String)apssid).c_str(), appassword);
Serial.println("");
Serial.println("STAIP address: ");
for (int i=0;i<5;i++) {
ledcWrite(4,10);
delay(200);
ledcWrite(4,0);
delay(200);
else {
WiFi.softAP((WiFi.softAPIP().toString()+"_"+(String)apssid).c_str(), appassword);
for (int i=0;i<2;i++) {
ledcWrite(4,10);
ledcWrite(4,0);
//WiFi.softAPConfig(IPAddress(192, 168, 4, 1), IPAddress(192, 168, 4, 1), IPAddress(255, 255, 255, 0));
Serial.println("");
Serial.println("APIP address: ");
Serial.println(WiFi.softAPIP());
startCameraServer();
pinMode(4, OUTPUT);
pinMode(33,OUTPUT);
digitalWrite(4, LOW);
pinMode(16,OUTPUT);
pinMode(13, OUTPUT);
if (!mlx.begin()) {
Serial.println("Error connecting to MLX sensor. Check wiring.");
//while (1);
/*Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempC());
Serial.print("*C\tObject = "); Serial.print(mlx.readObjectTempC()); Serial.println("*C");
Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempF());
Serial.print("*F\tObject = "); Serial.print(mlx.readObjectTempF()); Serial.println("*F");
Serial.println();*/
if(P1=="Mask") {
/*digitalWrite(13, HIGH);
int value = 0;
//while(P1=="Mask" || value != 25) {
Serial.print(" aaaaaa ");
AddTempValues(value);
delay(100);
value += 5;
for(int i = 0; i < value; i++) {
Serial.print(tempValues[i]);
Serial.print(" ");
if(P1=="No%20mask") {
Serial.println("aa" + outputPhoto);
bot.sendMessage(newChatID, outputPhoto, "");
bot.sendPhoto(newChatID, outputPhoto, "person", false);
// verify if the last bot ran.
// if the lastTime is a long time
// make new request.
if (millis() > lastTimeBotRan + botRequestDelay) {
int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
while(numNewMessages) {
Serial.println("got response");
handleNewMessages(numNewMessages);
lastTimeBotRan = millis();
void AddTempValues(int x) {
int init = x;
int fin = x + 5;
for(int i = init; i < fin; i++) {
float a = mlx.readObjectTempC();
Serial.println(a);
tempValues[i] = a;
delay(50);
static size_t jpg_encode_stream(void * arg, size_t index, const void* data, size_t len){
jpg_chunking_t *j = (jpg_chunking_t *)arg;
if(!index){
j->len = 0;
if(httpd_resp_send_chunk(j->req, (const char *)data, len) != ESP_OK){
return 0;
j->len += len;
return len;
static esp_err_t capture_handler(httpd_req_t *req){
camera_fb_t * fb = NULL;
esp_err_t res = ESP_OK;
int64_t fr_start = esp_timer_get_time();
fb = esp_camera_fb_get();
if (!fb) {
Serial.println("Camera capture failed");
httpd_resp_send_500(req);
return ESP_FAIL;
httpd_resp_set_type(req, "image/jpeg");
httpd_resp_set_hdr(req, "Content-Disposition", "inline; filename=capture.jpg");
httpd_resp_set_hdr(req, "Access-Control-Allow-Origin", "*");
size_t out_len, out_width, out_height;
uint8_t * out_buf;
bool s;
if(fb->width > 400){
size_t fb_len = 0;
if(fb->format == PIXFORMAT_JPEG){
fb_len = fb->len;
res = httpd_resp_send(req, (const char *)fb->buf, fb->len);
jpg_chunking_t jchunk = {req, 0};
res = frame2jpg_cb(fb, 80, jpg_encode_stream, &jchunk)?ESP_OK:ESP_FAIL;
httpd_resp_send_chunk(req, NULL, 0);
fb_len = jchunk.len;
esp_camera_fb_return(fb);
int64_t fr_end = esp_timer_get_time();
Serial.printf("JPG: %uB %ums\n", (uint32_t)(fb_len), (uint32_t)((fr_end - fr_start)/1000));
return res;
dl_matrix3du_t *image_matrix = dl_matrix3du_alloc(1, fb->width, fb->height, 3);
if (!image_matrix) {
Serial.println("dl_matrix3du_alloc failed");
return ESP_FAIL;
out_buf = image_matrix->item;
out_len = fb->width * fb->height * 3;
out_width = fb->width;
out_height = fb->height;
s = fmt2rgb888(fb->buf, fb->len, fb->format, out_buf);
