Below is my Arduino code
#include <ArduinoJson.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
const char* ssid = "YourWiFiSSID"; // Replace with your WiFi SSID
const char* password = "YourWiFiPassword"; // Replace with your WiFi password
const char* apiEndpoint = "http:///api/iotData/"; // Replace with your Django API endpoint
connectToWiFi();
if (Serial.available() > 0) {
String receivedData = Serial.readStringUntil('\n');
// Check if the received data is not empty
if (!receivedData.isEmpty()) {
Serial.println("Received Data: " + receivedData);
processSerialData(receivedData);
void processSerialData(String data) {
DynamicJsonDocument jsonDoc(1024);
DeserializationError error = deserializeJson(jsonDoc, data);
if (error) {
Serial.print("Deserialization error: ");
Serial.println(error.c_str());
return;
float temperature = jsonDoc["temperature"].as(); // Ensure float type
float pHValue = jsonDoc["pHValue"].as(); // Ensure float type
int turbidity = jsonDoc["turbidity"].as(); // Ensure integer type
// Print received values (optional)
Serial.print("Temperature: ");
Serial.println(temperature);
Serial.print("pH Value: ");
Serial.println(pHValue);
Serial.print("Turbidity: ");
Serial.println(turbidity);
// Send data to Django API
sendDataToDjangoAPI(temperature, pHValue, turbidity);
// Clear the JSON document
jsonDoc.clear();
void sendDataToDjangoAPI(float temperature, float pHValue, int turbidity) {
if (WiFi.status() == WL_CONNECTED) {
HTTPClient http;
// Construct the JSON payload
String payload = "{\"temperature\":" + String(temperature, 2) +
",\"pHValue\":" + String(pHValue, 2) +
",\"turbidity\":" + String(turbidity) + "}";
// Make the HTTP POST request
WiFiClient client;
http.begin(client, apiEndpoint);
http.addHeader("Content-Type", "application/json");
int httpCode = http.POST(payload);
if (httpCode == HTTP_CODE_OK) {
Serial.println("Data sent successfully!");
Serial.println(http.getString());
Serial.print("HTTP Error code: ");
Serial.println(httpCode);
// Disconnect
http.end();
void connectToWiFi() {
// Connect to WiFi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi!");
Below is the error keeping showing up
23:11:59.090 -> HTTP Error code: -1
23:11:59.121 -> Received Data: 0.004883,"turbidity":628}23:11:59.154 -> Deserialization error: InvalidInput
23:11:59.186 -> Received Data: {"temperature":-127,"pHValue":0.004883,"turbidity":627}23:11:59.249 -> Temperature: -127.00
23:11:59.281 -> pH Value: 0.00
23:11:59.326 -> Turbidity: 627
Can anyone please help me
Please ignore the readings
