Hi!
I’m completly new at the Arduino platform and at programing.
I am trying to measure the maximum acceleration of a punching bag using an accelerometer (ADXL 345); but while i can read the raw values of it, I can’t figure out how to get the program to give me the maximum acceleration values of an impact.
I would be really greatfull if anyone could give some insight on the question.
This is the sample code I’m using:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
int highest_accel = 0;
int current_accel = 0;
/* Assign a unique ID to this sensor at the same time */
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
void displaySensorDetails(void)
sensor_t sensor;
accel.getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" m/s^2");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" m/s^2");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" m/s^2");
Serial.println("");
void displayDataRate(void)
Serial.print ("Data Rate: ");
switch(accel.getDataRate())
case ADXL345_DATARATE_3200_HZ:
Serial.print ("3200 ");
case ADXL345_DATARATE_1600_HZ:
Serial.print ("1600 ");
case ADXL345_DATARATE_800_HZ:
Serial.print ("800 ");
case ADXL345_DATARATE_400_HZ:
Serial.print ("400 ");
case ADXL345_DATARATE_200_HZ:
Serial.print ("200 ");
case ADXL345_DATARATE_100_HZ:
Serial.print ("100 ");
case ADXL345_DATARATE_50_HZ:
Serial.print ("50 ");
case ADXL345_DATARATE_25_HZ:
Serial.print ("25 ");
case ADXL345_DATARATE_12_5_HZ:
Serial.print ("12.5 ");
case ADXL345_DATARATE_6_25HZ:
Serial.print ("6.25 ");
case ADXL345_DATARATE_3_13_HZ:
Serial.print ("3.13 ");
case ADXL345_DATARATE_1_56_HZ:
Serial.print ("1.56 ");
case ADXL345_DATARATE_0_78_HZ:
Serial.print ("0.78 ");
case ADXL345_DATARATE_0_39_HZ:
Serial.print ("0.39 ");
case ADXL345_DATARATE_0_20_HZ:
Serial.print ("0.20 ");
case ADXL345_DATARATE_0_10_HZ:
Serial.print ("0.10 ");
default:
Serial.print ("???? ");
Serial.println(" Hz");
void displayRange(void)
Serial.print ("Range: +/- ");
switch(accel.getRange())
case ADXL345_RANGE_16_G:
Serial.print ("16 ");
case ADXL345_RANGE_8_G:
Serial.print ("8 ");
case ADXL345_RANGE_4_G:
Serial.print ("4 ");
case ADXL345_RANGE_2_G:
Serial.print ("2 ");
default:
Serial.print ("?? ");
Serial.println(" g");
void setup(void)
#ifndef ESP8266
while (!Serial); // for Leonardo/Micro/Zero
#endif
Serial.println("Accelerometer Test"); Serial.println("");
/* Initialise the sensor */
if(!accel.begin())
/* There was a problem detecting the ADXL345 ... check your connections */
Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
while(1);
/* Set the range to whatever is appropriate for your project */
accel.setRange(ADXL345_RANGE_16_G);
// displaySetRange(ADXL345_RANGE_8_G);
// displaySetRange(ADXL345_RANGE_4_G);
// displaySetRange(ADXL345_RANGE_2_G);
/* Display some basic information on this sensor */
displaySensorDetails();
/* Display additional settings (outside the scope of sensor_t) */
displayDataRate();
displayRange();
Serial.println("");
void loop(void)
/* Get a new sensor event */
sensors_event_t event;
accel.getEvent(&event);
/* Display the results (acceleration is measured in m/s^2) */
Serial.print("X: "); Serial.print(event.acceleration.x); Serial.print(" ");
Serial.print("Y: "); Serial.print(event.acceleration.y); Serial.print(" ");
Serial.print("Z: "); Serial.print(event.acceleration.z); Serial.print(" ");Serial.println("m/s^2 ");