if(!s){
dl_matrix3du_free(image_matrix);
Serial.println("to rgb888 failed");
return ESP_FAIL;
s = fmt2jpg_cb(out_buf, out_len, out_width, out_height, PIXFORMAT_RGB888, 90, jpg_encode_stream, &jchunk);
if(!s){
Serial.println("JPEG compression failed");
return ESP_FAIL;
return res;
static esp_err_t stream_handler(httpd_req_t *req){
size_t _jpg_buf_len = 0;
uint8_t * _jpg_buf = NULL;
char * part_buf[64];
dl_matrix3du_t *image_matrix = NULL;
int64_t fr_start = 0;
int64_t fr_ready = 0;
static int64_t last_frame = 0;
if(!last_frame) {
last_frame = esp_timer_get_time();
res = httpd_resp_set_type(req, _STREAM_CONTENT_TYPE);
if(res != ESP_OK){
return res;
while(true){
if (!fb) {
res = ESP_FAIL;
fr_ready = fr_start;
if(fb->format != PIXFORMAT_JPEG){
bool jpeg_converted = frame2jpg(fb, 80, &_jpg_buf, &_jpg_buf_len);
fb = NULL;
if(!jpeg_converted){
res = ESP_FAIL;
_jpg_buf_len = fb->len;
_jpg_buf = fb->buf;
res = ESP_FAIL;
if(!fmt2rgb888(fb->buf, fb->len, fb->format, image_matrix->item)){
Serial.println("fmt2rgb888 failed");
res = ESP_FAIL;
fr_ready = esp_timer_get_time();
if (fb->format != PIXFORMAT_JPEG){
if(!fmt2jpg(image_matrix->item, fb->width*fb->height*3, fb->width, fb->height, PIXFORMAT_RGB888, 90, &_jpg_buf, &_jpg_buf_len)){
Serial.println("fmt2jpg failed");
res = ESP_FAIL;
fb = NULL;
_jpg_buf = fb->buf;
if(res == ESP_OK){
size_t hlen = snprintf((char *)part_buf, 64, _STREAM_PART, _jpg_buf_len);
res = httpd_resp_send_chunk(req, (const char *)part_buf, hlen);
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, (const char *)_jpg_buf, _jpg_buf_len);
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, _STREAM_BOUNDARY, strlen(_STREAM_BOUNDARY));
if(fb){
fb = NULL;
_jpg_buf = NULL;
} else if(_jpg_buf){
free(_jpg_buf);
_jpg_buf = NULL;
if(res != ESP_OK){
int64_t ready_time = (fr_ready - fr_start)/1000;
int64_t frame_time = fr_end - last_frame;
last_frame = fr_end;
frame_time /= 1000;
uint32_t avg_frame_time = ra_filter_run(&ra_filter, frame_time);
Serial.printf("MJPG: %uB %ums (%.1ffps), AVG: %ums (%.1ffps), %u+%u+%u+%u=%u %s%d\n",
(uint32_t)(_jpg_buf_len),
(uint32_t)frame_time, 1000.0 / (uint32_t)frame_time,
avg_frame_time, 1000.0 / avg_frame_time
last_frame = 0;
return res;
static esp_err_t cmd_handler(httpd_req_t *req){
char* buf;
size_t buf_len;
char variable[128] = {0,};
char value[128] = {0,};
String myCmd = "";
buf_len = httpd_req_get_url_query_len(req) + 1;
if (buf_len > 1) {
buf = (char*)malloc(buf_len);
if(!buf){
return ESP_FAIL;
if (httpd_req_get_url_query_str(req, buf, buf_len) == ESP_OK) {
if (httpd_query_key_value(buf, "var", variable, sizeof(variable)) == ESP_OK &&
httpd_query_key_value(buf, "val", value, sizeof(value)) == ESP_OK) {
else {
myCmd = String(buf);
httpd_resp_send_404(req);
return ESP_FAIL;
Feedback="";Command="";cmd="";P1="";P2="";P3="";P4="";P5="";P6="";P7="";P8="";P9="";
ReceiveState=0,cmdState=1,strState=1,questionstate=0,equalstate=0,semicolonstate=0;
if (myCmd.length()>0) {
myCmd = "?"+myCmd;
for (int i=0;i<myCmd.length();i++) {
getCommand(char(myCmd.charAt(i)));
if (cmd.length()>0) {
//Serial.println("");
//Serial.println("Command: "+Command);
//Serial.println("cmd= "+cmd+" ,P1= "+P1+" ,P2= "+P2+" ,P3= "+P3+" ,P4= "+P4+" ,P5= "+P5+" ,P6= "+P6+" ,P7= "+P7+" ,P8= "+P8+" ,P9= "+P9);
if (cmd=="your cmd") {
// You can do anything
// Feedback="<font color=\"red\">Hello World</font>";
else if (cmd=="ip") {
Feedback="AP IP: "+WiFi.softAPIP().toString();
Feedback+="<br>";
Feedback+="STA IP: "+WiFi.localIP().toString();
