Getting IP but cannot connect
Hello,
First of all, this is the output I got in my serial monitor window:
Attempting to connect to SSID: CMN
SSID: CMN
IP Address: 192.168.2.6
signal strength (RSSI):-68 dBm
But when I look on my firewall/dhcp server, I dont see this IP there… not sure what I am doing wrong. Below is the sketch for the same:
WiFi Web Server
A simple web server that shows the value of the analog input pins.
using a WiFi shield.
This example is written for a network using WPA encryption. For
WEP or WPA, change the Wifi.begin() call accordingly.
Circuit:
  • WiFi shield attached
  • Analog inputs attached to pins A0 through A5 (optional)
created 13 July 2010
by dlf (Metodo2 srl)
modified 31 May 2012
by Tom Igoe
#include <SPI.h>
#include <WiFi.h>
char ssid = “CMN”; // your network SSID (name)
char pass = “7A241C3DB4”; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println(“WiFi shield not present”);
// don’t continue:
while(true);
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin();
// you’re connected now, so print out the status:
printWifiStatus();
// listen for incoming clients
WiFiClient client = server.available();
if (client) {
Serial.println(“new client”);
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you’ve gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == ‘\n’ && currentLineIsBlank) {
// send a standard http response header
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
client.println(“Connection: close”); // the connection will be closed after completion of the response
client.println(“Refresh: 5”); // refresh the page automatically every 5 sec
client.println();
client.println("");
client.println("");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print(“analog input “);
client.print(analogChannel);
client.print(” is “);
client.print(sensorReading);
client.println(”
client.println(””);
if (c == ‘\n’) {
// you’re starting a new line
else if (c != ‘\r’) {
// you’ve gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println(“client disonnected”);
void printWifiStatus() {
// print the SSID of the network you’re attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield’s IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print(“signal strength (RSSI):”);
Serial.print(rssi);
Serial.println(" dBm");
Some dhcp server is issuing this address.
Are you certain you are looking in the right place on your router? Mine shows up under "ip dhcp-server lease".
Hello,
Yes. I am certain. I looked it up everywhere. Basically this sketch is supposed to create a simple web server that I can browse to but when I do, I see "Page not found"
If the response is "Page not found" instead of "unable to connect to the server", you have a problem. That is a response after the client connects to the server successfully, but the server was unable to find the requested file.
are you using http://192.168.2.6 in your web browser address bar?
Yes. that is exactly what I am typing. I even added some more parameters to my Serial Monitor output:
SSID: CMN
Gateway: 192.168.2.1
Subnet Mask: 255.255.255.0
signal strength (RSSI):-70 dBm
So the gateway and Subnet are correct. It is getting the correct info.
The Arduino code you are using doesn't send a "Page not found" error. That is sent by the server AFTER the connection is established and the client sends a page request. ??
