I am using someone else's code, and running into a problem with it, and not understanding where it is going wrong. It is supposed to take an input of 3 bits, and in his example, separated by commas. When I try it, it seems to fail to properly format or compute the input the first time around, but then it subsequently correctly formats it, and keeps repeating it.
I am wondering:
1)Why does it fail on the first input, of say 015,015,015?
2) Why does it keep repeating the output?
3) Is it made to accept a subsequent input of another three, three bit characters? If so, it doesn't seem to work for me.
Here is the code:
[code]
#include "I2Cdev.h"
#include "MPU6050.h"
#include "Wire.h"
#define X_STEP_PIN 54
#define X_DIR_PIN 55
#define X_ENABLE_PIN 38
#define Y_STEP_PIN 60
#define Y_DIR_PIN 61
#define Y_ENABLE_PIN 56
#define Z_STEP_PIN 46
#define Z_DIR_PIN 48
#define Z_ENABLE_PIN 62
MPU6050 accelgyro1 (0x68);
MPU6050 accelgyro2 (0x69);
int16_t ax, ay, az;
int16_t gx, gy, gz;
double x,y,z, xx, yy, zz;
double d,D,A,B,C;
int F=0,f;
String readString, Sumbu_X, Sumbu_Y, Sumbu_Z;
double R,S,T;
double Q1,W1,E1;
double Q0,Q4,W0,W4,E2;
double Q3,W3,E3;
#define LED_PIN 13
bool blinkState = false;
Wire.begin();
Wire.setClock(400000);
Serial.println("Initializing I2C devices...");
accelgyro1.initialize();
accelgyro2.initialize();
Serial.println("Testing device connections...");
Serial.println(accelgyro1.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
Serial.println(accelgyro2.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
Serial.println("Input the Coordinate (3 bit each plane) Of X,Y,Z!");
pinMode(LED_PIN, OUTPUT);
pinMode(X_STEP_PIN , OUTPUT);
pinMode(X_DIR_PIN , OUTPUT);
pinMode(X_ENABLE_PIN , OUTPUT);
digitalWrite(X_ENABLE_PIN , LOW);
pinMode(Z_STEP_PIN , OUTPUT);
pinMode(Z_DIR_PIN , OUTPUT);
pinMode(Z_ENABLE_PIN , OUTPUT);
digitalWrite(Z_ENABLE_PIN , LOW);
pinMode(Y_STEP_PIN , OUTPUT);
pinMode(Y_DIR_PIN , OUTPUT);
pinMode(Y_ENABLE_PIN , OUTPUT);
digitalWrite(Y_ENABLE_PIN , LOW);
while (Serial.available()) {
if (Serial.available() >0) {
char c = Serial.read();
readString += c;
if (readString.length() >0) {
Serial.println(readString);
Sumbu_X = readString.substring(0, 4);
Sumbu_Y = readString.substring(4, 8);
Sumbu_Z = readString.substring(8, 12);
double n1;
double n2;
double n3;
char carray1[6];
Sumbu_X.toCharArray(carray1, sizeof(carray1));
n1 = atoi(carray1);
char carray2[6];
Sumbu_Y.toCharArray(carray2, sizeof(carray2));
n2 = atoi(carray2);
char carray3[6];
Sumbu_Z.toCharArray(carray3, sizeof(carray3));
n3 = atoi(carray3);
R = n1;
S = n2;
T = n3;
Serial.print("X = ");Serial.println (R);
Serial.print("Y = ");Serial.println (S);
Serial.print("Z = ");Serial.println (T);
/*Sudut Theta Satu*/
Q1 = S/R;
W1 = atan(Q1)/0.0174532925199433;
if (R>=0 && S>=0) {
f = W1/0.1;
Serial.print("Sudut 1 = ");Serial.println (W1);
else if(R<=0 && S>=0) {
E1 = 180+W1;
f = E1/0.1;
Serial.print("Sudut 1 = ");Serial.println (E1);
else if(R<=0 && S<=0) {
E1 = 180+W1;
f = E1/0.1;
else {
E1 = 360+W1;
f = E1/0.1;
/*Sudut Theta 2*/
Q0 = (T-10)/(sqrt((R*R)+(S*S)));
W0 = atan(Q0)/0.0174532925199433;
Q4 = ((13.5*13.5)+(R*R)+(S*S)+((T-10)*(T-10))-(16*16))/(2*13.5*sqrt((R*R)+(S*S)+((T-10)*(T-10))));
W4 = acos(Q4)/0.0174532925199433;
E2 = W0+W4;
Serial.print("Sudut 2 = ");Serial.println (E2);
/*Sudut Theta 3*/
Q3 = ((R*R)+(S*S)+((T-10)*(T-10))-(13.5*13.5)-(16*16))/(2*13.5*16);
W3 = acos(Q3)/0.0174532925199433;
E3 = -1*W3;
Serial.print("Sudut 3 = ");Serial.println (E3);
delay(1);
/*Link 1*/
for(F;F<=f;F++){
digitalWrite(X_DIR_PIN, HIGH);
digitalWrite(X_STEP_PIN, HIGH);
delay(1);
digitalWrite(X_STEP_PIN, LOW);
/*Link 2*/
gyro();
if (A>= (E2-2) && A <= (E2+2)){
/*Link 3*/
gyro_1();
if(C>= (E3-2) && C<= (E3+2)){
else{
if (C < E3){
digitalWrite(Z_DIR_PIN, LOW);
digitalWrite(Z_STEP_PIN, HIGH);
delay(1);
digitalWrite(Z_STEP_PIN, LOW);
else{
digitalWrite(Z_DIR_PIN, HIGH);
delay(1);
/*Link 2*/
else{
if (A < E2){
digitalWrite(Y_DIR_PIN, HIGH);
digitalWrite(Y_STEP_PIN, HIGH);
delay(1);
digitalWrite(Y_STEP_PIN, LOW);
else{
digitalWrite(Y_DIR_PIN, LOW);
delay(1);
void gyro() {
accelgyro1.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
xx = ax;
yy = ay;
zz = az;
x = xx/(4*4096);
y = yy/(4*4096);
z = zz/(4*4096);
d = x/z;
D = atan(d)/0.0174532925199433;
if (D<0)
A = 180+D;
A=D;
void gyro_1(){
accelgyro2.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
xx = ax;
yy = ay;
zz = az;
x = xx/(4*4096);
y = yy/(4*4096);
z = zz/(4*4096);
d = x/z;
B = atan(d)/0.0174532925199433;
C=B-A;
[/code]