else if (cmd=="mac") {
Feedback="STA MAC: "+WiFi.macAddress();
else if (cmd=="restart") {
ESP.restart();
else if (cmd=="digitalwrite") {
ledcDetachPin(P1.toInt());
pinMode(P1.toInt(), OUTPUT);
digitalWrite(P1.toInt(), P2.toInt());
else if (cmd=="digitalread") {
Feedback=String(digitalRead(P1.toInt()));
else if (cmd=="analogwrite") {
if (P1=="4") {
ledcWrite(4,P2.toInt());
else {
ledcAttachPin(P1.toInt(), 9);
ledcSetup(9, 5000, 8);
ledcWrite(9,P2.toInt());
else if (cmd=="analogread") {
Feedback=String(analogRead(P1.toInt()));
else if (cmd=="touchread") {
Feedback=String(touchRead(P1.toInt()));
else if (cmd=="flash") {
int val = P1.toInt();
ledcWrite(4,val);
else if (cmd=="serial") {
if (P1!=""&P1!="stop") Serial.print(P1); Serial.print(" ");
if (P2!=""&P2!="stop") Serial.println(P2);
else {
Feedback="Command is not defined";
if (Feedback=="") Feedback=Command;
const char *resp = Feedback.c_str();
httpd_resp_set_type(req, "text/html");
return httpd_resp_send(req, resp, strlen(resp));
else {
int val = atoi(value);
int res = 0;
if(!strcmp(variable, "framesize")) {
if(s->pixformat == PIXFORMAT_JPEG)
res = s->set_framesize(s, (framesize_t)val);
else if(!strcmp(variable, "quality")) res = s->set_quality(s, val);
else if(!strcmp(variable, "contrast")) res = s->set_contrast(s, val);
else if(!strcmp(variable, "brightness")) res = s->set_brightness(s, val);
else if(!strcmp(variable, "hmirror")) res = s->set_hmirror(s, val);
else if(!strcmp(variable, "vflip")) res = s->set_vflip(s, val);
else if(!strcmp(variable, "flash")) {
ledcWrite(4,val);
else {
res = -1;
if(res){
return httpd_resp_send_500(req);
if (buf) {
Feedback = String(buf);
else {
return httpd_resp_send(req, NULL, 0);
static esp_err_t status_handler(httpd_req_t *req){
static char json_response[1024];
char * p = json_response;
*p++ = '{';
p+=sprintf(p, "\"flash\":%d,", 0);
p+=sprintf(p, "\"framesize\":%u,", s->status.framesize);
p+=sprintf(p, "\"quality\":%u,", s->status.quality);
p+=sprintf(p, "\"brightness\":%d,", s->status.brightness);
p+=sprintf(p, "\"contrast\":%d,", s->status.contrast);
p+=sprintf(p, "\"hmirror\":%u,", s->status.hmirror);
p+=sprintf(p, "\"vflip\":%u", s->status.vflip);
*p++ = '}';
*p++ = 0;
httpd_resp_set_type(req, "application/json");
return httpd_resp_send(req, json_response, strlen(json_response));
static const char PROGMEM INDEX_HTML[] = R"rawliteral(<!doctype html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width,initial-scale=1">
<meta http-equiv="Access-Control-Allow-Headers" content="Origin, X-Requested-With, Content-Type, Accept">
<meta http-equiv="Access-Control-Allow-Methods" content="GET,POST,PUT,DELETE,OPTIONS">
<meta http-equiv="Access-Control-Allow-Origin" content="*">
<title>Teachable Machine-Nitesh Suthar</title>
<style>
body{font-family:Arial,Helvetica,sans-serif;background:#181818;color:#EFEFEF;font-size:16px}h2{font-size:18px}section.main{display:flex}#menu,section.main{flex-direction:column}#menu{display:flex;flex-wrap:nowrap;min-width:340px;background:#363636;padding:8px;border-radius:4px;margin-top:-10px;margin-right:10px}#content{display:flex;flex-wrap:wrap;align-items:stretch}figure{padding:0;margin:0;-webkit-margin-before:0;margin-block-start:0;-webkit-margin-after:0;margin-block-end:0;-webkit-margin-start:0;margin-inline-start:0;-webkit-margin-end:0;margin-inline-end:0}figure img{display:block;width:100%;height:auto;border-radius:4px;margin-top:8px}@media (min-width: 800px) and (orientation:landscape){#content{display:flex;flex-wrap:nowrap;align-items:stretch}figure