Getting issue while trying to flash a sketch on Arduino(dfu error) GIGA R1
Hello Everyone i am trying to flash my sketch on the arduino GIGA board but i am getting this error, can anyone help me understand what's happening here. For intitial steps i did get the Omed board library installed.
Warning: Invalid DFU suffix signature
A valid DFU suffix will be required in a future dfu-util release
Cannot open DFU device 2341:0366 found on devnum 16 (LIBUSB_ERROR_NOT_FOUND)
No DFU capable USB device available
Failed uploading: uploading error: exit status 74
Here is my code for reference:
#include<stdio.h>
#include "CytronMotorDriver.h"
// Configure the motor driver.
CytronMD motor(PWM_DIR, 3, 4); // PWM = Pin 3, DIR = Pin 4.
// The setup routine runs once when you press reset.
// The loop routine runs over and over again forever.
motor.setSpeed(255); // Run forward at full speed.
motor.setSpeed(0); // Stop.
motor.setSpeed(-255); // Run backward at full speed.
motor.setSpeed(128); // Run forward at 50% speed.
Kindly read the pinned post re 'How to get the most from the forum', that will teach you how to post code among other things BUT your code is not relevant to this problem. You need to look at the GIGA docs to learn how to upload. DFU is different, not like an UNO at all.
What OS?
windows OS
Hi @ani680.
This error indicates you have not installed the drivers for your Arduino board.
Arduino IDE automatically installs the drivers as part of the Boards Manager installation of support for the board. However, the driver will only be installed if you provide approval, which is requested via a Windows User Account Control (UAC) dialog that is displayed during the installation:
Do you want to allow this app from an unknown publisher to make changes to your device?
dpinst-amd64.exe
It might be that the driver is missing because you did not approve its installation at that time.
The solution will be to reinstall the "Arduino Mbed OS Giga Boards" platform, making sure to approve the driver installation offer:
  1. Select Tools > Board > Boards Manager... from the Arduino IDE menus to open the "Boards Manager" view in the left side panel.
  2. Scroll down through the list of boards platforms until you see the "Arduino Mbed OS Giga Boards" entry.
  3. Hover the mouse pointer over the "Arduino Mbed OS Giga Boards" entry.
    You will see a ●●● icon appear at the top right corner of the entry.
  4. Click the ●●● icon.
    A menu will open.
  5. Select "Remove" from the menu.
    An "Uninstall" dialog will open.
  6. Click the "YES" button in the "Uninstall" dialog.
    The dialog will close.
  7. Wait for the uninstall process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
    Successfully uninstalled platform ...
  8. Click the "INSTALL" button at the bottom of the "Arduino Mbed OS Giga Boards" entry.
  9. If a "User Account Control" dialog about "dpinst-amd64.exe" appears, click the "Yes" button in the dialog:
  10. Wait for the installation process to finish, as indicated by a notification at the bottom right corner of the Arduino IDE window:
    Successfully installed platform ...
After you have done that, try uploading the sketch to your Arduino board again, just as you did before. Hopefully it will be successful this time. If not, please let us know and we'll provide further assistance.
Thank you @ptillisch will try this solution.