img{display:block;max-width:100%;max-height:calc(100vh - 40px);width:auto;height:auto}figure{padding:0;margin:0;-webkit-margin-before:0;margin-block-start:0;-webkit-margin-after:0;margin-block-end:0;-webkit-margin-start:0;margin-inline-start:0;-webkit-margin-end:0;margin-inline-end:0}}section#buttons{display:flex;flex-wrap:nowrap;justify-content:space-between}#nav-toggle{cursor:pointer;display:block}#nav-toggle-cb{outline:0;opacity:0;width:0;height:0}#nav-toggle-cb:checked+#menu{display:none}.input-group{display:flex;flex-wrap:nowrap;line-height:22px;margin:5px 0}.input-group>label{display:inline-block;padding-right:10px;min-width:47%}.input-group input,.input-group select{flex-grow:1}.range-max,.range-min{display:inline-block;padding:0 5px}button{display:block;margin:5px;padding:0 12px;border:0;line-height:28px;cursor:pointer;color:#fff;background:#ff3034;border-radius:5px;font-size:16px;outline:0}button:hover{background:#ff494d}button:active{background:#f21c21}button.disabled{cursor:default;background:#a0a0a0}input[type=range]{-webkit-appearance:none;width:100%;height:22px;background:#363636;cursor:pointer;margin:0}input[type=range]:focus{outline:0}input[type=range]::-webkit-slider-runnable-track{width:100%;height:2px;cursor:pointer;background:#EFEFEF;border-radius:0;border:0 solid #EFEFEF}input[type=range]::-webkit-slider-thumb{border:1px solid rgba(0,0,30,0);height:22px;width:22px;border-radius:50px;background:#ff3034;cursor:pointer;-webkit-appearance:none;margin-top:-11.5px}input[type=range]:focus::-webkit-slider-runnable-track{background:#EFEFEF}input[type=range]::-moz-range-track{width:100%;height:2px;cursor:pointer;background:#EFEFEF;border-radius:0;border:0 solid #EFEFEF}input[type=range]::-moz-range-thumb{border:1px solid rgba(0,0,30,0);height:22px;width:22px;border-radius:50px;background:#ff3034;cursor:pointer}input[type=range]::-ms-track{width:100%;height:2px;cursor:pointer;background:0 0;border-color:transparent;color:transparent}input[type=range]::-ms-fill-lower{background:#EFEFEF;border:0 solid #EFEFEF;border-radius:0}input[type=range]::-ms-fill-upper{background:#EFEFEF;border:0 solid #EFEFEF;border-radius:0}input[type=range]::-ms-thumb{border:1px solid rgba(0,0,30,0);height:22px;width:22px;border-radius:50px;background:#ff3034;cursor:pointer;height:2px}input[type=range]:focus::-ms-fill-lower{background:#EFEFEF}input[type=range]:focus::-ms-fill-upper{background:#363636}.switch{display:block;position:relative;line-height:22px;font-size:16px;height:22px}.switch input{outline:0;opacity:0;width:0;height:0}.slider{width:50px;height:22px;border-radius:22px;cursor:pointer;background-color:grey}.slider,.slider:before{display:inline-block;transition:.4s}.slider:before{position:relative;content:"";border-radius:50%;height:16px;width:16px;left:4px;top:3px;background-color:#fff}input:checked+.slider{background-color:#ff3034}input:checked+.slider:before{-webkit-transform:translateX(26px);transform:translateX(26px)}select{border:1px solid #363636;font-size:14px;height:22px;outline:0;border-radius:5px}.image-container{position:relative;min-width:160px}.close{position:absolute;right:5px;top:5px;background:#ff3034;width:16px;height:16px;border-radius:100px;color:#fff;text-align:center;line-height:18px;cursor:pointer}.hidden{display:none}
</style>
<script src="https:\/\/ajax.googleapis.com/ajax/libs/jquery/1.8.0/jquery.min.js"></script>
<script src="https:\/\/cdn.jsdelivr.net/npm/@tensorflow/tfjs@1.3.1/dist/tf.min.js"></script>
<script src="https:\/\/cdn.jsdelivr.net/npm/@teachablemachine/image@0.8/dist/teachablemachine-image.min.js"></script>
<script src="https:\/\/cdn.jsdelivr.net/npm/@teachablemachine/pose@0.8/dist/teachablemachine-pose.min.js"></script>
</head>
<body>
<section class="main">
<figure>
<div id="stream-container" class="image-container hidden">
<div class="close" id="close-stream" style="display:none">×</div>
<img id="stream" src="" style="display:none" crossorigin="anonymous">
<canvas id="canvas" width="0" height="0"></canvas>
</div>
</figure>
<section id="buttons">
<table>
<tr><td><button id="restart" onclick="try{fetch(document.location.origin+'/control?restart');}catch(e){}">Restart</button></td><td><button id="get-still" style="display:none">Get Still</button></td><td><button id="toggle-stream" style="display:none"></td></tr>
</table>
</section>
<div id="logo">
<label for="nav-toggle-cb" id="nav-toggle">☰ Toggle settings</label>
</div>
<div id="content">
<div id="sidebar">
<input type="checkbox" id="nav-toggle-cb">
<nav id="menu">
<div class="input-group">
<label for="kind">Kind</label>
<select id="kind">
<option value="image" selected>image</option>
<option value="pose">pose</option>
</select>
</div>
<div class="input-group" style="display:none;">
<label for="modelPath">Model Path</label>
<input type="text" id="modelPath" value=https://teachablemachine.withgoogle.com/models/XHqAtmRxi/> // edit your Teachable machine Model
</div>
<label for="btnModel"></label>
<button type="button" id="btnModel" onclick="LoadModel();">Start Recognition</button>
</div>
<div class="input-group" id="flash-group">
<label for="flash">Flash</label>
<div class="range-min">0</div>
<input type="range" id="flash" min="0" max="255" value="0" class="default-action">
<div class="range-max">255</div>
</div>
<div class="input-group" id="framesize-group">
<label for="framesize">Resolution</label>
<select id="framesize" class="default-action">
<option value="10">UXGA(1600x1200)</option>
<option value="9">SXGA(1280x1024)</option>
<option value="8">XGA(1024x768)</option>
<option value="7">SVGA(800x600)</option>
<option value="6">VGA(640x480)</option>
<option value="5" selected="selected">CIF(400x296)</option>
<option value="4">QVGA(320x240)</option>
<option value="3">HQVGA(240x176)</option>
<option value="0">QQVGA(160x120)</option>
</select>
</div>
<div class="input-group" id="quality-group">
<label for="quality">Quality</label>
<div class="range-min">10</div>
<input type="range" id="quality" min="10" max="63" value="10" class="default-action">
<div class="range-max">63</div>
</div>
<div class="input-group" id="brightness-group">
<label for="brightness">Brightness</label>
<div class="range-min">-2</div>
<input type="range" id="brightness" min="-2" max="2" value="0" class="default-action">
<div class="range-max">2</div>
</div>
<div class="input-group" id="contrast-group">
<label for="contrast">Contrast</label>
<input type="range" id="contrast" min="-2" max="2" value="0" class="default-action">
</div>
<div class="input-group" id="hmirror-group">
<label for="hmirror">H-Mirror</label>
<div class="switch">
<input id="hmirror" type="checkbox" class="default-action" checked="checked">
<label class="slider" for="hmirror"></label>
</div>
</div>
<div class="input-group" id="vflip-group">
<label for="vflip">V-Flip</label>
<input id="vflip" type="checkbox" class="default-action" checked="checked">
<label class="slider" for="vflip"></label>
</div>
</div>
</nav>
</div>
</div>
</section>
<br>
<div id="result" style="color:red"><div>
<script>
document.addEventListener('DOMContentLoaded', function (event) {
var baseHost = document.location.origin
var streamUrl = baseHost + ':81'
const hide = el => {
el.classList.add('hidden')
const show = el => {
el.classList.remove('hidden')
const disable = el => {
el.classList.add('disabled')
el.disabled = true
const enable = el => {
el.classList.remove('disabled')
el.disabled = false
const updateValue = (el, value, updateRemote) => {
updateRemote = updateRemote == null ? true : updateRemote
let initialValue
if (el.type === 'checkbox') {
initialValue = el.checked
value = !!value
el.checked = value
initialValue = el.value
el.value = value
if (updateRemote && initialValue !== value) {
updateConfig(el);
function updateConfig (el) {
let value
switch (el.type) {
case 'checkbox':
value = el.checked ? 1 : 0
break
case 'range':
case 'select-one':
value = el.value
break
case 'button':
case 'submit':
value = '1'
break
default:
return
const query = `${baseHost}/control?var=${el.id}&val=${value}`
fetch(query)
.then(response => {
console.log(`request to ${query} finished, status: ${response.status}`)
document
.querySelectorAll('.close')
.forEach(el => {
el.onclick = () => {
hide(el.parentNode)
// read initial values
fetch(`${baseHost}/status`)
.then(function (response) {
return response.json()
.then(function (state) {
document
.querySelectorAll('.default-action')
.forEach(el => {
updateValue(el, state[el.id], false)
const view = document.getElementById('stream')
const viewContainer = document.getElementById('stream-container')
const stillButton = document.getElementById('get-still')
const streamButton = document.getElementById('toggle-stream')
const closeButton = document.getElementById('close-stream')
const stopStream = () => {
//window.stop();
view.src="";
streamButton.innerHTML = 'Start Stream'
const startStream = () => {
view.src = `${streamUrl}/stream`
show(viewContainer)
streamButton.innerHTML = 'Stop Stream'
// Attach actions to buttons
stillButton.onclick = () => {
stopStream()
try{
view.src = `${baseHost}/capture?_cb=${Date.now()}`
catch(e) {
show(viewContainer)
closeButton.onclick = () => {
stopStream()
hide(viewContainer)
streamButton.onclick = () => {
const streamEnabled = streamButton.innerHTML === 'Stop Stream'
if (streamEnabled) {
stopStream()
startStream()
// Attach default on change action
document
.forEach(el => {
el.onchange = () => updateConfig(el)
</script>
<script>
var getStill = document.getElementById('get-still');
var ShowImage = document.getElementById('stream');
var canvas = document.getElementById("canvas");
var context = canvas.getContext("2d");
var modelPath = document.getElementById('modelPath');
var result = document.getElementById('result');
var kind = document.getElementById('kind');
let Model;
async function LoadModel() {
if (modelPath.value=="") {
result.innerHTML = "Please input model path.";
return;
result.innerHTML = "Please wait for loading model.";
const URL = modelPath.value;
const modelURL = URL + "model.json";
const metadataURL = URL + "metadata.json";
if (kind.value=="image") {
Model = await tmImage.load(modelURL, metadataURL);
else if (kind.value=="pose") {
Model = await tmPose.load(modelURL, metadataURL);
maxPredictions = Model.getTotalClasses();
result.innerHTML = "";
getStill.style.display = "block";
getStill.click();
LoadModel();
async function predict() {
var data = "";
var maxClassName = "";
var maxProbability = "";
canvas.setAttribute("width", ShowImage.width);
canvas.setAttribute("height", ShowImage.height);
context.drawImage(ShowImage, 0, 0, ShowImage.width, ShowImage.height);
var prediction = await Model.predict(canvas);
var { pose, posenetOutput } = await Model.estimatePose(canvas);
var prediction = await Model.predict(posenetOutput);
if (maxPredictions>0) {
for (let i = 0; i < maxPredictions; i++) {
if (i==0) {
maxClassName = prediction[i].className;
maxProbability = prediction[i].probability;
a = prediction[1].probability.toFixed(2);
else {
if (prediction[i].probability>maxProbability) {
data += prediction[i].className + "," + prediction[i].probability.toFixed(2) + "<br>";
result.innerHTML = data;
result.innerHTML += "<br>Result: " + maxClassName + "," + maxProbability;
$.ajax({url: document.location.origin+'/control?serial='+maxClassName+";"+maxProbability+';stop', async: false});
result.innerHTML = "Unrecognizable";
getStill.click();
ShowImage.onload = function (event) {
if (Model) {
try {
document.createEvent("TouchEvent");
setTimeout(function(){predict();},250);
catch(e) {
predict();
</script>
</body>
</html>)rawliteral";
static esp_err_t index_handler(httpd_req_t *req){
return httpd_resp_send(req, (const char *)INDEX_HTML, strlen(INDEX_HTML));
void startCameraServer(){
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
//http://192.168.xxx.xxx/
httpd_uri_t index_uri = {
.uri = "/",
.method = HTTP_GET,
.handler = index_handler,
.user_ctx = NULL
//http://192.168.xxx.xxx/status
httpd_uri_t status_uri = {
.uri = "/status",
.method = HTTP_GET,
.handler = status_handler,
.user_ctx = NULL
//http://192.168.xxx.xxx/control
httpd_uri_t cmd_uri = {
.uri = "/control",
.method = HTTP_GET,
.handler = cmd_handler,
.user_ctx = NULL
//http://192.168.xxx.xxx/capture
httpd_uri_t capture_uri = {
.uri = "/capture",
.method = HTTP_GET,
.handler = capture_handler,
.user_ctx = NULL
//http://192.168.xxx.xxx:81/stream
httpd_uri_t stream_uri = {
.uri = "/stream",
.method = HTTP_GET,
.handler = stream_handler,
.user_ctx = NULL
ra_filter_init(&ra_filter, 20);
Serial.printf("Starting web server on port: '%d'\n", config.server_port); //Server Port
if (httpd_start(&camera_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(camera_httpd, &index_uri);
httpd_register_uri_handler(camera_httpd, &cmd_uri);
httpd_register_uri_handler(camera_httpd, &status_uri);
httpd_register_uri_handler(camera_httpd, &capture_uri);
config.server_port += 1; //Stream Port
config.ctrl_port += 1; //UDP Port
Serial.printf("Starting stream server on port: '%d'\n", config.server_port);
if (httpd_start(&stream_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(stream_httpd, &stream_uri);
void getCommand(char c)
if (c=='?') ReceiveState=1;
if ((c==' ')||(c=='\r')||(c=='\n')) ReceiveState=0;
if (ReceiveState==1)
Command=Command+String(c);
if (c=='=') cmdState=0;
if (c==';') strState++;
if ((cmdState==1)&&((c!='?')||(questionstate==1))) cmd=cmd+String(c);
if ((cmdState==0)&&(strState==1)&&((c!='=')||(equalstate==1))) P1=P1+String(c);
if ((cmdState==0)&&(strState==2)&&(c!=';')) P2=P2+String(c);
if ((cmdState==0)&&(strState==3)&&(c!=';')) P3=P3+String(c);
if ((cmdState==0)&&(strState==4)&&(c!=';')) P4=P4+String(c);
if ((cmdState==0)&&(strState==5)&&(c!=';')) P5=P5+String(c);
if ((cmdState==0)&&(strState==6)&&(c!=';')) P6=P6+String(c);
if ((cmdState==0)&&(strState==7)&&(c!=';')) P7=P7+String(c);
if ((cmdState==0)&&(strState==8)&&(c!=';')) P8=P8+String(c);
if ((cmdState==0)&&(strState>=9)&&((c!=';')||(semicolonstate==1))) P9=P9+String(c);
if (c=='?') questionstate=1;
if (c=='=') equalstate=1;
if ((strState>=9)&&(c==';')) semicolonstate=1;
